Go Back   HeliFreak > R/C Helicopters > RC Helicopter Flight School
RC Helicopter Flight School Instructional Flying Tips, Tricks, Videos, and Q&A
Old 03-17-2015, 02:56 PM   #1 (permalink)
Default Dual rates
Curious, does anyone use dual rates for flying helis? Having different expo and travel settings are useful on planes. I could see the benefit of having different settings for flipping between hard and soft 3d.. wasn't sure if anyone actually did it though.
dwelzel is offline        Reply With Quote Quick reply to this message
Old 03-17-2015, 03:08 PM   #2 (permalink)
YES!!!
Most models I have 3 DR rates (landing 50, soft flying 80, full out 100).
Use DR 50 for indoor practice hovering on the 130X.
My 450X uses DR equivalent of 130 to get roll rate up high enough (else it feels too sluggish).
Old 04-05-2015, 10:19 PM   #3 (permalink)
I might differ a little bit. I always use the same rates, because for me its the only way to consistently improve my stick inputs. What gives some duality are different headspeeds. The lower one is good for gentle moves, taking off and landing. The higher is for sport flying and 3D. But if you feel dual rates might help you in certain situation like shaky inputs on landing, use them.
Mateyhv is offline        Reply With Quote Quick reply to this message
Old 04-05-2015, 11:10 PM   #4 (permalink)
I have 3 rates on my models. I most always use 100%. Set my FBL agility to handle what I can deal with at max rates. But sometimes I have a off day, or just want to do some smooth circuits and I'll flip to mid or low rates. Low rates as well if I have my camera strapped to the heli
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS, T-700N
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote Quick reply to this message
Old 04-06-2015, 11:13 AM   #5 (permalink)
I was about to ask a similar question.
Being a newly converted plank flyer I am used to switching between D/R depending on the maneuver.
I am on lesson 4 (inverted Piros) but still learning my nose in and out orientations. When I flip, I flip on High rates but want to hover on low rates. But I keep it on High rates incase I need to "escape" to upright. Is it preferred to Hover inverted then on High or low rates?
This is all sim flying at the moment.
Regards,
Theunis.
Theunisjr is offline        Reply With Quote Quick reply to this message
Old 04-06-2015, 07:14 PM   #6 (permalink)
I use different rates on different modes when I'm setting up a new helicopter so I can test different setups. However, once I decide on the rates I like the only things I change on mode changes is head speed. If I'm not feeling too sharp I fly on lower head speed than if I feel like pushing it.
As to flipping rates being different than hovering rates, I personally would not do that, but there's no rule that says you can't. A lot is going on in your head when you're working out all the new orientations. Adding the complexity of mode changes into that might be pretty hard. As you gain experience flipping you'll find them naturally tightening up so you can do them on lower rates if you want. It doesn't take as much stick motion as you think, but it takes some time to get there.
George - Goblin700(iKon2), Trex550e(iKon), Oxy3(microiKon), Taranis
gstoneberg is offline        Reply With Quote Quick reply to this message
Old 04-06-2015, 07:51 PM   #7 (permalink)
I simply tune my RL helis to the speed that I am flying on the sim and they generally stay there. When I wish to change setup, I set some new DR values and flick between them during the tuning flights to see which one I like better until I settle on a new tune. Then they tend to stay that way for a while.
There is no reason you can't have a slow DR setup for a piro hover and then aggressive DR for 3D etc.
Changing HS will increase/decrease cyclic response etc so you may like to alter DR for a high/slower HS.
12S 4035-500 Gaui X5 Formula VBar, 6S 2520-1880 Gaui X3 AR7200BX, Phantom 3 Professional
FailureToFly is offline        Reply With Quote Quick reply to this message
Old 04-06-2015, 09:18 PM   #8 (permalink)
Regards,
Theunis.
No problem using a lot of expo to keep the hover soft, but the flip rate high.
If you have a particularly advanced transmitter, you can do some funky stuff (like low expo, low DR first 75% of stick, then medium expo, high DR for the last 25% - best of both worlds).
It's all personal preference.
Old 04-07-2015, 02:08 AM   #9 (permalink)
Thanks a lot for the replies and suggestions, I Have a DX9 so when I get my OXY 3 or 450L (Still on the fence) I will set her up that feels the best.
Theunis.
