700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
06-25-2012, 06:23 PM | #81 (permalink) |
According to the Align website, If I buy the combo with the HV servos I need a Lipo 2s 1900-2300 . and then:
What 2s lipo 1900 - 2300 would you recommend? As would be the connection? I do not want to be plugging and unplugging the battery from the FBL unit Anyone have photos or a diagram of how to use. Thanks in advance
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo |
06-25-2012, 09:24 PM | #82 (permalink) | |
Personally, I like the separate 2S pack, cause you can charge it once and fly your electronics most of the day. A 2S 2600mAh or 3600mAh and even 5000mAh battery will serve you well. Pulse batteries, NRG Outrage or Proggressive RC's Spyder batteries are all great choices. Hope this helps you.
At the precipice, we change! Team GrandRC |
06-25-2012, 09:59 PM | #83 (permalink) | |
06-25-2012, 10:36 PM | #84 (permalink) |
FYI, I'm running the Align HV servos, and at 8.4V I can get my vBar to brown out. At 6V it's stable. So at this time I would only recommend a 2s LiPo and not a BEC in the 700e DFC if you want to run HV to the servos.
I was using a WR Hercules Super BEC (the $100 14s one). |
06-26-2012, 01:16 PM | #85 (permalink) |
how i connect the 2s lipo battery in the rx ? I do not want to be plugging and unplugging the battery from the rx.
06-26-2012, 03:57 PM | #86 (permalink) | |
http://www.spektrumrc.com/Products/D...ProdID=SPM9532
06-26-2012, 06:53 PM | #87 (permalink) | |
Synergy E7, Vbar 5 Pro, BLS255 & 256HV, Hacker Turnado 530 Edition, Rail 716, CC120, WR Sup BEC, Scorp BUG | Trex 450L, Vbar Pro, MKS 8910A+ on tail, Talon 35 | Futaba 18mz |
06-26-2012, 07:18 PM | #88 (permalink) |
Why is it called DFC HV?
Newbie at this game...somewhat... Current "air force": new Raptor 50 SE, Damaged and forsaken Blade SR, and CX2,CX3 in working condition . |
06-26-2012, 07:22 PM | #89 (permalink) |
This is a common misconception for servos. The higher the voltage to a servo motor, the faster it moves, the more torque it generates and therefore the more current it consumes. If the output power remained a constant, then this would be true. But instead it increases dramatically with voltage.
06-26-2012, 07:23 PM | #90 (permalink) |
It comes with the considerably more expensive HV servos.
06-28-2012, 06:32 AM | #91 (permalink) |
First video I found, any other?
[ame]http://www.youtube.com/watch?v=wUF_vcrWt3Q[/ame]
Looks sweet, the flight is not so good though. |
06-28-2012, 08:04 AM | #93 (permalink) | |
yes, yes I don't like Tareq either . |
06-28-2012, 09:16 AM | #94 (permalink) |
What about resolution guys. I am very conserned being not optimal for a CGY750, V-Bar or other units than the 3GX. Any information about that?
If someone can convince me about that I will buy one. Otherwise I will probably go for a GAUI X7 this time.
T-Rex 500E - JIVE 80+ LV + MINIPYRO 20-08 / BLS153 / CGY750 / BLS251 T-Rex 550E DFC - JIVE 100+ LV + PYRO 600-12 / DS610 / V-Bar / BLS251 T-Rex 700E DFC - ICE2 HV 120 + 750MX / BL700H / CGY750 / BL750H |
06-28-2012, 09:24 AM | #95 (permalink) |
The resolution is OK because the new swashplate comes with two ball-link positions.
06-28-2012, 09:44 AM | #96 (permalink) | |
And like previously mentioned: use the inner hole on the swash. Other option would be the extended grip arms from KDE: http://www.kdedirect.com/TREX700MRHAXT.html Tim
Certified Flight Instructor |
06-28-2012, 09:47 AM | #97 (permalink) |
Hobby Hut secured a small amount of 700V3 kits get them now.
http://www.hobbyhut.com/T_REX_700E_D...p/kx018e15.htm |
06-28-2012, 11:19 AM | #98 (permalink) |
Arghhhhh. I want this to be my 1st 700 bird so badly. No funds though.
How much is one kidney in the black market nowadays . |
06-29-2012, 07:17 AM | #99 (permalink) | ||
