X5 Discussion and support of the Gaui X5 |
10-14-2011, 07:22 PM | #1 (permalink) |
GAUI X5 Battery Database
Ive decided to start a X5 battery database. Ive quickly gone through a few posts to grab the most common batteries to start the ball rolling..
Batteries are to be 3800mah or larger. Please advise if battery fits with or without battery fence/frame stiffener. Please keep the thread for database updates, amending errors ...etc. Any suggestions on formatting or additional information that should be collated please let me know.. -------------------------------------------------------------------------------------------------------------------- X5 Batteries ------------------------------------------------------------------------------------------------------------------- Fit with no modifications (* = No battery fence fitted) Name............................................. Dimensions(mm).......Weight(g) Voltz 4200mah/35C.........................134 x 44 x 49...............601g Hyperion 4200mah/35C..................135.5 x 39.2 x 54.7.... .666g Turnigy 4000mah/30C....................143 x 48 x 43................653g* GensAce 4000mah/25C.................140.5 x 43.3 x 52.8.......658g Hacker Topfuel 3800mah/30C........133 x 43 x 57................690g Kongpower 4200mah/35C..............134 x 44 x 50...............644g SkyLipo 4400mah/40C...................136 x 42 x 53................632g ProTek 4200mah/45C.....................140 x 46 x 54...............672g OptiPower 4300mah/30C................138 x 44 x 56...............680g Turnigy 4000mah/20C.....................148 x 49 x 40...............650g (Tight fit) Zippy 4500mah/30C........................149 x 50 x 48..............752g DYMOND ZP-5000mah/45C............134 x 47 x 64..............762g* Spyder 4000mah/30C.....................137 x 42 x 51..............610g Spyder 5300mah/30C.....................135 x 62 x 42..............716g Kypom 4200mah/35C.....................134 x 49 x 44...............601g Not confirmed Zippy Flightmax 4000mah/40C.......147 x 50 x 44................690g Voltz 4500mah/45C........................146 x 49 x 48...............708g Thunderpower 3850mah/45C.........136 x 49 x 44...............607g Thunderpower 3850mah/65C.........136 x 49 x 44...............620g Turnigy Nano-tech 4000mah/45C...163 x 50 x 42...............684g* Last edited by nexgen; 12-08-2011 at 09:02 PM.. Reason: added Spyder |
10-14-2011, 07:50 PM | #2 (permalink) |
Geffect, this is a great Idea. This is one of those questions that I see coming up over and over. If others like the idea I will stick it.
Gaui 200 •Gaui 550 •Gaui X5 BeastX Castle Scorpion Hyperion Spektrum JR The Front Porch, Nexgens Lounge |
10-14-2011, 08:10 PM | #3 (permalink) |
+1
However, I don't understand how you can fit a Turnigy nano under there. They are 163mm long!!! I can barely fit the regular 30c 4000mah packs and they're only 143mm. I don't use the battery fence.
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all AMA #934662 |
10-14-2011, 08:29 PM | #4 (permalink) | |
10-14-2011, 08:32 PM | #5 (permalink) | |
I can vouch for the Voltz... they fit without strain at all... perfect pack for this bird...in size at least...mine is starting to puff a little after each flight (only have 50 cycles on it so far).
10-14-2011, 09:11 PM | #6 (permalink) |
ive moved the Nanotech 4000/45 to the "not confirmed" list.
10-15-2011, 12:52 AM | #7 (permalink) |
blue turnigy 4000 mah 40c does not fit with the battery fence
XLPower Specter V2 - Rotorflight - ELRS OMP M2 Explore - Rotorflight - ELRS TX: Fr-Sky X9 Lite S / RM Pocket - EdgeTX - ELRS |
10-15-2011, 02:20 AM | #9 (permalink) |
I don't know if anyone uses ProTek liPos. But I have one before: 4200mah 45C 6S for my X5 with battery Fence and it fits just right with a little more room at the nose end of the canopy:
For more details and dimension: http://www.amainhobbies.com/product_...k-222V-4200mAh Hope it helps. |
10-15-2011, 02:47 AM | #10 (permalink) | |
Added to the list. Thanks.. |
10-15-2011, 05:00 AM | #11 (permalink) |
Many thank's for that Geffect,well done you,your's Marty.
10-15-2011, 05:24 AM | #12 (permalink) |
Terrific thread. Thanks heaps
Sticky please The Hyperion 4200 Vx and Ex fit with the batt fence installed Vas
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx GAUI Field Rep, Team Empire Hobby |
10-15-2011, 09:32 AM | #14 (permalink) |
never tried, don't have the batteries anymore. I run gens ace now.
10-15-2011, 09:46 AM | #15 (permalink) |
OptiPower 4300mAh packs fit with or without fence.
I added them to the first post and made this thread a sticky G, I also did a little formatting to make it easier to read, if you dont like it go ahead and let me know.
10-15-2011, 03:20 PM | #16 (permalink) |
GensAce 3300 25C
Turnigy 4000 20C (tight fit) both fit with fence Turnigy 4500 25C without fence, really tight fit but fits
www.flyfreak.net - Croatian RC forum |
10-15-2011, 06:37 PM | #18 (permalink) | |
Ive added the Turnigy 4000/20c to the list. The Genace 3300/25 is a bit small for the X5, so it wont be added. I couldnt find any details for the Turnigy 4500/25C.. There is a Turnigy Nano-tech 4500/25C listed on Hobbykings website.. Please confirm if its Turnigy (Blue) or the new Turnigy Nano Tech series. Cheers G-effect. |
10-16-2011, 02:09 PM | #19 (permalink) |
Uh, sorry my bad.
They are Zippy 4500 30C http://www.hobbyking.com/hobbyking/s...idProduct=9992 Surprisingly CG is ok with them....
10-16-2011, 10:35 PM | #20 (permalink) | |
Cheers G |
