Old 02-04-2015, 10:51 PM   #41 (permalink)
Originally Posted by Txboy View Post
Had my maiden flight today. All's I can say is WOW. rock solid. Not everything was perfect when I switch to idle up 1 which is a straight 70% curve I get a vibration that sounds like the canopy rubbing. I removed the canopy still same thing any ideas what this could be. I did notice when looking the bird over one of the tail blades had gotten loose. Would that cause the problem. Tail gain is set to 70. Thanks
That was my word exactly, WOW! Its hard to say without seeing or hearing it in person, but from what you describe I can only guess a few thing.
1) your experiencing the "Tail buzz", that others have encountered. Most claim the tail blades are the culprit. a friend of mine had the same issue and thought it was the carbon boom. he switched to the aluminum boom and got the same results. When i check over the bird he had tightened the tail pitch fork arms so tight it was causing binding, we loosened re applied loctite and re installed and its been perfect ever since. so check both.
2) If it is a high almost bird tweeting sound or "chirping" the GOV gain is to high in the ESC settings. I am running around 12 on my DOM 700L. if it was a Tail gain issue you would have had a very over reactive tail, it would have oscillated very fast. Im sure you know that, but sometimes it can be so fast it mimics a vibration issue.
Can you see any physical vibration, example skids or horizontal stab fin?
hope this helps, best of luck and congrats on the maiden!!
T-rex 700N DFC, TTX50, Dominator 700L, Lynx 300x, Oxy3, Team Lynx/OXY... ...Its just Dirty old money
raptard003 is offline        Reply With Quote Quick reply to this message
Old 02-05-2015, 05:10 AM   #42 (permalink)
I could see vibration in the vertical stab. What really seemed odd was one tail blade was really loose after the flight it would not hold itself in the blade holder. It wasn't loose preflight. Maybe the vibration did it...I will check all the rest and report back this evening. Thanks for the info
Txboy is offline        Reply With Quote Quick reply to this message
Old 02-05-2015, 10:32 AM   #43 (permalink)
Do yourself a favor and order Rail 106mm tail blades. It 99.99999% of the time fixes the issue. I just finished my top and the same thing happened to me. Loud buzzing noise. I switched to a set of rails and the sound vanished. Smooth sailing after that. Amazing bird
TREX 700 Pro, TREX 700LTop, GauiX3, Futaba 14SGH
Excalibur3 is offline        Reply With Quote Quick reply to this message
Old 02-05-2015, 06:30 PM   #44 (permalink)
Ok pulled the tail apart and regreased the thrust bearings and polished the tail shaft with 12000 grit micro mesh put it all back together. Noticed that the hub had left some marks on the tail shaft I guess from the vibration. I ordered rail tail blades but figured I'd give it a quick test. The vibration was all but gone but would slightly do it at the 2150 rpm. New blades will be here Monday so we shall see what happens.
Old 02-06-2015, 01:13 AM   #45 (permalink)
@txboy ok good deal you covered your bases and now when the blades show up you will have the solution. Keep us posted brother! Have fun and be safe!
Old 02-21-2015, 06:44 PM   #46 (permalink)
Burned in the Top this morning...... Dumb Thumbed it in....
Buying parts now.....
Does anyone now where to locate the RED Main Rotor Holder Arms
I can get these, and i'm pretty sure their the same item, but was wanting to go back with the Red ones. I think they look nice!
http://www.lowerheli.com/h70095-700d...or-holder-arm/
Thanks in advance for any help.
yardner is offline        Reply With Quote Quick reply to this message
Old 02-21-2015, 07:50 PM   #47 (permalink)
The only place that I have found them separately is on EBAY. There is a seller named SFIHELI that auctions off parts from all of the dominator kits. I won those red arms and the red swash for my 700. There is a set ending Monday night.
Tarot 450 FBL (Robird, YEP45, Hobbymate 2000KV, TGY306G)
Align 500 Pro DFC (Robird, YEP80, Turnigy SK3 1600KV, Savox 1250MG/1257MG)
Align 550E Pro DFC (Robird, YEP 120LV, 730MX, DS610/655)
Align 700E Pro DFC (GPro, YEP120HV, 800MX, DS615/655)
CrazyCooter75 is offline        Reply With Quote Quick reply to this message
Old 02-21-2015, 07:57 PM   #48 (permalink)
Here's mine.
Old 02-21-2015, 08:25 PM   #49 (permalink)
Wow hope u get it back in the air soon.
Nothing smaller than 700 .....
ah_liang is offline        Reply With Quote Quick reply to this message
Old 02-22-2015, 09:00 AM   #50 (permalink)
CrazyCooter75
Hey thanks for the tip CC. Found SFIHELI and made a bid on the arms.
ah liang
Thanks man, I'm sure i will. Its the same old, Buy-Build-Break-Repair-Repeat.......
Old 03-04-2015, 08:33 AM   #51 (permalink)
Any Update on this yet? curious to see if the tail blades fixed the problem...
Ukhan24 is offline        Reply With Quote Quick reply to this message
Old 03-04-2015, 08:45 AM   #52 (permalink)
They def do. Buy yourself a set of rail 106's right out the gate
Trex700Pro/Trex700LTop/X3/14sgh T$3D
Old 03-04-2015, 09:34 AM   #53 (permalink)
I think Align got a bad batch of tail blades... I had the same problem. The blades would hum and actually get out of track by about 3/4" at 2100 rpm head speed. The Rail 106's work well. Also the Cyclone 105's work very well.
Maxxs700 is offline        Reply With Quote Quick reply to this message
Old 03-04-2015, 09:48 AM   #54 (permalink)
How are the Cyclone Tail blades? do you think they will also resolve this issue?
Old 03-04-2015, 11:24 AM   #55 (permalink)
Idk but what I do know is no other tail blade works other than the rails. I wouldn't risk it. Besides the rail blades are really nice
Old 03-04-2015, 10:32 PM   #56 (permalink)
Wrong. Rotortech are even lighter.
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 03-05-2015, 08:17 AM   #57 (permalink)
I don't know about wrong. The simple fact is rails always fix the problem. I couldn't recommend another blade cause I haven't personally seen any others solve the problem. There are always exceptions though. But for me it's rail 106
Old 03-05-2015, 09:03 AM   #58 (permalink)
Thanks Ex! I'll give me a try
Old 03-07-2015, 07:12 PM   #59 (permalink)
I just meant that the light weight is why the problem goes away. Rotor tech are crazy light...
AMA 373608
Old 03-23-2015, 06:40 PM   #60 (permalink)
Must resist the temptation to buy another 700. These dominator top 700's are awsome
TRex 550e DFC Pro Demon 3sx
TRex 700e DFC PRO HV Demon 3sx
Goblin 630 Demon 3sx
JR XG14
Chewy700 is offline        Reply With Quote Quick reply to this message
