Go Back   HeliFreak > R/C Electronics Support > bavarianDEMON/HeliCommand
bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support
Old 04-03-2015, 06:09 PM   #1 (permalink)
Default A few set up issues
First time setting up the BD3SX. This is my set up
Goblin 500
BK 5001 BK 7005 servos
YGE 120LV
Spektrum DSMX satellites x 2
DX8 radio
Up to this point, everything has been going as is should......bound, all stick movements correspond to the bar movements and I have 100% in all directions, servos trimmed.
Then I get to the mixer tab!
Choose the proper mounting orientation (upright and front), rotation (right) swash type (tri 120). Write, next.
Servo direction is correct. Write, next.
Setting cyclic and collective . I can move the sliders, but it has no effect on my gage (Soko). I also noticed that the sliders are grey instead of what I'm assuming should be red. I need help! Thanks!
jbobb1 is offline        Reply With Quote Quick reply to this message
Old 04-03-2015, 07:57 PM   #2 (permalink)
Its been a while since I have set mine up. But I remember I had to hit write everytime I moved a slider for swash leveling and setting collective.
Blade 400 hs-65hb, Spartan Quark, Ino-lab Hg-d261hb dimension sport BEC Steath blades
MSH Protos 500 Futaba 9650, Bavarian Demon 3x, MKS ds760p
Logo 600se, 12s , kontronic Pyro, 80 hv, Spartan nano
refused is offline        Reply With Quote Quick reply to this message
Old 04-03-2015, 08:20 PM   #3 (permalink)
Hi, the cyclic and collective sliders change the overall range of movement available when you increase or decrease the pitch . I think you will notice the difference when you move the TX stick - not sure if the servos move when moving the sliders. My T rex 550 has 80 on the collective slider and 70 on both the aileron and elevator sliders. Leave collective offset at 0. The sliders are grey, not red!!
You need to test fly after setting the tail gyro and rigid tabs to make sure your tail and head gains are correct. Once these are done, you can set the levelling and rescue modes in the Horizon tab. There are people on Helifreak more experienced than me so I'm sure someone will chime in to help. I have set up the 3SX on 3 models and I also have the DX8 so I'm happy to help.
You might have some confusion when you do the self levelling and rescue setup. If you do, just pop back and one of us will be happy to assist. Once you are set up, you will love the 3SX. It will pay for itself in no time. The Self levelling and rescue are all on the same channel - just different gain settings. Good luck.
EDIT: refused, the swash levelling and servo set up is done in the TRIM tab, the collective range is set in the Mixer. jbobb1, you can always come back to any tab after you have gone through the wizzard.
T REX 550E, Logo 550, T Rex 700, T REX 470L, TB40. Spektrum DX9. Microbeast Plus. Mikado VControl
tonycopter is offline        Reply With Quote Quick reply to this message
Old 04-03-2015, 08:44 PM   #4 (permalink)
You nailed it refused! It just didn't kick about having to click write with each change. Thank you!
Old 04-03-2015, 09:16 PM   #5 (permalink)
Anytime you make a change you see the equal sign become "not equal", meaning the settings in the software don't agree with what's in the BD itself; that's your visual indication to "write" it before disconnecting, and is pretty slick in operation, actually.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8
Skidpad is offline        Reply With Quote Quick reply to this message
Old 04-03-2015, 09:23 PM   #6 (permalink)
Just another little tip, you want to make sure your Dual Rates are set at 100 when looking to see how much deflection you get after setting the Aileron and Elevator limits. You can always lower the TX Rates later and/or add expo. However, I leave my rates at 100 and lower Agility to get comfortable max flip and roll rates. This gives the best control resolution. I also lower tail agility to get a comfortable max piro rate. You may find the piro rate is crazy fast with the default Tail agility setting.
My gassers will bog if I try to flip them too fast. Lowering the Agility until they flip without bogging is how I set them.
This is your brain on helicopters!
Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550X. Spirit or BD3SX
rhodesengr is offline        Reply With Quote Quick reply to this message
Old 04-03-2015, 09:29 PM   #7 (permalink)
I had it in my head that I could make all the necessary changes and see the results, then write it to the unit. You guys got me on the right track!
Old 04-03-2015, 09:43 PM   #8 (permalink)
Point taken about lowering the agility! Makes sense!
Dual rates are at 100%.
Next step is to read the Correct tuning sticky!
More questions to come, I'm sure!
Old 04-04-2015, 05:54 AM   #9 (permalink)
Sorry jbobb1, I didn't realise you weren't clicking "write" each time!! Now I feel like an idiot
But as you are using a DX8 and setting up a 500 size heli, I might still be able to help with your tranny settings
Old 04-04-2015, 07:27 AM   #10 (permalink)
Your not an idiot at all! You posted some very informative info, and I appreciate it. I'm pretty sure I'll be asking questions, so beware!
Old 05-21-2015, 01:33 AM   #11 (permalink)
on the other hand if I want mine to flip faster , raise the agility ?
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 05-21-2015, 10:46 AM   #12 (permalink)
yes. However, A while back I saw some posts saying they were increasing the agility and past a point, they were not getting faster flip/roll rates. In that case you might need to increase your cyclic limits. But then you have to make sure you are not getting excessive servo motion; hitting mechanical stops and such.
The cyclic, like the tail, can only move so far. That range can be used by the pilot to do maneuvers but the 3SX needs some range beyond what you use to maintain control.
If you are hovering in a strong wind, you are already using up some of your range. If on top of that you move your sticks for a hard maneuver and the 3SX has no more range to use, then you might get a momentary loss of control.
So just some things to keep in mind.
