X7 Discussion and support of the Gaui X7 |
09-22-2012, 09:53 AM | #1 (permalink) |
ar7200bx on x7
Hi
Could you please show some pictures of your wire job on your 7x ? I just got one, and will use a 7200bx on it, but not sure where to place it. Could it sit on the tray just above the main gear? - its just angeled a bit, but will it effect the beastx's performance? Or is it better to put under gyro plate in rear? Best regards |
09-22-2012, 04:14 PM | #2 (permalink) |
hi, i place my beast on top of bottom. very nice to setup on field and i can see every time the led and status
olli |
09-22-2012, 06:33 PM | #3 (permalink) |
I had an ar7200bx wired the same way before putting the vbar on. Here is a link to the post.
It's mounted under the boom. https://www.helifreak.com/3837928-post.html Sent from my iPhone using Tapatalk
Synergy Factory Specialist / Rail Blades / Team Scorpion |
09-23-2012, 01:23 AM | #4 (permalink) |
hi again.
and thanks for sharing it was actually that place i would put the ar7200 on, but i totaly forgot that itīs a bit wider that the norman BX, so therefore it doesent fit -but then i just put it under the gyro plate. -about the question of BX angeled a bit, does anyone know? best regards |
09-23-2012, 05:37 AM | #5 (permalink) |
It does fit. Just have to move it back on the try far enough that the antennas clear. Trust me. I had mine there. Fits fine.
09-23-2012, 11:45 AM | #6 (permalink) |
Okay, thanks allot
I will take a look at it when i get home from job |
