Old 06-19-2015, 09:37 AM   #1 (permalink)
Default GPro 1.2 tail fighting me...
Hello my fellow rotorheads!
I have a GPro 1.2 installed on a Blade 300X. Everything is set up properly and she hovers well, except the tail is fighting me. Counter clockwise rotation is fine. Clockwise rotation though is met with the tail heading back to where it came from.
I would expect the same reaction to both left and right inputs, but it only happens in one diection. I have to overcompensate and let it settle back a little less than it started with. But turn the other way and it turns no problem.
Mechanically she is set up properly, as far as I can tell.
Googled this, but only found one video where someone complained of similar issue and just changed it out for a BeastX (That's what I put on my 500L). Only other thing is the complaints about tail wag, which this does not.
Thoughts???
Thanks!
Gary
Nano CPX / mCPX v2 / mCPX BL / 120 SR / 180 CFX / 300 X / 300 CFX / 360 CFX / T-Rex 470L Dominator / T-Rex 500L Dominator / Goblin RAW 420 / GooSky S1 / GooSkyS2 / Spektrum DX9
Sgt_BF_Gunner is offline        Reply With Quote Quick reply to this message
Old 06-19-2015, 11:07 PM   #2 (permalink)
When you setup the neutral position for the tail, how did you go about doing it?
Gaui X3- Xnova, Hobbywing PP50AV3, Savox/MKS, MSH Brain
jmheath357 is offline        Reply With Quote Quick reply to this message
Old 06-21-2015, 05:20 PM   #3 (permalink)
I set up the tail per the Jeff Fassbinder video...
Align GPro Binding and Setup by Jeff Fassbinder (56 min 33 sec)
(at minute 43).
90 degree on the servo and end points set not to bind. Rudder Endpoint Settings in the GPro software.
I'm sure I'm missing something???
Old 06-22-2015, 01:29 AM   #4 (permalink)
Ya, that's what I thought. Believe or not, this is not the way you want to do it. You actually want the neutral position to be setup that when you are in rate mode and in a hover the tail does not drift. Once you do this, you will see much better results when you switch back to heading hold mode. Keep in mind, it doesn't have to be absolutely perfect but the closer you get it the better. Here's a picture of where mine ended up being.
Old 06-22-2015, 01:30 AM   #5 (permalink)
Give that a shot and then let me know if that helped.
Old 06-22-2015, 06:43 AM   #6 (permalink)
You sir, are a genius. It worked perfectly.
Thank you for your insight! Life is good now.
Old 06-22-2015, 10:43 AM   #7 (permalink)
Thats great! I'm glad that worked out for you.
