Old 10-24-2011, 10:49 AM   #1 (permalink)
Default Swash to Main Grip Links- wear fast
I am getting maybe 50 flights on the ball links going from swash to main blade grips.
When they get loose i just replace as no way I want those coming off. The rest of the links hold up fine
Anyone know of a stronger ball link that does not require replacing balls?
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 10-24-2011, 12:09 PM   #2 (permalink)
I have between 1-200 flights on the QUK rocket links. I cant remember if i had to size the ball end or not though. Love those links as you can drill them out to whatever size turnbuckle or rod size you have.
Chris_M is offline        Reply With Quote Quick reply to this message
Old 10-24-2011, 12:34 PM   #3 (permalink)
Is there somebody else who has noticed this issue ?? I must have approx 150-200 flights (sport flying only !) and they seem fine... one is a bit more loose I'd say but coming off the blade grips would be a nightmare !!!
Ufoman is offline        Reply With Quote Quick reply to this message
Old 10-24-2011, 01:30 PM   #4 (permalink)
If you flight hard like Mystic, stuff wears out. Hard to avoid.
Every 10 flights, I seem to find loose bolts, worn links etc. I've resorted to red loctite in a few areas, but I've found no cure for wearing out links.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 10-24-2011, 07:10 PM   #5 (permalink)
agreed they wear out pretty fast maybe 70 flights or so
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote Quick reply to this message
Old 10-24-2011, 07:14 PM   #6 (permalink)
I looked but cannot find a substitute as those links are a different size.
Old 10-25-2011, 07:53 AM   #7 (permalink)
How do you determine if a link is wearing out (or getting loose)? I assume the process is is not just trying to pull the damn thing off the ball. Do you wiggle it back and forth ACROSS the ball?
stockman is offline        Reply With Quote Quick reply to this message
Old 10-25-2011, 07:55 AM   #8 (permalink)
Correct
Old 10-25-2011, 12:33 PM   #9 (permalink)
Perhaps it is time to move away from plastic ball links on these size heli's. I like the idea of a metal swivel type end that is bolted into the swash and grip arm, I think similar to a compass (I think this is the model) and/or a RC car links. This may require lubrication but may last longer and be more secure.
What do you think?
Something similar to this but metal
Found these, closer yet
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote Quick reply to this message
Old 10-25-2011, 12:55 PM   #10 (permalink)
Or just get a Goblin(yea baby) that has bearings attached to blade grips to a solid rod going to swash.
Old 10-25-2011, 01:05 PM   #11 (permalink)
that is another option
Carl
Old 10-25-2011, 01:59 PM   #12 (permalink)
Thats something KDE needs to come out with, Goblin style bearing link to the grips, which you can screw a normal link rod into (and be able to secure it with a grub screw).
T-REX 450P DFC 6S, SK-720BE/GPS, EDGE 50, TM1000, KDE 450XF 1450, MKS DS95x3, Futaba BLS-257, DX8
T-REX 700E DFC, SK-720BE/GPS, EDGE 160HV, TM1000, KDE 700XF 495, Outrage BL9180x3/BL9188, DX8
spikestabber is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 02:56 PM   #13 (permalink)
What do you think?
If i´m not mistaken this is how it works on the full size equivalent.
I would buy this if available.
tomra is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 11:30 PM   #14 (permalink)
I dont know if it matters but I see a lot of pictures with the long ball attached to the link going up to the grip. Manual shows to use the small ball?
Doubt it would make a difference.Just a thought.
Example of usuing the long ball vs the short ball::
c54fun is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 02:53 PM   #15 (permalink)
the small versus the long changes the geometry and will impact the FBL controller setup. Been there done that on another heli. Use the shorter ones for the links to grips and the longer ones to the radius arms.
Carl
Old 10-30-2011, 02:58 PM   #16 (permalink)
+1
mbrashear is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 02:58 PM   #17 (permalink)
+1
Old 11-01-2011, 01:30 PM   #18 (permalink)
They have a suggestions link on their site... send them your idea!
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote Quick reply to this message
Old 11-01-2011, 02:34 PM   #19 (permalink)
This is good stuff! I have often wondered why we use the plastic ball links on the larger helis ... they have come so far technologically... this has to be one of the logical next steps. The precision and safety increase would be substantial. The purple ones are just about right...maybe a little heavy but in the right direction.
Jeff
cfijeff is offline        Reply With Quote Quick reply to this message
Old 11-02-2011, 02:23 PM   #20 (permalink)
THey would be nice, but I was looking at them and this particular design would probably bind when at extreme AILE/ELEV inputs. Only way to figure this out is to try I guess.
But I still like this idea
Carl
