Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 09-27-2010, 09:10 PM   #1 (permalink)
Default Flybarless X5 Photos, Files and Setup Notes
Hi guys!
There's obviously lots of interest in running the Gaui X5 without a flybar. It occurred to me that a sticky would be a great place to consolidate our findings. So .... here we go!
Post your flybarless X5 photos, files and setup notes here! If you have questions regarding a fbl X5 feel free to post those here too. It doesn't matter which system you fly. We're not looking to answer any questions about which system is best. If you feel strongly about that and need to say so - please, start another thread. The goal here is to be helpful. If you are new to fbl, there can be a bit of a learning curve. Some frustration in the beginning should probably be expected. Hopefully we can keep the difficulty to a minimum and maximise the fun.
Peace out!
terrabit is offline        Reply With Quote Quick reply to this message
Old 09-28-2010, 12:55 AM   #2 (permalink)
This is certainly not necessary for vbar 5.0 but, if anyone's interested, it this does show that the X5's head geometery is nearly ideal for flybarless relative to the Mikado reference.
The inner swash radius is roughly 22.75mm, the outer swash radius is roughly 40.5mm, main grip radius is roughly 31mm. All measurements taken 90* to mainshaft.
Link to tool: http://www.vstabi.info/en/geometry
I'm also finding that an 13mm tail servo arm gives me CCW/CW of roughly 60/60. The swash servo arms will need to be in the 18 to 20mm range for vbar. Mine work well at 18mm.
The two captures show data for +/- 11 and 12* of pitch.
ID:	182376   Click image for larger version
Old 09-28-2010, 05:23 PM   #3 (permalink)
My setup:
Scorpion 4020-910kv
Stock ESC soon to be CC Ice 100amp
BLS451's on cyclic
BLS251 on tail
Mikado vbar 5.0 Std
FES head w/black dampers
Align 520 cf mains soon to be Edge 523's
Stock tail blades
I'm running +/- 12* of collective and 8* of cyclic at 2500 w/14t pinion. Performance is supurb! Nearly on par with my Logos with maybe a bit more pop. I am managing 5 minutes from 6s Turnigy 30c 3300's but performance at 4 minutes is certainly not what it is at 2 minutes. Gov mode on the stock esc did not help much. I'm confident that the Ice 100 and some new lipos will improve that significantly. I should have some 6s Hyperion 35c 4200's within the next week. I'll report my experiences thereafter.
My vbar 5.0 file is attached.
Old 09-28-2010, 07:01 PM   #4 (permalink)
Thanks for putting this up
I got my head conversion bits yesterday and now waiting for the rest to show up hopefully today. Will be ummm interesting as it's my first FBL adventure
Setup will be
Blue mini-v v5
BLS253/251
Nervous but excited at the same time
Vas
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx
GAUI
Field Rep, Team Empire Hobby
torana74 is offline        Reply With Quote Quick reply to this message
Old 09-29-2010, 04:30 AM   #5 (permalink)
X5 & beastX
Stock motor+ 15t
Stock ESC Governed at 67 & 72%
MKS DS 670 x3
MKS BLS980 on tail which is now dead so I use InoLab D261 (No joke)
On 67% gov I get 6min of smooth 3D Flying (mostly piro maneuvers)
On 72% I get 4 - 4:30 of hard flying.
eDeK is offline        Reply With Quote Quick reply to this message
Old 09-29-2010, 07:08 AM   #6 (permalink)
Gaui X5 FES = A GOOOOOOD TIME!!!
BeastX
Scorpion 4020-910KV
Stock ESC
BLS950's Cyclic @ 6V
DS650 Tail
Edge FBL 523mm Main Blades
KBDD 85mm Tail Blades
Red Dampeners
15t Pinion
4000mAH 30C Lipo's
6.30min Sport Flying & Light 3D
Tips:
The black dampeners work well with the standard blade sizes - 500mm. If you are going to use Edge 523mm Main Blades, install the red dampeners to minimise chance of a boom strike. (Advise from Gaui Team Pilot)
If you are experiencing a wobble on the skids, chances are your headspeed is too low for your pinion size and dampener type, so up your headspeed. (Ask me how I know)
Do not cable tie BeastX servo cables or keep them bunched up and cable tied in the airframe, resonance from the frame will be amplified down the wires and into the BeastX controller.
I got a longer Jesus Bolt, as the one supplied was just a little too short for my liking. (See last attachment - 5mm longer than the bolt supplied and a chunkier head)
ID:	182583   Click image for larger version
ID:	182584   Click image for larger version
ID:	182585   Click image for larger version
ID:	182586   Click image for larger version
ID:	182588   Click image for larger version
ID:	182589   Click image for larger version
ID:	182590   Click image for larger version
g-bru is offline        Reply With Quote Quick reply to this message
Old 09-29-2010, 07:17 AM   #7 (permalink)
Awesome pics G and super sweet /clean heli.
Very very nice
Vas
GAUI
Old 09-29-2010, 07:26 AM   #8 (permalink)
Very very nice
Vas
Thanks Vas!
How is your conversion coming along?
G.
Old 09-29-2010, 07:59 AM   #9 (permalink)
Originally Posted by g-bru View Post
Thanks Vas!
G.
Just got all the bits today after a few delays with customs. Is going to be a new build so am starting the frames as we speak. I'm excited
Vas
GAUI
Old 09-29-2010, 09:24 AM   #10 (permalink)
Please add lipos!!! ... and thanks!
Old 10-04-2010, 04:44 AM   #11 (permalink)
terrabit, just had a look at your file and a few questions.
Firstly noticed you have 0 servo trim.Did you level the swash via the links and got perfect 90 on the servo horns???
Also my collective and cyclic figures are different. I got 100 on the collective(gives me 13.5 up/12.9 down) which i'll tame in the tx. I think the difference is the trim i added to get the servos at 90. Cyclic i got 8 degrees at 95. Using the long balls though.
Just trying to understand how all the differences work and what the vbar software looks for.
Vas
GAUI
Old 10-08-2010, 07:07 AM   #12 (permalink)
well she's all set for the maiden tomorrow.....i think
Managed to squeeze all the wiring and step-down in, moved my receiver pack to the rear to help with balance. For some reason this one is ever so slightly nose heavy.
Weird as the newer canopies aren't as stiff / heavy as my first. First weighs in at 115g, the newer at 84g.But am running a CC Ice 100 which is heavier.Hyperion EX packs despite the numbers actually weighed in a few grams less than the CX.But did notice that with the batt/motor saver that my packs sit a little further forward than where i had originally placed.
Did the vib log thingie spin up(no blades) test and nothing major to report.No fiddling,no swash moving, all numbers low.
So we'll cross the fingers and see how we go with my first attempt at FBL.
Oh and have to take a family photo.I do really like the clean ,no flybar look.
Vas
GAUI
Old 10-08-2010, 11:03 AM   #13 (permalink)
Don't mention pictures and not post any Vas!
You're gonna love it dude, enjoy the maiden tomorrow and report back sharpish!
G.
Old 10-08-2010, 11:56 AM   #14 (permalink)
Vas
Hi Vas, sorry I didn't get back quicker.
I zeroed out the trim settings for the purpose of this thread. My actual trims are quite low at six and less. I tuned my collective for +/- 12* and 8* of cyclic. You can adjust for even +/- in the trim tab. Also, be sure to adjust the cyclic ring so you don't have any binding at max throws. The long balls may be fine. You just want the value entered under the cyclic tab to be between 80 and 110 at 8*.
I am anxious to hear your impressions. Please keep us posted!
Old 10-08-2010, 07:35 PM   #15 (permalink)
G.
G, i know, i know Just too excited last night and had to share
They will be coming
It all seemed to fall nicely within the green zones so will hopefully see this arvo.
Closing the shop now and heading to the field and fingers crossed all well. Have fitted the LE motor to this so should be ummmmmm interesting
Vas
GAUI
Old 10-09-2010, 06:26 AM   #16 (permalink)
raving success. and yes FBL is awesome. Only had one real soft optimising flight today but after a min or so getting used to the different feeling i must admit i love it. Just really wish i didn't forget the other packs at home
Vas
GAUI
Old 10-26-2010, 01:15 PM   #17 (permalink)
What damper rubbers are you guys using? The softer or the harder red ones?
Gaui X5 - BeastX
Gaui 330X-S
Futaba 8FG
johan84 is offline        Reply With Quote Quick reply to this message
Old 10-26-2010, 01:29 PM   #18 (permalink)
I run the softers.
Old 10-26-2010, 05:58 PM   #19 (permalink)
I run the harder red dampeners for Edge 523 blades, if you are running stock 500 blades then the black dampeners are fine.
G
TDR3DRigid Mikado V-Bar 5.1
Futaba8FG S-Bus
Old 10-26-2010, 08:15 PM   #20 (permalink)
I think it depends on what headspeed you want to run. If you are running high headspeed, the harder red dampers would be best. If you are running lower headspeed then the softer black dampers might better. I am running the soft dampers at around 2500 with good results.
