Old 06-07-2012, 02:05 AM   #161 (permalink)
Originally Posted by Waff View Post
Jason, I agree with what these guys are saying. If you are using Auto Rotate feature and followed the instructions to the end, then you should have a Flight Mode 0 (Flight Mode Normal) throttle setting of all zeros. You do not have this. You have straight 30.
I did not like having FM0 set to straight 0 because if you accidentally switch to FM0 during flight, you are going down!
Waff
Of course you are correct, I had reset the FM0 back to the Castle recommendation of 30 flat immediately after your last instruction.
I tried 0, 30,30,30,30 and that worked, but thought I read another post around here talking about moving the 0 throttle pulse to a different switch. I found the post and now have my arming pulse (actually Throttle Cut set to 0%) on the trainer button. So, Yay, don't have to bugger up a Flight mode to arm this combo, and I don't have to worry about going to FM0 in flight.
Thanks guys, Bitchin' help!
Gaui 425, Scorpion -1600, Gaui 100A ESC, GP750, Spectrum servos Radian Pro!
Blade mCPX, Blade mSRX, Blade mQX, Blade 450X
DX7, DX8
Jasong911 is offline        Reply With Quote Quick reply to this message
Old 08-28-2012, 09:41 AM   #162 (permalink)
Just thought id give a big thanks to Waff for this. I followed the instructions at first, but had the same problem with no initialization after removing the batt with TH set to 22 for Auto Bailout. Thanks for clearing that up guys.
Using the DX6i and arming the ESC by pressing Throttle Cut, that way i can still keep Normal and IU with flat curves. Fantastic Tip!
One thing if note is make sure you set your Auto Bailout feature, you want to raise the headspeed change speed up, as the default 5 is way too slow.
MSH PRÔTOS
Rave Ballistic 635
Spunjah413 is offline        Reply With Quote Quick reply to this message
Old 08-29-2012, 06:50 AM   #163 (permalink)
Excellent! Glad it worked out for you!
Waff
Waff is offline        Reply With Quote Quick reply to this message
Old 03-24-2013, 12:43 AM   #164 (permalink)
Hi,i just got a cc 50a lite.Is it possible to calibrate the throttle, in a rc plane i have lying around with ar500 rx then transfer the cc lite to the 450x. Without problems?Thankyou
Pappy1 is offline        Reply With Quote Quick reply to this message
Old 03-27-2013, 05:06 PM   #165 (permalink)
Default AR7200BX and CC Ice Lite can't calibrate.
I would follow the instructions but I don't think it will be bad to do what you are saying. Remove mains and tails till its all set up
________________
Naked & Afraid
whippo is offline        Reply With Quote Quick reply to this message
