| Mikado V-BAR Mikado V-Stabi/V-BAR Flybarless System Software and Hardware Support |
I noticed when looking at the expert menu that there was already "EXPO" of 15% in the controller. I also added expo to my TX.... Does that mean with the 15% in the controller and 20% in the TX mean I have 35% or is it a wash?
If you use expo on the radio you need to 0 out the expo in the vbar
expo on expo is bad karma
Dave Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro MutliWiiCopter Scarab Stealth Armour, Scarab TriiKopta, Scarab Octa, Scarab Vampire |
#3 |
as deet said, bad karma
zero out your radio expo and set it on the vbar and by using bank switching on the vbar you can have differnt expo rates as well as adjust cyclic performance. if you use bank switching everything you setup bank 0 copy it to all other banks then edit the other banks for expo and agility if you dont do this when you change banks you might get unwanted pitch curves as the default bank has your setup config you did on the vbar and the others unless you change them are at the defaults. I have made this mistake it is a ugly mistake to make and it can be COSTLY!!!!
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
#4 |
I zero out cyclic expo on the vbar and do that on my radio, but leave the tail expo set in the vbar ( and therefore 0 tail expo in radio)
