Old 08-29-2015, 08:03 PM   #1 (permalink)
Default Blue flashing light when flying?
I have a beast x with about 100 flights on it. Last week when I was in the air the helicopter started pirouetting almost like the tail servo went out and was stuck in a hard left rudder position.
I rebuilt the helicopter and after it initializes, there remains a blue flashing light. It hovers fine, but I'm afraid to take it up since I'm not sure what this means. I'm familiar with bx as I have 3 helix with them. Can someone help?
frankiexp2 is offline        Reply With Quote Quick reply to this message
Old 08-29-2015, 08:06 PM   #2 (permalink)
This you REDO all the Settings on the Beast?? ALL of them?? That's where I would start. Setup from Scratch .. that always works for me.
DJI MIni, XK K110 120, previously Protos 500, Goblin 570/700.
HarryR is offline        Reply With Quote Quick reply to this message
Old 08-31-2015, 04:26 AM   #3 (permalink)
Hi,
when the Status LED flashes during operation (blue or purple, depending of tail gyro mode) the system did perform a soft reset during operation. This can be due to power glitches, i.e. voltage drops below 3.5 Volts for an instant of a second or due to static discharge. maybe this happens when your servos move for the first time at startup. Please check your power supply and voltage level under load. Also you may disconnect the servos and check if it the LED flashes w/o servos, or with 1, 2, 3 or 4 servos only. Maybe you have some defective servo!?
best regards from Germany
Stefan
BEASTX r&d Team
freakware.com
Frenchdress is offline        Reply With Quote Quick reply to this message
Old 08-31-2015, 06:54 AM   #4 (permalink)
Thanks for the info. Will try all of the above and report back!
Old 09-01-2015, 01:59 PM   #5 (permalink)
Turned out to be a faulty be in the esc. Went to an external and works great!
Old 09-01-2015, 02:00 PM   #6 (permalink)
Turned out to be a faulty be in the esc. Went to an external and all is working great!
Old 09-01-2015, 02:01 PM   #7 (permalink)
It turned out to be a faulty bec in the ESC. I went to an external bec and it works perfectly.
