Old 05-11-2011, 10:19 AM   #1 (permalink)
Red face Help with COPILOT II and trex 500 3g
Finally i have mi beatiful trex 500 3g and my new copilot II, so. now i need help to install it!!!
Theres no info how to install it, the wires conections, i don`t even know if it goes after o before the flybarless control unit!
Plaese help me
Sorry my poor english
Hi from Argentina!!
Airober is offline        Reply With Quote Quick reply to this message
Old 05-11-2011, 04:15 PM   #2 (permalink)
Hope Nightflyr will chime in, he is the innovator here.
RX -> CPII -> 3G -> Servos is generally how it suppose to go. The recommendation for sure will be to get the heli and 3G dialled in before even thinking CPII.
T-Rex600-ICE100,WR10ABEC,Scorp4025-1100+17T,Kasama head,QUK Swash CNC Tail,G-Force blocks,3152,DS760+BLS251,DX7+AR7000,FM.
Blade400
-CC ICE50,Scorp2221-8+12T,Sonix Head&Tail,5A BEC,HS65HB,Quark+3500G,AR7000,Align Carbon blades,TRex500 Skids,Flymentor.
pril250 is offline        Reply With Quote Quick reply to this message
Old 05-11-2011, 06:16 PM   #3 (permalink)
https://www.helifreak.com/showthread...ighlight=beast
I just installed a cp2 and beast x with nightflrs help, this might help a little
"You can always tell a pilot,but not much"
Gaui X 5 Phanthom 2
n6nev is offline        Reply With Quote Quick reply to this message
Old 05-11-2011, 08:32 PM   #4 (permalink)
As pril stated..
You need to get your machine flying well with the 3G alone before you attempt installing the CPII.
This is a step by step process, follow the path and you'll have a nice flying helicopter, try to take short cuts and most likely it will crash before you realize it.
One item of note, you might want to consider a high output BEC. you will be drawing higher power with the FBL.
JR9303 / JR9503 / Futaba10CHP
Old 05-14-2011, 05:28 PM   #5 (permalink)
Default CP II and Microbeast
Are there any posts that describe how to connect the co-pilot II and a microbeast.
rwpielet is offline        Reply With Quote Quick reply to this message
Old 05-14-2011, 07:21 PM   #6 (permalink)
the basics remain the same....
Rx>>>>CPII>>>>BeastX>>>>>Servos
One note of EXTREME caution
You need to ensure the path of each servo follows through start to finish, the way the BeastX instructions call out.
Old 05-19-2011, 03:12 PM   #7 (permalink)
I use setup for 3G device from this thread.
https://www.helifreak.com/showthread.php?t=292734
With a little adjustment the heli works fine.
Engaged the CPII, had to adjust the gain down to about 40 - 50.
Now, the interaction between 3G, CPII and me work perfectly.
OYLORE is offline        Reply With Quote Quick reply to this message
Old 05-19-2011, 06:04 PM   #8 (permalink)
Default Thanks!
i read all the post! thank you very much!! it help me a lot!
but, i need more information about the wire connections, so how do i connect the Receiber to CP 2 to Flybarless! i donīt understand the manual diagram!
Can you please take a pic or a drawing of the connection?
Thanks, Thanks!, Thanks!
Robert
ID:	228710   Click image for larger version
Old 05-20-2011, 02:29 PM   #9 (permalink)
Default photo of beast/CP2 wiring for rwpielet
You asked for it!!! go into the tx subtrim and put gear to gear for the on/off.. take off with the cp2 off, thats a must.. and auto trim to 0..........Larry
Gaui X 5 Phanthom 2
Old 05-23-2011, 07:06 PM   #10 (permalink)
Default Thanks man!!
Thank you!! very much!!
You're my god!
I think it`ll work thanks to your drawing.
Robert
