Go Back   HeliFreak > R/C Helicopter Support > Kasama Helicopters and Upgrades
Kasama Helicopters and Upgrades Kasama Srimok 90 Helicopters and Upgrades Discussion
Old 03-14-2014, 11:52 AM   #21 (permalink)
Originally Posted by Romeo RL67 View Post
I machined a new component and cut/modified the crown gear to fit.
Attachment 494465
Attachment 494466
Reverse the pinion block and the front tail holder. I have to cut the tail and the torque tube to retain the original length.
Romeo RL67 is offline        Reply With Quote Quick reply to this message
Old 03-14-2014, 11:52 AM   #22 (permalink)
Attachment 494465
Attachment 494466
After all that effort I hope it works for you!!
Ben - UK's sole stockist of Kasama Helicopters - www.kasama.co.uk - we ship worldwide
FREE WORLDWIDE SHIPPING ON KONTRONIK PYRO COMPETITION EDITION MOTORS, choose your KV and custom engraving - www.kontronik.co.uk
BenScoobert is offline        Reply With Quote Quick reply to this message
Old 03-14-2014, 11:54 AM   #23 (permalink)
I flew it twice now, Ben. But havent pushed it hard.
Old 03-14-2014, 11:59 AM   #24 (permalink)
I just loved this heli so much but I do not have the peace of mind flying it with the original crown gear. Too bad I can only do this on the Faifa because the main gear is wide enough. I can release the CAD drawing so that other srimokers can get this made by their local machine shop.
Old 03-16-2014, 04:59 AM   #25 (permalink)
Yes please Romeo If you could send over those CAD drawings that would be great
JR Forza 450 | Align Trex 550 V1 | Henseleit TDF | Henseleit TDSF
Varelco is offline        Reply With Quote Quick reply to this message
Old 03-16-2014, 02:26 PM   #26 (permalink)
Default Crown and Bevel Gear
I'm building mine at the moment and I don't think all the blame lies on the crown gear. Just looking and setting up the tail take off mesh shows some flaws in the bevel gear support block design. There's only two bolts supporting it and the holes they go into are huge producing a very sloppy fit. The only thing stopping the block from twisting and rotating in flight is the friction produced by those two bolts. A third support bolt position further forward would help a lot in reducing the twist on this block. A third support bearing in the lower bearing block would be even better.
I haven't flown it yet but I've used a lot of MA helis with crown gears and there design is pretty bullet proof but its very differant to Kasamas design.
I'm not controlling it, I'm just preventing it from crashing.
Joe Bailey is offline        Reply With Quote Quick reply to this message
Old 03-17-2014, 09:54 AM   #27 (permalink)
Crown gear adpter.pdf
Old 03-17-2014, 10:34 AM   #28 (permalink)
I've never had any show signs of movement post flight.
Old 03-17-2014, 01:15 PM   #29 (permalink)
Me either.
I believe all helis have their own limitation and I have reached the tail limit on this heli.
Just like the TDR, they have reached the RPM limit so they are building a bigger drivetrain TDR/TDS.
Old 03-18-2014, 04:30 AM   #30 (permalink)
I'm afraid will get a tail blow out. I guess we need to do an inverted hurricane with that set up and see if the tail blows out.
Backwards full pitch circuits, speed run to sideways loops and very hard-stop tail down were all fine with the reduced tail pitch. Not even a hint of tail blowout.
I flew the same manoeuvres two days before, without reducing the tail pitch and stripped the teeth in three different spots on the crown. I'm also only running 95mm tails, though the head speed is 2200rpm.
With the amount of tail pitch at full travel, the tail blades are stalling the drive train.
Kasama UK | Bavarian Demon
wadders248 is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 06:58 AM   #31 (permalink)
So exactly how much is the travel being reduced by? I plan to run to a headspeed of 1900 and lower on 105 tails.
Old 03-18-2014, 08:54 AM   #32 (permalink)
Wadders did approximately half, about 20° each way.
Old 03-18-2014, 09:12 AM   #33 (permalink)
Well this is a good news then, cause I have the classic Srimok and Dune that I cant apply this mod.
Old 03-18-2014, 09:14 AM   #34 (permalink)
It's not a mod, it is a setting in your FBL unit or gyro, just reduce tail throw limits
Old 03-18-2014, 09:35 AM   #35 (permalink)
I meant, my KDS mod.
Old 03-18-2014, 12:47 PM   #36 (permalink)
Fantastic mod by the way... it would still be good to have the option from Kasama to have helical tail crown and gear, but at least reducing the tail pitch gives a solution for people who want to use stock parts.
Old 03-18-2014, 01:14 PM   #37 (permalink)
I would like to get the helical stuff on mine to, but atm i not having problems with the stock parts, mine used to eat the bevelgears in 5-6 flights , even if i had the mesh tight or loose, my pinion had pretty sharp edges.
So, i pulled it out and went over each tooth with a small file to dull the edges some, put it back in with a new bevelgear and set the mesh pretty tight. Havent seen a speck of white dust from the bevelgear after that.
Jan
Futaba T14SG, Copterx/align 450 Pro miniVbar, Tianzi TZ 50 (Stinger 50), T-Rex 600N pro Vbar, Kasama Srimok 90n ECO Vbar, Minicopter Diabolo 14s Kosmik200 pyro800 Vbar
Y@nkee is offline        Reply With Quote Quick reply to this message
Old 04-28-2014, 12:41 PM   #38 (permalink)
This heli is worry free now to my skill level. Had more than 30 flight on it now without any lubricat on the bevel gears.
I have 1 extra of this mod. PM me if you need it. This will include the modded gear and the machined adapter, no screws included. You will have to buy the other matching bevel gear.
Old 04-30-2014, 04:45 PM   #39 (permalink)
I've just reduced my throw mechanically by moving the servo ball in a hole after stripping a second crown gear in as many days!! Yesterday was with 105's on and full throw and today was with 95's but was doing a vbar optimization so full rudder and hard stop etc etc. Have to say its going to take a few flights to get confident with it again although I've had a Faifa before and had zero issues with the crown.
Is there any chance one of you fine people could measure the distance you're getting between the tail gearbox now you've reduced the throw/pitch? I think I've reduced the throw by around 4/5mm, that sound about right?
I'd certainly buy any upgrade that became available.
George J is offline        Reply With Quote Quick reply to this message
Old 04-30-2014, 10:32 PM   #40 (permalink)
I've reduced mine to 20 and 25 degrees. I say there smacking the tail left and right for a whole flight to test it. I find it hard to believe anyone could strip a crown at these amounts. Tail held perfect too.
