Old 11-02-2010, 02:35 AM   #281 (permalink)
Ahhh ok
JR9303 / JR9503 / Futaba10CHP
Old 11-02-2010, 07:32 AM   #282 (permalink)
Originally Posted by Stumblebee View Post
I was looking at the Combo 2. Still backordered until Nov 15.
QUOTE=nightflyr;2438288]I just looked they have them now.....where are you looking?
Cellpro PowerLab 8, 1000W, Multichemistry Battery Workstation UNLEASH THE POWER! The industry's first 1000W Battery Workstation will charge, discharge, monitor, or multiple cycle any current or future battery chemistry. Was: $279.95
Price: $229.95 (Excl. GST) – Quantity in Basket: 1
[/QUOTE]
Hi,
The FUIM3 (PC interface) is on backorder and should be available November 15th.
Howard Matos is offline        Reply With Quote Quick reply to this message
Old 11-02-2010, 01:08 PM   #283 (permalink)
Default Amazing what you stumble across
Now most of you wouldn't know about this,... but trying to find large length boom stock has been a bit of a job.
There is one that is designed for an 800 size bird but it is a bit larger in diameter so in oorder to get it to work I needed to machine the tail casing open for it to fit.
And unless you wish to pay a premium price for a manufacturer to produce a custom tube, your choices are extremely limited.
Until today...I'm at work and after doing a bit of cutting, I needed to clean up the mess.
Coming back with a broom and dust pan..it struck me that this broom handle appears to be the same size as a ALIGN boom...
So I grab a pipe cutter and section a piece of the handle to get some measurements..
Amazingly..The OD is only 0.022 larger than the ALIGN boom tube , ID is close enough were the bearing rubber holder will still get a good grip.
So it turns out this "Quickie" broom handle has a new purpose..cheap, easily available boom stock.
Today was a good day
Old 11-02-2010, 06:29 PM   #284 (permalink)
Coooool
I'm gonna have to take a look around, I may be surrounded by Heli parts and don't even know it
When the people find that they can vote themselves money, that will herald the end of the republic.
~Benjamin Franklin ~
Navigator53 is offline        Reply With Quote Quick reply to this message
Old 11-04-2010, 08:11 PM   #285 (permalink)
Oh Gawd I hate this time of year when the laboratory is "Moth balled"
Old 11-04-2010, 08:14 PM   #286 (permalink)
And where did you get that impression from...
Old 11-04-2010, 09:44 PM   #287 (permalink)
Oooops.....almost forgot night, you're always working on something!
Old 11-05-2010, 12:18 AM   #288 (permalink)
NightFlyr's Lab Never Stop's
My fantasies of flying a Heli, is better than the reality.
JR X9503.FunJet Ultra, Scimitar, Stryker F27C and Q, DogFighter, mCPx
FLAME747 is offline        Reply With Quote Quick reply to this message
Old 11-06-2010, 05:38 PM   #289 (permalink)
Default A new challege for the laboratory
It was asked if this could become a reality..
With the use of these....
CF930mm
Carbon Fiber 930mm Professional Heli Blade
Could a TREX1000 be created......
(.... quietly walking down into the damp darkness of the laboratory......)
Old 11-06-2010, 07:24 PM   #290 (permalink)
You answered your own question here
Blade400
pril250 is offline        Reply With Quote Quick reply to this message
Old 11-08-2010, 09:40 PM   #291 (permalink)
Default Battery stuff
Night, if you wouldn't mind I would like your help in checking my thinking regarding setting up this charging station using FMA's charger.
While this charger can output 1000 watts of power, my requirement of being able to charge four 3S 2000 lipos at the same time does not require anywhere near that amount of wattage.
I have found a 340 watt switching power supply of the same engineering standard as the ones in your photo. All I have to is figure out which lines to short on the output in order to have it turn on. That one is not exactly rocket science.
I am not the greatest with Ohm's Law but I figure that 12 volts at 2.2 amps would require at most about 26.4 watts to recharge. Multiplying that wattage time four gives me about a 105.6 watt load at max. This is well within the range of my power supply. I plan to recharge full balance at 1C normally and at the most, 2C. I should still have plenty of current to run the electronics of the power supply itself. Perhaps my calculations are totally off on this one.
Any input is welcome at this stage.
Stumblebee is offline        Reply With Quote Quick reply to this message
Old 11-08-2010, 10:22 PM   #292 (permalink)
Hi:
Maybe I can help you out. If I read your post correctly, you have a 340W, 12V PSU?
340W / 12V = 28A the unit will output
Set the PL8 input current limit to 25A using the CCS Supply tab and check the Power Supply as the input source. Click update. Or if you don't run the CCS, you can set these parameters at the PL8. Please check the very first few pages of the user guide for more instructions.
After you set input current limit, the PL8 will automatically protect your PSU and will never draw more than 25A from it.
As for what you can get at the output:
25A x 12V = 300W at the input
300W x 0.85 (worst case efficiency) = 255W at the output
255W / (3 * 4.2) = 20A
You could charge your 3s 2000 mAh LiPos at up to 20A; not that you would want to. By setting the input current limit up the way I mentioned above, even if you set the output current to 30A, the PL8 would never exceed 20A on a 3s battery.
You can just download the PL8 Power Calculator spreadsheet and punch these numbers in to get the results I provided above. Or you can look at other PSU's and see what they will do, etc:
2nd link on the PL8 Resources tab:
http://www.revolectrix.com/pl8_links_tab.htm
Oh, and by the way, the original PL8 v1 is 1000W output when powered by 24V input. But the v2 upgrade enables the v1 unit to go up to 1344W output on 26.35V.
Tim Marks
Tim Marks is offline        Reply With Quote Quick reply to this message
Old 11-09-2010, 12:06 AM   #293 (permalink)
Now there's an idea
CF930mm
Old 11-09-2010, 07:45 AM   #294 (permalink)
Hi Tim
Thanks for your help on this one. Looks like this is the direction I am going in after the 15th of November. Are you folks still okay shipping this item to Canada using the regular postal service? UPS is still living up to its reputation regarding its "brokerage and customs fees" to Canada. UPS continues to be the service one would use to send a parcel from the U.S. to someone you absolutely hate in Canada.
Old 11-12-2010, 04:55 PM   #295 (permalink)
Default FINALLY .....
I can call the 600>800 AP stretch a success!!
With the help of some talented folks @ the AP forum.. the shakes are finally gone and the bird can video record like a charm.
Sorry its a bit dark..but I still hates DST/EST
[ame]http://www.youtube.com/watch?v=XytnDWjp5qo[/ame]
Old 11-12-2010, 05:28 PM   #296 (permalink)
So Night, looks rock steady,what did to actually have to do to finally nail it. Was it to do with ESC, TT or gyro/Beast.
Blade400
Old 11-12-2010, 05:36 PM   #297 (permalink)
Went to fixed end points in the ESC, and strapped the 4 boom stays.
Though I will try SET RPM again tomorrow and see if I can still use it, if not fixed end points and a 58 - 65% throttle curve will work fine
Old 11-12-2010, 05:54 PM   #298 (permalink)
For a job well done and a success.
Next................
Blade400
Old 11-12-2010, 06:00 PM   #299 (permalink)
if I can get a few hours in, I need to get a bird trimmed up for some flight time
Old 11-12-2010, 07:37 PM   #300 (permalink)
Hey nightflyr, if it is any consulation, things aren't any better with DST/PST! Those light photons start getting real scarce around 4:00 PM.
