Old 07-20-2012, 04:34 AM   #1 (permalink)
Default Dx7s 2-pos. Flight mode?
Hello! Is this possible? I mean like idle 1 and idle 2.
Thanks in advance
Rclover is offline        Reply With Quote Quick reply to this message
Old 07-20-2012, 05:30 AM   #2 (permalink)
no not with the dx7s you could with the older dx7
JR 11XG DMSS the only way to go , xcell 60 xcell 60 SE
jet ranger xcell 60 mechanics now electric
T rex 700e, beastx V1, Trex 700 F3c V2,
Trex 500 stock ,trex 500 fbl (beastx ) , 500 scale ,Trex 550e , MFA 500,.Micromold Lark
sircol is offline        Reply With Quote Quick reply to this message
Old 07-20-2012, 10:10 AM   #3 (permalink)
And there aint no other way like to program à mix or something?
Old 07-20-2012, 11:58 AM   #4 (permalink)
Yes you can do a mix to boost rpm if thats your main difference between ST-1 & 2
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote Quick reply to this message
Old 07-20-2012, 10:24 PM   #5 (permalink)
Thanks in advance
It is possible. You have to set thold for 0% to get the esc to arm and then just use idle up pitch and throttle curves for both positions, of course you won't have a normal mode and if you accidentally bump the thold, the heli could spool up at full power, depending on the setup of your esc and you have to work around the thold alarm on your radio by starting the radio with thold off then enable it and then continue to power on the heli.
I've seen some real knuckle heads try this, DONT DO IT. Because, people are dumb, really dumb, even the smart ones. With low throttle and thold, you have a double safety for spoolup. When you by pass this with the method I described above, you are now at the mercy of one single switch and bad things can happen.
Thumbs Only!
phoenixheli is offline        Reply With Quote Quick reply to this message
Old 07-22-2012, 01:22 AM   #6 (permalink)
I upgraded from DX7 to DX7s without realising it had only 2 flight modes instead of 3 (thanks Spektrum) but in reality it's not that big an issue if you have soft start on your ESC.
Program position for Idle 1 and the other for Idle Up 2, start with TX in Throttle Hold then select let the Slow Start work directly in flight mode 1 or 2.
What goes up must come down, only why so hard?
Spektrum DX7s, Align 450 Pro, Blade 450 X, Align 500 DFC, Blade mCPX & MQX
Radium Pro Electric Glider. Sydney Australia
Corona is offline        Reply With Quote Quick reply to this message
Old 11-05-2012, 10:18 PM   #7 (permalink)
It is possible, I'm using mine with the mix1 setup aux2>>thr and active for IU. Then I assigned my gear switch to AUX2 channel to use as an IU2 switch. FM switch puts it in IU1 then Gear switch puts it in IU2, this way I still have use of my gyro channel for the gyro gain. You set your throttle curve on IU to what ever curve you want, then add mix to raise or lower the throttle in either the up or down switch position. With using the mix in this way you will still have a normal mode and a TH mode as well as 2 Flight modes.
Tasteles is offline        Reply With Quote Quick reply to this message
Old 12-22-2012, 10:28 PM   #8 (permalink)
I just wanted to give Tasteles a "" for this post; I just programmed my DX7s with a Mix giving a throttle offset to essentially provide an additional IU setting as per his instructions; I'm looking forward to trying it inflight tomorrow.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8
Skidpad is offline        Reply With Quote Quick reply to this message
Old 12-22-2012, 10:34 PM   #9 (permalink)
As long as you have slow spool up.. just set the 2 positions to idle1 and idle2. Thats what many of us do who run governor mode and can't have a normal mode.
Old 12-22-2012, 11:00 PM   #10 (permalink)
Agreed Sly, I was just trying avoid losing my Normal mode (for some reason); this is a slick way to gain an IU mode and retain Normal without buying a new tx.
I'll be experimenting with governor mode soon
Old 01-19-2013, 04:19 PM   #11 (permalink)
I also was let down with the no 3 position switch. However with a little mixing and editing I now have a normal, and 3 idle up configuration to be used with the castle gov.
First we set our Idle up low throttle for the castle gov.
Then we want to set up our "Governor" Note that it is set to AUX2 and Gyro switch. I personally dont have anything in Aux2 on the RX.
Then we adjust mixing. Note that I only have this mixing enabled in idle up mode.
Now you have a 3 position idle up switch. You activate idle up with F-Mode and adjust headspeed with the 3 position gyro switch. These settings are set up for the set headspeed with the castle ESC. Lastly 3 photos show you how we just affected the throttle channel only when changing the gyro switch.
Spartan Vortex, Scorpion Motors, ExperienceRC Batteries, OMG Servos
FrSky Taranis
DaveHolland is offline        Reply With Quote Quick reply to this message
Old 01-19-2013, 09:38 PM   #12 (permalink)
Thanks for the lesson. Nothing like pictures!
kingmeow is offline        Reply With Quote Quick reply to this message
Old 01-20-2013, 01:34 PM   #13 (permalink)
I have since refined this mix and made a video going over it. In the video is properly set for the casle gov at 30, 70 and 100%. It also keeps the normal flight mode open for you to use or as a back up 0% throttle. The photos will work just fine for phoenix sim but do not correctly align with the CC gov.
FrSky Taranis
Old 01-21-2013, 12:43 PM   #14 (permalink)
This should be sticky!
(Now how does one nominate that?)
Old 11-20-2013, 12:56 PM   #15 (permalink)
dct
Yes that's all I would like to do...
But how???
DX7s any links??
Thanks Dan T
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And
T-rex 450 Pro, DFC with AR7200BX , Blade 300CFX, and Two, Blade 130X , Blade 350QX .!
dct is offline        Reply With Quote Quick reply to this message
Old 11-21-2013, 10:03 AM   #16 (permalink)
dct
I think I figured it out on my own...
I don't run a ESC set in governor mode ...
So, I only use throttle curves ...
I like them much better !!!
I can't see wasting all that battery power when not needed ...!!
That's why I can get 7 minutes flights on my Trex 550 ...!!
Old 03-30-2015, 09:21 PM   #17 (permalink)
Actually you'll save more battery power with a governor, but whatever!
M52 POWER! is offline        Reply With Quote Quick reply to this message
