Hurricane 550 Discussion and support of the Gaui Hurricane 550 |
07-15-2015, 09:08 AM | #1 (permalink) |
It's Back! [CHP550]
Pretty excited about this build. I've had an itch for a 500mm bladed heli and I still have the CHP 550 frame set laying around. Was going to pick up a Goblin 500 or HDCell 500 but the CHP frameset has been calling me from the corner of my bench.
So I made some orders for some parts today. Main purpose of this build is narrow profile (CHP frame set is extremely narrow) and light weight. I want to keep the disc loading down as much as possible. Gaui550 FBL head (it's tall and considering some modification to shorten it). KBAR FBL unit (have had this on the shelf for a while now). Will be using Futaba 9650 servos with 9660 metal gears <-- was using these on my original CHP 500 rig (after an Align DS510 stripped). Hyperion 4020-910kv motor ($45 on ebay). Yep 120A ESC or CC80A ESC. Still need a BEC. KBDD 515mm FBL blades ($37 2nd's on ebay). Lynx 82mm tail blades. Align 550/600 TT tail assembly. Align 550/600 tail shaft (converting to belt using TT tail box). Trex550 boom (or G550 boom). 550 belt 65c 6s 3600 packs (new). Making a set of boom mounts to accept an Align 550/600 boom so I can use a TREX600(NSP) tail. Very small clearance between the frames and boom but it should fit in there. If that doesn't work I will make a shim for the Gaui550 boom to fit the trex 600 tail. Currently requires 1 layer of electrical tape for a nice fit so it won't take much. Going to try something fun for landing skids (not as pictured below). Going to try something fun for the canopy as well. Original build pics here: https://www.helifreak.com/album.php?albumid=830
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 - Last edited by JaggedEdge; 07-16-2015 at 03:08 PM.. |
07-16-2015, 08:39 AM | #2 (permalink) |
I should have realized that this place is a ghost town now.
Will continue this thread! So this is what I'll be tackling today. Align 550/600 booms are .850 OD. Gaui Boom mount has just .050 clearance on each side between the frames. After removing .025 on the diameter there will be .0125 less material at each side where the part is at its thinnest. I'm think about making a 1 piece boom mount 1.5" long to keep everything solid.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 - |
07-16-2015, 09:57 AM | #3 (permalink) |
CAD version of the boom mount.
Looks like the 550/600 booms will fit between frames.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 - Last edited by JaggedEdge; 07-16-2015 at 11:22 AM.. |
07-16-2015, 10:19 AM | #4 (permalink) |
Got the bearings and TT gear out of the tail box.
Plenty of room for the belt.
07-16-2015, 12:58 PM | #5 (permalink) |
Drawing of the part.
Have to double check bolt hole location and then I should have this made in 20 minutes.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 - Last edited by JaggedEdge; 07-20-2015 at 07:31 AM.. |
07-16-2015, 02:52 PM | #6 (permalink) |
.850 boom block done.
07-16-2015, 06:10 PM | #7 (permalink) | |
HF MR Support
Still Here!
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1 AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD |
07-16-2015, 06:53 PM | #8 (permalink) |
Hi! Good to see you!
Wonder who else will swing by go say hi....
07-16-2015, 07:40 PM | #9 (permalink) |
HF MR Support
Looking like that will be a great flyer! I have the Head Hunter frame, but still run a flybar (600) Remember, X5 booms (TT) are the same as the 550 grey booms...
07-16-2015, 07:50 PM | #10 (permalink) |
The rotorstar 120A is on sale for $70 and it's the same as the yep 120,if you don't have one.
07-17-2015, 09:54 AM | #11 (permalink) |
Thanks! I have a YEP and the CC80.
The YEP 120 might be a bit large for these frames.
07-18-2015, 02:00 AM | #12 (permalink) |
Looks like a fun project, good luck with the build.
I remember when I bought my first Hurricane 550 back in 2008, this was a busy place. Dozens of guys posting here every day. I miss those days, but still have a half a dozen Hurricanes from a 200 to a 550, all still flybar'd....
I don't need the latest and greatest. I just need more time to fly what I have. Align 450 Sport V2, Gaui 200, Gaui 425 x 2, "HeadHunter 500, Gaui 550, all Flybar'd |
07-18-2015, 02:35 AM | #13 (permalink) |
Thats awesome man, what tools are you using to machine your parts?
please continue |
07-18-2015, 03:48 AM | #14 (permalink) | |
There's not been enough abuse around these parts recently |
07-18-2015, 03:39 PM | #15 (permalink) |
HF MR Support
...Let us see...Me thinks I know of a Gaui in a TREE, STILL !!LOL
07-18-2015, 04:52 PM | #16 (permalink) |
At least none of mine are out swinging in the trees.
07-19-2015, 12:47 AM | #17 (permalink) |
still ... still swinging there !
his is the only flying mashine I know that didn´t come down ... worth for the Guinnes Book of Records perhaps
Jörg * fly fast - live slow * |
07-19-2015, 03:47 AM | #18 (permalink) |
Don't feel too bad Mike, if that tree grows tall enough, your Hurri can R.I.P. in Heaven some day.
07-19-2015, 04:46 AM | #19 (permalink) |
I might have to go back and see if it is still up there - must be some kind of record if it is
07-19-2015, 07:07 AM | #20 (permalink) |
Ahh that's the g550 forum I remember.
definitely shortening the head this week. will look into blade to boom clearance. These kbdd blades are beautiful. I can't find a single blemish. Will be buying more.
