Old 05-02-2012, 03:15 AM   #1 (permalink)
Default microheli upgrades with original electronics?
Hi guys!
Been flying my mCP X v2 for a few weeks now and she has about 150 fligts on her. My swash has had a few bangs (because of me not the crashes) but I am still amazed about how amazing this lil' heli flies!
However, many parts are broke and loose so I am thinking to upgrade the lil' bird. I am thinking of a microheli frame, tail and rotor head upgrade.
I don't feel rdy yet as a pilot to go brushless (I will do that with time). So I am keeping my original motor (working really well) and electronics.
My question is: Will I be able to use the original motor and electronics in the microheli frame?
Thanks a bunch! And to top it off, here are some nice photos in flight
KristoferSwe is offline        Reply With Quote Quick reply to this message
Old 05-02-2012, 03:33 AM   #2 (permalink)
Yes you sure can. The only electronics you can really upgrade would be the motor and battery but stock will work fine withe microheli upgrades.
youturnjason is offline        Reply With Quote Quick reply to this message
Old 05-02-2012, 03:42 AM   #3 (permalink)
Super!
Thanks man! Then I will place my order. I guess it's not long until I get myself a brushless motor and ESC.
There seam to be so many choices out there. But like it as clean as possible. While I am here.
Any good suggestions? I have not read so much yet, but will educate myself better before the conversion
Trex 450 Pro v2, E-flight Blade mCP X v2 c05m BL. Using a Spektrum Dx8
E-sky lama v4 (old but still flying )
Old 05-02-2012, 03:48 AM   #4 (permalink)
If you want a simple upgrade grab a c05m + 10a pnp esc. Similar headspeed as stock but way less blowouts and bogging (Also lighter so crashes just as well).
Personally the only microheli upgrade I found worth it was the swashplate, because I kept breaking balls off my original one. Other upgrade I haven't really noticed a difference in performance, but others have had increases in performance.
Old 05-02-2012, 04:14 AM   #5 (permalink)
Ok,
Yeah, thats exactly what I need right now as well, a new swash! But my landing gear is glued and not olding up and the main frame is really weak at one spot. I guess I wont notice a big difference in the other parts, but at least it will held up. I rather buy upgrades than new original landing gear, frame etc.
Old 05-02-2012, 05:49 AM   #6 (permalink)
I have 2 mcpx's
My v1 has
- Mh x Frame
-X Swash
-MH grips
_mH rotor head
My V2 has
-Mh Swash
I prefer my v1, it has alittle more weight but not enuf to feel bogged down or even really noticible but it is so much more crisp and predictable. The 2 main upgrade i think you should invest in are a X swash and X frame from MH or whatever company you choose.
Since having the frame i have had no broken frame posts and no more landing gear getting stuck in the frame. Worth every penny imo. The swash is also a great upgrade, i was having trouble with stock swash balls breaking or nearly coming off and decided it was time for a swash upgrade. The cyclic inputs seem much more crisp and have had 0 issues with it since, and even bought a extra for the v2.
MH Grips and rotor head are a worthwhile upgrade if you have the money but imo are less of a necessity. The head is nice so you dont lose links which is why i got it and it has saved me a lot of links so far. The grips i enjoy becuase they have 0 lateral play in them compared to the stock ones. Whatever you get you will enjoy.
branmuffin is offline        Reply With Quote Quick reply to this message
Old 05-02-2012, 06:33 AM   #7 (permalink)
Sounds hreat!
WHats the difference from the "normal" MH frame and the X frame? Is it only to have the anti rotation rod in the back?
Dose that really matter where you have it? I am thinking of going with the nromal frame.
Old 05-02-2012, 07:36 AM   #8 (permalink)
Actually my bad branmuffin does make a good point. The X frame is definitely worth it for the A/R relocation.
Kris while your heli is on the ground give forward and backward cyclic and watch the swash. You'll notice it twists to the left as you go forward and doesn't move straight. This is due to the location of the A/R bracket. All they needed to do was put the A/R pin higher it didn't need to be at the back but that silly design decision makes it twist. You may or may not have noticed in flight your heli goes a bit to the left on forward cyclic.
Old 05-02-2012, 07:46 AM   #9 (permalink)
Agreed on the X Frame and the relocated A/R bracket along with the X Swashplate. I have this on my HP06V2 setup and the elevator control is noticeably better. Very easy to replace canopy mounts on this setup when you break them like I did yesterday in a pretty spectacular (for an mCPX) crash.
Chris Gardill is offline        Reply With Quote Quick reply to this message
Old 05-02-2012, 08:05 AM   #10 (permalink)
youturnjason´: I just noticed that a few days ago when I was fiddeling with my servos.
Just to clear everything up. We are talking about this frame right?
http://www.microheli.com/store/produ...roducts_id/673
and his swash?
http://www.microheli.com/store/produ...roducts_id/678
Ok then. Time to upgrade this baby! When I feel the motor is giving up on me I will get me a brushless!
BTW is it worth it getting an extended boom? I like how small and tight the heli is now. But I guess I will be putting a 120 motor in the back when converting to brushless, is the larger boom needed then or can I fly on my standard?
Old 05-02-2012, 08:08 AM   #11 (permalink)
Yep those are the ones!
It depends on what motor you go with, if you go with a c05m then extended boom is fine, but if you go with a more powerful motor you'll want a sr120 tail or dual-tail. C05m requires alot less modifying and keeps the lightness and crashability of the mcpx. HP05s or bigger turn it into a screamer but then its no longer really an mcpx anymore
Old 05-02-2012, 08:19 AM   #12 (permalink)
Oh, then it really sounds like I wanna go with the c05m!
So if I go with that motor, the original tail motor and a extended boom would hold it? Or may I even keep my shorter boom?
Old 05-02-2012, 08:25 AM   #13 (permalink)
I went extended while i was still stock cause my boom kept breaking and wanted a solid one so I can't say how stock will hold, although if you aren't experience blowouts with stock then it should be fine, as the brushless motor draws power from the esc not the 3in1 so it means the tail doesn't get its current stolen by the main motor.
Old 05-02-2012, 08:31 AM   #14 (permalink)
Well I get some blowouts and these 1/4 turns now and then. More often after 2-3mins of flying. Guess an power issue. So maybe I should look into the extended to be sure
Thanks for all the info!
Old 05-02-2012, 08:39 AM   #15 (permalink)
No worries!
Trust me once you get a c05m in there you will fall in love with your mcpx even more
Old 05-02-2012, 09:12 AM   #16 (permalink)
Sent you a PM youturnjason
Old 05-02-2012, 10:16 AM   #17 (permalink)
One thing to think about with the x frame and swash; if you reverse the front servos in the mounts you will need two more straight rear servo links rather than the stock ones with the right angle bends. I missed that detail when I ordered the kit and had to rob a link from another and fab the third.
________________________________
TRex 700E (2) - Fusion 50 (4) - Goblin 630
TRex 500 (5) - Trex 450 (6)...
Hell, lots of Helicopters. Lots. Airplanes and Quads too.
Unless this is my wife reading this, then just a couple.
rkweekly is offline        Reply With Quote Quick reply to this message
Old 05-02-2012, 03:37 PM   #18 (permalink)
Where's the best place to get the c05m + 10a pnp esc? Is it fully PNP meaning no soldering needed, no other electronic parts needed?
Tony777 is offline        Reply With Quote Quick reply to this message
Old 05-02-2012, 07:59 PM   #19 (permalink)
Astroid is one of the favorites of the forum, as far as the PNP c05 setup goes.
An extended tail boom is easy to do, and cheap (~$2 for a length of solid 2mm carbon fiber rod, and a few minutes trimming it down to 145-150mm and sanding on the flat spots). Definitely recommend it hands-down on a stock (night and day difference!), and as I understand it, is 100% necessary for a c05 setup unless you're going for an upgraded tail motor. At which point, why not just go for an hp05 setup instead?
Blade: mCX2, mSR, mSRX, Nano-CPX, 2x mCPX (v1), mCPX-BL, 120SR, 450 X
Spektrum DX8, DX6i
Talesin is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 12:52 AM   #20 (permalink)
I read somewhere that the M5 motor is a simpler install as compared to the C05M motor because less frame modding is needed, is that true?
