Old 05-27-2010, 10:44 AM   #1 (permalink)
Talking Rayguns custom DDVP tail for my Trex 250
Just getting started on the installation.Just a couple super minor mods needed.
I'm waiting on a tail servo and gyro which are in the mail already.
The machine work is beautiful.
All I did was move my ESC from the rear center to the front and balance is perfect.
The motor added 10 grams but you have to remember,I'm losing the tail shaft,pulley and belt so weight is almost a push.
The second ESC is lighter than one of the wires.lol...Tiny.
Nice work Ray.I'll have it flying in no time.
McKrackin1 is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 11:03 AM   #2 (permalink)
Just a question, as I've not heard anything about this mod.
Why would you go with a tail motor? Most that have a tail motor try to get mods to get rid of it.
Craig
Ozz58 is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 11:03 AM   #3 (permalink)
Slight mod to the tail fin...
Old 05-27-2010, 11:06 AM   #4 (permalink)
Craig
Most helis with tail motors work with variable speed and fixed pitch.
This has variable pitch and will run a very consistent speed for a very steady tail.
Without the belt,about 20% more power is going to the main rotor.
Also,no matter what I do to bog the main rotor,the tail rotor will not be effected in the slightest.
Old 05-27-2010, 11:06 AM   #5 (permalink)
dze
awesome, cant wait to see how it works on the 250 .. i tested one out on a 450 and it looks like the system actually has potential. I wonder where this will go and if it will actually catch on?
[ame]http://www.youtube.com/watch?v=jXJKefAQeDY[/ame]
dze is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 11:14 AM   #6 (permalink)
There's a fairly high end heli I saw recently (was it a 90 size Minikopter???) that has a separate motor to drive the tail. I presume you'll still run it from the main flight battery right?
J-S-Q is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 11:30 AM   #7 (permalink)
It probably will not catch on because of the increased complexity and failure modes.
Neat but impractical.
Ultraviolet is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 11:31 AM   #8 (permalink)
All that's missing is the direct drive main rotor.
https://www.helifreak.com/showthread.php?t=18988
Winfred is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 12:29 PM   #9 (permalink)
It runs on the main flight pack.Right.
It's pretty simple really and I think it's less work than taking care of a belt.
Old 05-27-2010, 02:10 PM   #10 (permalink)
what do you mean by "taking care of the belt"? properly set up a belt needs only occasional tension check like a motorcycle drivebelt. Plus the belt puts no weight at the tail where you don't want any.
Outrage Fusion 50 FBL / Futaba 8FG / Beastx / Scorpion HK4025
sansone is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 03:52 PM   #11 (permalink)
You die hard belt defenders have got to GTF over it
Nobody slammed a belt drive or said it was difficult.
I said the motor is easiER which implies the belt is EASY.
This is not meant as a debate as to which is better.
I'm simply showing you guys something I'm working on.
I'm sure you all can rest easy knowing the belt drive will be on the market for years to come
Old 05-27-2010, 03:58 PM   #12 (permalink)
The guys on RCGroups that were doing this on 450s had tail pitch and throttle curves on their wish list for radio enhancements.
T-Rex 700N, 600NP, 450v2 w/Pro head, 250SE - Blade mCP-X, mCX, mSR x 2, Parkzone F4U Corsair: All on DX7se
Sonic_BOOMER_SOONER is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 04:06 PM   #13 (permalink)
My throttle curve on the tail is 0-50-100-100-100 so it spools up to full speed before the heli lifts off and runs wide open at a steady RPM throughout the flight.
You simply program the ESC with half throttle as 100%.
Since everything above half throttle is 100% idle up will have no effect on the tail speed.
Old 05-27-2010, 04:48 PM   #14 (permalink)
That is a cool idea, how did you calculate the motor size for the tail?
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class().Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even.
.Who is John Galt?
755 robert is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 05:18 PM   #15 (permalink)
wow! And here I thought I was kind of inventive Thats a pretty cool idea!
T-Rex 500/spartan Quark
T-Rex 450 Pro:Walkera BL 4G3:Walkera V120D02S
Richard F. is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 05:29 PM   #16 (permalink)
You die hard belt defenders have got to GTF over it.
who pissed in your corn flakes?
I only asked because I was curious about your inventive modification. Obviously you are too defensive. I studied your pics and thought the work is neatly done.
Old 05-27-2010, 05:40 PM   #17 (permalink)
Sorry about my first post as I didn't see the tail servo and thought you change it to a veriable speed tail motor, my bad.
After seeing what you are doing I'm very interested in the result.
Again sorry for the quick jump to "Why would you do that" statement.
Keep up the good work,
Craig
Old 05-27-2010, 06:21 PM   #18 (permalink)
lol...That's funny.You're the one that jumped bad in defense of tail belts
That's an old and tiresome argument which I want no part of is all I meant to say.
Not being defensive at all,just saying I'm not going to debate the merits.Gotta head it off early as a bunch here like to start off by calling me sad and stupid.
Thank you by the way.I think it's looking good so far.
I've had it fired up and I have some tweaking to do but it has a ton of thrust.
For some reason the tail motor runs in throttle hold.I'll try a big negative number in throttle hold later.
I ran it for 10 minutes and the little 6A ESC got barely warm.
Old 05-27-2010, 06:37 PM   #19 (permalink)
For anyone curious as to why....I am just looking for a bolt on mod for helis like the SR and other DD tail helis that have bad issues with tail motors.
Old 05-27-2010, 06:39 PM   #20 (permalink)
[ame]http://www.youtube.com/watch?v=7efiAIJoNso[/ame]
