Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 10-25-2012, 07:43 AM   #41 (permalink)
Is it available in stores soon??
PeterW is offline        Reply With Quote Quick reply to this message
Old 10-26-2012, 11:44 AM   #42 (permalink)
As long as they have V1's in reasonable stock, I do not think they will be in such a hurry to run a production run of V2's.
Phil
MotorRotor is offline        Reply With Quote Quick reply to this message
Old 11-02-2012, 07:18 AM   #43 (permalink)
I've added the build videos for the tail boom, tail rotor, canopy, motor completion and fuel tank plumbing........almost done.
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 11-03-2012, 08:02 AM   #44 (permalink)
I love the looks of that new tail setup. We should be able to dig trenches all day and not bend or strip the tail system.
Mr.HillBilly is offline        Reply With Quote Quick reply to this message
Old 11-03-2012, 08:01 PM   #45 (permalink)
will the v1 be upgradable?
shihan is offline        Reply With Quote Quick reply to this message
Old 11-03-2012, 08:57 PM   #46 (permalink)
this was built using a V1 kit and replacing the V2 parts..........so yes
whether or not there would be an upgrade kit, can't answer that
Carey Shurley
Old 11-04-2012, 01:01 PM   #47 (permalink)
Your build is a truely enjoyable read! Well done Carey.
ngin is offline        Reply With Quote Quick reply to this message
Old 11-04-2012, 01:04 PM   #48 (permalink)
That is good to know. That means one can get the V1 now, as it is available and enjoy gasser flying. Then when the V2 is released hey can just do a simple upgrade....ditto for us who already have a V1.
I would think that Century would make a simple upgrade kit available.
Old 11-04-2012, 04:13 PM   #49 (permalink)
+1!!
Sent from my iPad by carrier pigeon
karl k is offline        Reply With Quote Quick reply to this message
Old 11-05-2012, 11:07 AM   #50 (permalink)
Carey, you are doing a FIRST CLASS job on this project. I am sure all of us following (note the number of hits) this build, find it very interesting. Two Thumbs UP.
Phil
Old 11-06-2012, 01:22 PM   #51 (permalink)
Wonderful build! I will definitely use this thread as a reference guide.
Thanks Carey!
madog is offline        Reply With Quote Quick reply to this message
Old 11-06-2012, 02:07 PM   #52 (permalink)
Thanks Carey!
Old 11-07-2012, 07:27 AM   #53 (permalink)
Default Maiden
Hi Carey, Nice build thread as always. Are you going to post maiden flight video?
foreignloren is offline        Reply With Quote Quick reply to this message
Old 11-07-2012, 11:30 AM   #54 (permalink)
yeah, might be a little bit, we have the Orlando Helicopter Blowout coming up and its consuming a lot of time
Carey Shurley
Old 12-28-2012, 02:33 PM   #55 (permalink)
Is the HWC carb manifold taller than the red BH Hansen one?
my carb eccentric is rubbing the G30 baseplate well before the carb is tightened down...
darksidedave is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 02:38 PM   #56 (permalink)
Is the HWC carb manifold taller than the Hansen red one?
The carb eccentric is rubbing on the G30 baseplate well before I can tighten the screws all the way...??
edit..double post because I didnt see the forume post approval screen first time
Old 12-29-2012, 07:44 PM   #57 (permalink)
doubt it, this one is 14mm edge to edge, this doesn't account for the recess on one side.
do you have both teflon spacers/gaskets installed (one between isolator and cylinder and one between isolator and carburetor?
Carey Shurley
Old 12-30-2012, 08:44 AM   #58 (permalink)
Smile
The hansen block measures 12mm, so that is part of the problem..
yes , I had both teflon gaskets in placeand the carb almost tighten down when the interference happens..
I think the easy fix is to cut away a bit of the eccentric and move forward with the build..I want to get a couple of 813 or 990 carbs anyway
thanks for the hwc block info
Old 12-31-2012, 01:24 AM   #59 (permalink)
After having read through the build about the g30 v2 and the whiplash which heli do you think would be better overall. In terms of durability(both from crash resistance and maintenance), simplicity, quality, and a good design. I don't have access to seeing the two different heli's in person so I am counting on getting good advice from here. Thanks
Trex 600n, A610's, Fut.9254, OS50, JR9303
JR Ergo 46, JR4735's, OS46FX
Trex 450P, A410's, A510, Align esc, GP780 gyro, AR6110,
Blade 400, Hitec 65mg's, JR290 w/Fut. 401, stock esc w/Sport Bec, Sonic head and tail
Fairview is offline        Reply With Quote Quick reply to this message
Old 12-31-2012, 07:40 AM   #60 (permalink)
one of my 2013 projects is to do a full blown Radikal vs Whiplash report.
there isn't a one size fits all answer here, each model has its own merits and areas for improvement.
the radikal weighs less....period.
in my opinion, the whiplash central chassis is a little simpler to build
I had more initial parts quality issues with the Radikal however the mfgr provided replacements that were fine.
the current landing gear design on the Whiplash is vulnerable, they are somewhat brittle and tend to break, although they can be replaced individually and easily. I had problems with the plastic landing gear pieces splitting on the Radikal, also easily replaced.
in current production form, there are at least 3 gearing options for the Radikal. There is currently only one available for the Whiplash
the Whiplash uses very simple direct to swash servo controls, the Radikal uses push-pull bellcranks which will let less expensive servos still work well.
Its easier to get the engine/clutch/pinion alignment done on the Whiplash. The bell/pinion has fixed alignment in the frame and the clutch is essentially a floating/self aligning setup as its the stock Zenoah RC clutch. The Radikal uses a threaded clutch/fan hub assembly so there's really not much alignment that you can do there. The pinion/bell/block assembly mounts into slotted holes so it can be adjusted.
The cooling system used on the Zenoah RC motor in the Whiplash is bulletproof. The fan/shroud/clutch setup that Century developed for the Radikal seems to work just as well
at least at normal on the shelf pricing, they seem to cost more or less about the same.
Carey Shurley
