500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
07-13-2015, 10:44 PM | #1 (permalink) |
weirdest crash ever today.
OK...this I gotta tell
today I had the weirdest, highest altitude, hardest ever, on the hardest surface ever - asphalt, it was the most noise making, yet cheapest crash I have ever had in 35 years flying RC and 14 with helis... Cost of the crash? NOTHING!!!! absolutely nothing...not even a scratch! I swear this is true and I can't explain it...no one will believe this. as a beater/practice heli, I use a Trex 500L with a Kobi 90, Scorpion 3226-1600KV, on a 13T pinion,Scorpion HK-3226-1600 and BK servos, running on 6S 3300mAh, with an WR BEC, and all controlled by a Spartan VX1n FBL. My second flight of the day...went up vertical, really really high inverted and hit TH.. started the auto down really fast, rotated it back out of inverted and for no reason whatsoever decided to flip it back out of TH to do it again... the motor didn't start....so instead of continuing the AR down, letting pitch gain head speed, in my surprise and awe for what had just happened, I started flipping the damn switches instead, moved TH 3 or 4 times and tried Idle 0, 1 and 2, and out of the blue...with all the time I lost fiddling with the switches, the blades simply stopped!! The heli was some 80 feet high in the air and with no blades spinning came down faster than a turd out of a tall dog's ass!! BANG on the runway asphalt...I could see it came down perfectly square on the landing gears so I figured..that one will cost some money and time to fix it...it fell so far I drove there! When I get there, I see the heli on its side, the first impression was weird..no parts scattered all over...the blades were both pointing back and both with weird pitch angles, so I figured..broken linkages etc.. Picked it up and looked at the canopy on all sides, and it doesn't even have a scratch!! looked around, no parts, the pitch links were off from the blades, but both on the swashplate...so I put them back on...looked at the tail..nothing..not even a scratch in the blades or on the fin... so I tried to see if it worked, connected the battery and radio, and it flew!! as good as it did before the crash, and even did 3 or 4 more AR like the one I was doing... now...why the Koby did not engage, I have no idea, but it worls fine..but the awe...is the crash from an 80 feet height, broke nothing... BTW...I use Gorilla gears and thee never break, so not even a bent skid pipe!! do you believe this?? Its true, I have to say, Align does make a sturdy helicopter... Kind regards Alex |
07-13-2015, 10:54 PM | #2 (permalink) |
Nosir, I don't believe it.
Trex 500e dfc ar7200,mcpx v2, Dx9, Goblin 630 yee haa |
07-13-2015, 11:05 PM | #3 (permalink) |
would I come here and post a post like this just to lie? I have better things to do
07-13-2015, 11:17 PM | #4 (permalink) |
I would have liked to have seen something like that. Might have even paid money.
Blade mcx2 / msrx / 120sr / nano qx / nano cpx |
07-13-2015, 11:43 PM | #5 (permalink) | |
Actually now that I looked better, there is some damage, but nothing serious...I did not see this when I flew it today...I did notice that that battery had come off the slides... with the impact the battery actually bent a bit, and in the area where the velcro strap secures it dented the battery, and on one side ripped the heat shrink.. I inspected it, charged it and measured it just now and all is good. These batteries on my beaters don't last long anyway... ohh and one of the blades does have a scratch...dang...there goes my story. ohh and one of the blades does have a scratch...dang...there goes my story. |
07-14-2015, 08:50 AM | #6 (permalink) |
It slipped thru one of the black holes floating around in Europe created by the CERN.....
Obviously rx signals are shunted in em too.....
Reach farther... |
07-14-2015, 08:55 AM | #7 (permalink) |
Noticed your flying FB blades on a FBL.....
Reach farther... |
07-14-2015, 07:02 PM | #10 (permalink) |
Is this April 1st.?
Mini Protos 3x HS5065mg, AR7200BX, JR290 Trex 500ESP Robird, Oxy 2, OXY 3, Oxy 4 All on Dx8G2 AMA 732104 |
07-15-2015, 04:15 PM | #11 (permalink) |
I have had a similar incident on my blade 500 3d two summers ago. I fly up on a bank, and my heli briefly drifted out of sight over the bank during an inverted nose dive. I hit TH, gave full negative and pitch forward.
I see my blade 500 floating back up into view over the bank! It's fully upright! I re-engage the throttle to regain some power, but this thing barely has enough power to autorotate safely, and it makes it 60 ft away, landing upright in a dried out swamp! Same thing, no damage or anything. My trex 500 on the other hand, it blows up every 30 flights. It's been nothing but headache for me.
Nano CPX x2, MCPX BL, HP05 MCPX(retired), 130x, Trex 250 SE(retired), Blade 300x, Trex 450 SA, Blade 450x, Trex 450 PRO, HK500 CMT(retired), Blade 500 3D, Assault 700 DFC |
07-15-2015, 05:10 PM | #12 (permalink) | |
what do you mean they blow? I have been flying them (almost daily for the last 3 years, 2 to 4 packs each time) for practice for a while now and had never had one blow on me. what do you mean please? Kind regards Alex |
07-17-2015, 07:45 PM | #13 (permalink) |
Go up to the top of a four story building. Leave the blade carrier on, attach your flight pack, put the canopy on, and throw the heli over the edge. Report back if theres no damage. That or your idea of 80 feet is grossly mistaken.
07-18-2015, 01:50 PM | #14 (permalink) |
You know right kind of wind conditions - the kiting effect may take just enough energy out - if stars, moon, and everything is aligned right.....
Its kinda like when that Great White takes a bite - its the luck of the draw whether he just gets a bite of the board - or well - you know......
Reach farther... |
07-18-2015, 11:11 PM | #15 (permalink) |
By blow up, I mean the tail hub throws a blade grip. At first this was happening with the ESP tail and gears, so I switched to pro tail case/ gears.
