Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 01-25-2011, 01:32 PM   #1 (permalink)
Default Velocity 90 Questions
hello friendly HF's...i've got a Velocity 90 to build when i get back to singapore in early April (currently in the states for a bussiness trip)...i'm kinda torn between somethings on what i should install in my new 90 heli...
1) Beastx Ver 2 or V-Bar 5.0?
2) Which muffler for my engine OS 91 HZ-R?
Also if you guys have some tips before i start will be much appreaciated...cheersss all
Gravity Always Wins
mahathyr is offline        Reply With Quote Quick reply to this message
Old 01-25-2011, 03:17 PM   #2 (permalink)
for the Beast X or the Vbar...both are great...I run the Beast X in one of my 550's, the Vbar in my other 550.
The Beast X I love because you don't need a computer to set up and if flys great right out of the box with no tinkering.
The Vbar...well...what can you say...it is a Vbar...they have set the standard for FBL units for many years.
I have a Total G in both my V50 and V90 because of the built in governor...but plan on changing out the Total G on my V90 once Vbar releases their governor upgrade to see how the governor update works on the V90
These days...all of the FBL units fly very well...I have been flying testing the following units for quite a while now...and all fly great! some take a little more tinkering than others...but fly great...
Skookum 720: Trex 700E, Bergen Turbine, HC500
Total G: Velocity 50 and Velocity 90
Beast X: Outrage 550
Mini-Vbar 5.0: Outrage 550
Standard Vbar 5.0: Gaui X5
Helicommand HC3xtreme: Going into Fusion 50
If you want a good unit for good price...Hard to Beat the Beast X at $220 or so...but I have no experience with it in a Nitro...Standard VBar is proven in Nitro's...
Greg Alderman
Warehouse/ Facilities Manager
greg@helidirect.com
Greg Alderman is offline        Reply With Quote Quick reply to this message
Old 01-25-2011, 03:25 PM   #3 (permalink)
Hi,
cant tell you nothing about FBL units. I still love flybar!
And I have the YS91srs installed, so for the mufller I dont know.
but I just finished my velocity90. Well still have to fit all the electronics. its the kit with the updated parts.
Everything is straight forward. Easy to build.
Some things I came across:
-starter adapter: I was unable to fit that one. couldnt fit one screw. (it was replace with the one from the first kits (setscrew version). Now its fine.
-the ball links are terribly strong to fit onto the balls and even harder to fit onto the linkage rod. Solution: heat the linkage rod and then screw the ball link onto it. or use a screw to cut the thread first.
-make sure to clean all the screws and parts with some alcohol or so....They still have some machining oil or whatever on them. If you dont clean it, loctite will fail.
-almost all of the 2mm*5mm screws shared off. And I havent overtightened them, really I was very careful. They are VERY soft. I replaced all of them in the meanwhile.
-my bevel gear in the front tail gearbox had quite some play forward and backward. check, that the teeth have good contact all the time. I fixed it with some washers I fittet in front of the first bearing thats beeing pushed up the bevel gear B...
-when fitting the tail rotor assembly to the boom: make sure the tail pitch slider moves freely. check after each screw.
-factory assebled stuff: take apart everything and check for loctite and tight fit of the screws. I found many screws, that were not tighened enough or didnt have locite on them.
Well I think thats about the things I came across during my build. Biggest thing I didnt like was the play in the front tail gear box...Still have to talk to my dealer about this...
hope that helps...Have fun building your new bird!
cheers,
cyril
low.level.3d is offline        Reply With Quote Quick reply to this message
Old 01-25-2011, 03:33 PM   #4 (permalink)
The Capi
Here is a little shameless self promotion for my build thread, it covers most of the things that need to be tweaked on the 90 (minus the new tail shaft).
https://www.helifreak.com/showthread.php?t=240639
Old 01-25-2011, 06:20 PM   #5 (permalink)
If money is not an issue, go a full size V-Bar, the external sensor makes vibe issues on nitro helis just that little bit easier to deal with. And as has been mentioned they have been THE standard for a long time.
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote Quick reply to this message
Old 01-26-2011, 06:55 AM   #6 (permalink)
Thank you all for the kind tips and advice...90%likely this is gonna be my setup..
Velocity 90 FBL
Cyclic: Savox SH-1258TG
Rudder: Futaba BLS 251
FBL Unit: Full Size V-Bar 5.0
Engine: OS 91 HZ-R
Muffler: Outrage 91?
Throttle: Align DS-650
Regulator: Gryphon Extreme Regulator w/ Gryphon Auto Booster
Governor: Multigov Pro
Blades: Edge 713 or SAB 710 with Edge or Sab Tail Blades
Gravity Always Wins
Old 01-26-2011, 06:59 PM   #7 (permalink)
Dont worry about the multi-gov very soon the V-Bar will have its built in Gov available. Just hold off till them.
Dave
Old 01-26-2011, 07:16 PM   #8 (permalink)
yes i do know abt the v-bar having the gov update soon...but i have an extra multigov in my possesion so im just gonna use it but once the v-bar gov update is out im gonna try it and if its good i will use it and maybe sell the multi gov...thanks for the heads up...cheersss
Gravity Always Wins
