Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Like Tree3Likes
Old 08-28-2012, 07:45 AM   #61 (permalink)
i do not see where you have went the wrong way.
bwijk is offline        Reply With Quote Quick reply to this message
Old 08-28-2012, 07:52 AM   #62 (permalink)
You are fine. The 130 is because scorpion doesn't offer a 120. HW120 is plenty for that 4035 motor.
As for servos, the align 610s are a proven solution.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 08-29-2012, 02:41 PM   #63 (permalink)
My Setup finished this Week
X7
Flight Style: sport, soft 3D
FBL System: beastX
Motor: Turnigy SK3 new wire 1,5mm (545kv)
Pinion: 10
Target Headspeed(s): 1550, 1850, 2200
ESC: Helijive 120HV
Governor: Jive
BEC: Jive 6V
RX Pack: none
Cyclic Servos:Futaba BLS 451
Tail Servo: Futaba BLS 251
Main Blades:Railblades 696
Tail Blades: Railblades 105
Lipos: SLS 5000
Olli
neotask is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 09:29 AM   #64 (permalink)
Default Help me on gaui x7 setup...
I planning to use scorpion hk111 4035 560kv with hobbywong 120a...is it ok for mild 3D flight (will learn hard 3d)..what pinion size should i go..
armscofield is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 04:51 PM   #65 (permalink)
Originally Posted by dantemcc View Post
Flight Style: Not even good enough to call it a style
FBL System: Sk540
Motor: Scorpion HKIII 4035-500
Pinion: 10 or 11
Target Headspeed(s): At least 2000
ESC: HW 120HV
Governor: .......
BEC: CC BEC PRO
RX Pack: 2s 2400
Cyclic Servos: DS610
Tail Servo: DS650
Main Blades: Edge 693
Tail Blades: Edge 105
I think i went wrong with the servo's and the esc. I see alot of pilots with 130hv or more. I see a couple with 120hv's. I'm not a good enough pilot to notice the difference in the ds610's and the HV servo's that are out, but in comparison, they seem to be a little weak.
All of your hardware is OK. My concers is "Flight Style: Not even good enough to call it a style" and "Target Headspeed(s): At least 2000". I myself is a pretty all right pilot and Im only using 1950 as maximum headspeed. Its enough for EVERYTHING exept VERY hard smack.
If you are fairly good 1800-1900 RPM is enough for all 3D maneuvers and F3C maneuvers as well. As a bonus you will get more flight time.
I dont know what is going on when beginners use 2200RPM on a 700 size machine when 1500-1600 is all they need to learn to hover.
IMO things are about to go totally bananas with all these RPM's.
Member of Team Gaui Denmark
pxpep is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 05:39 PM   #66 (permalink)
Since I've had mine for 4 months now I'm liking it real well since I've had it. It was my first FBL heli so i didnt throw her around to my skill level until i got familiar with her. But now she is nasty and thats the way uh huh uh huh i like it!
https://www.youtube.com/channel/UCVA...MiyWkC_3r0vjMw - Me And MineTv Coming to Youtube Winter 2015
dantemcc is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 07:59 PM   #67 (permalink)
X7
Flight Style: hard 3d
FBL System: ar7200bx
Motor: scorpion 4035-530
Pinion: 10
Target Headspeed(s): 1900
ESC: CC ICE2 120HV
Governor: CC
REG: SG reactor X2 (6.8v)
RX Pack: Team Great Hobbies 2200 35c 2s
Cyclic Servos: align ds615
Tail Servo: align ds655
Main Blades: edge 713
Tail Blades: edge 105mm se
Lipos: Gens Ace 3800 55C obviously 6s packs
Wow my setup is way different then u guys
1sickvibe50 is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 08:02 PM   #68 (permalink)
+1 I like the advice you are giving just would like to add I can do smack 3d on only 1900 headspace by running smaller packs and larger blades (713)
Old 01-11-2013, 07:53 AM   #69 (permalink)
4525-520 11t
bls 451 @8v 251@5v
vbar 5.2 pro
yge 160 xxtreme edition
vbar gov
Tp 6s 65c 5000s
2250hs
mild to hard 3d
edge 693se 105se
600 DFC HV
Pilot Brandon J.
bj660raptor is offline        Reply With Quote Quick reply to this message
Old 01-11-2013, 11:54 AM   #70 (permalink)
Default My Setup
Gaui X7
Flight Style: Smooth and Hard 3D
Cyclic Servos: MKS HBL950
Tail Servo: MKS HBL980
ESC: Heli Jive 120HV
Motor: 4525-520KV Ultimate
Pinion: 10T or 11T
Flyberless system: Vbar 5.3 Pro
Governor: Vbar
Edge SE 693 / Rail 696
Tail Blades: Rail 105/SAB 105
Batteries: Gens Ace 5000mAh 60C
NeL3D.com
Nelson Rodriguez is offline        Reply With Quote Quick reply to this message
Old 02-03-2013, 11:48 PM   #71 (permalink)
X7
Flight Style: 3D
FBL System: iKon
Motor: Scorpion 4525-520 ultimate
Pinion: 10/ 11
Target Headspeed(s): 2000, 2200
Pitch: 13 degrees
ESC: Scorpion 130 HV
Governor: Scorpion/ iKon
BEC: WR super herc (evaluating)
RX Pack: Pulse 2550 (back-up)
Cyclic Servos:Outrage 9180
Tail Servo: Outrage 9188
Main Blades:Edge SE 693
Lipos: Giant Power 5000 65c
New Head should be here Feb 11th 2013!
Upgraded Formula canopy
I noticed Pitch wasn't on there before. Would be great if the guys that already listed went back and added it...
jakozzz is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 02:06 AM   #72 (permalink)
X7
Flight Style: Sport/Learning 3D
FBL System: Mini Vbar
Motor: Scorpion 4035-500
Pinion: 10/ 11
Target Headspeed(s): 1950/2000
Pitch: 12 degrees
ESC: YGE 160
Governor: Vbar
BEC: WR super mini BEC G2
Batts: Gens Ace 6s 4000
Main Blades: Rotortech 690
Hoping to maiden this soon. Weather needs to cooperate
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 08:21 PM   #73 (permalink)
X7
Flying Style- Sport/mild 3D
Motor- 4035-500 added Gaui XL shaft
Pinion-11T
Upgraded main gear assembly
FBL - AR7200BX
ESC-CC 120HV
CC gov- 1900-2000-2100
Rec Pack- Spyder 2600 2s
Battery- Spyder 5300 6s x2
Cyclic- BLS255HV @ 8.4V
Tail- BLS256HV @ 8.4V
Collective = 12-/12+
Mains- Rail 696
Tail - Rail 105
Got about 6 flights on this heli ,and it is everything I thought it would be-- Africkinmazing!!!
Gaui X7, Synergy E5, Synergy N7, Goblin 700, Goblin 700C,Goblin 570,CGY 750 ,Goblin 380-Ikon,14SG
Lazybfarm is offline        Reply With Quote Quick reply to this message
Old 02-05-2013, 12:46 AM   #74 (permalink)
X7
Flight Style: 3D
FBL System: Mikado V-bar Blueline (Fullsize)
Motor: Scorpion 4530-300
Pinion: 10
Target Headspeed(s): 1800, 2050, 2250
Pitch: 14 degrees
ESC: TOM24
Governor: Castle
BEC: Gryphon Quasar HV Bec
RX Pack: N/A
Cyclic Servos: Futaba BLS253
Tail Servo: Futaba BLS251
Main Blades: Edge 713
Lipos: 4x Turnigy 6s 2450mAh 30C
Its a weapon.
Team Old Mate - He's a good bloke
timmytron is offline        Reply With Quote Quick reply to this message
Old 02-21-2013, 07:33 PM   #75 (permalink)
X7 / Formula head, formula canopy, upgraded one way
Flight Style: 3D
FBL System: Blueline VBar
Motor: Scorpion HK4525-520 w/ XL Shaft
Pinion: 11T
Target Headspeed(s): 2250
ESC: Scorpion Commander V 130A opto
Governor: scorpion
BEC: WR Super BEC
RX Pack: None
Cyclic Servos: MkS 950 @ 8.4v
Tail Servo: MKS 980 @ 8.4v
Main Blades: Mavrrik 710
Lipos: Gens Ace 5300 30C
Robert Ables
Gaui USA Team Pilot / Cyclone Blades
Scorpion Power Systems / MKS USA / Optipower / VP Racing Fuels / YS Engines
RobertAbles is offline        Reply With Quote Quick reply to this message
Old 02-24-2013, 09:08 PM   #76 (permalink)
Default X7
X7 / Formula head, stock canopy, upgraded one way is next
Flight Style: my attempts at 3D
FBL System: Older VBar
Motor: Scorpion HKIII 4035-500 w/ XL Shaft
Pinion: 11T
Target Headspeed(s): 2200
ESC: YGE 160 with heatsink
Governor: YGE
RX Pack: 2S 2550 Pulse
Cyclic Servos: Outrage Torq 9180, Tail Servo: Outrage Torq 9188@ 8.4v
Main Blades: Curtis V2 690
Lipos: Gens Ace 5300 45C
helitroll is offline        Reply With Quote Quick reply to this message
Old 03-29-2013, 04:39 AM   #77 (permalink)
Anyone using gaui x7 with align 750mx 530kv..what pinion you use?..10T or 11T..
Old 04-03-2013, 01:47 PM   #78 (permalink)
Got my setup re-done,
X7
FBL System: Vbar
Motor: Scorpion Ultimate
Pinion: 10
Target Headspeed(s): 1900/2000/2100
ESC: Scorpion 130V
Governor: Vbar
BEC: Gens ace 2s 1000mah lipo
Cyclic Servos:Torq 9180
Tail Servo: Torq 9188
Lipos: Gens ace 5300 30c
When i did my remaiden with the torqs the servo spline of my aleron servo broke of after 2,30 minutes. The only thing i was doing was tail in hoover and some pyro's with hard stops.
Dont know if some other pilots had this problem? But Helidirect is not responding to any of my emails.
Tangman is offline        Reply With Quote Quick reply to this message
Old 04-04-2013, 11:08 AM   #79 (permalink)
Updated Setup:
Flight Style: Fast Big Air / Smack 3D
FBL System: Mikado Full Size Silverline VBar 5.3 Pro
Motor: Scorpion 4525-520 Ultimate
Pinion: 11T
Target Headspeed(s): 2200-2330
ESC: Scorpion Commander VI 130A
Governor: Internal Governor Gains P-8 I-6
RX Pack: 2S Lipo 1300 Mah w/ Fromeco DC-Up
Cyclic Servos: Savox 2271 SG @ 8.4v
Tail Servo: Futaba BLS256HV @ 8.4
Main Blades: Spin 700mm Matte Black
Tail Blades: EDGE 105mm SE
Lipos: 2x 5000 Mah Scorpion 65C+ Competition Power Packs
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 04-04-2013, 07:59 PM   #80 (permalink)
changed my setup too but just voltage on rx
X7
Pinion: 10
ESC: CC ICE2 120HV
Governor: CC
REG: SG reactor X2 (5.8v)
(accidently unsubscribed to the thread and dunno how to subscribe without posting)
Gaui X7, JR Vibe 50, T-Rex 450, Blade 400, T-Rex 250, Blade mcpX
