Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 03-23-2011, 12:23 PM   #1 (permalink)
Default Scorpion HK-4530-540KV (Limited Edition)
Hei all
I have a TDR coming next month and have started to shop in equipment.
Just ordered the 4530-540KV engine and are wondering if you guys have any ESC recommendation for this motor?
Is a Jive 80HV sufficient?
Also what pinion should i be running on this motor?
Thanx all
JR Sylphide EX with Super Gracy
JR Sylphide with MB391
TDR jive120 4530-540 scorpion CGY750
Mikado Logo 600SE V-bar
maizor is offline        Reply With Quote Quick reply to this message
Old 03-23-2011, 12:52 PM   #2 (permalink)
i've also ordered it. I don't think the jive will be enought for that kind of powerful motor..!
neohp is offline        Reply With Quote Quick reply to this message
Old 03-23-2011, 12:52 PM   #3 (permalink)
Hi,
with a motor as powerful as the 4530, the Jive80HV really is no option.
Because of the screw-type body, you need at least the 14 teeth pinion, or else the motor will get in the way of the intermediate shaft bearing. Bigger than that is only needed for really high head-speeds
shaman3 is offline        Reply With Quote Quick reply to this message
Old 03-23-2011, 12:55 PM   #4 (permalink)
You will definitely need the 120HV for this motor!
G.
TDR3DRigid Mikado V-Bar 5.1
Futaba8FG S-Bus
g-bru is offline        Reply With Quote Quick reply to this message
Old 03-23-2011, 01:47 PM   #5 (permalink)
Thanx all just ordered a jive120HV so loooking forward to this build
Old 03-27-2011, 01:25 AM   #6 (permalink)
Yep 120HV mandatory!
Does anyone know where were the 4525LE made? The 4530 are being wound in germany, I assume they might be done a bit nicer.
helicraze is offline        Reply With Quote Quick reply to this message
Old 03-27-2011, 03:07 AM   #7 (permalink)
The 4525LE if I remember that correctly was wound in China, PowerCroco himself gave advices... there was a post a while back that the guy had to train doing this kind of windings first.
-Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-Logo400-500-600SE
worldofmaya is offline        Reply With Quote Quick reply to this message
Old 03-27-2011, 03:46 AM   #8 (permalink)
Why assume, there are some excellent products coming from the East.
VControl
Old hand at Planks
Peter
Old 03-27-2011, 04:58 AM   #9 (permalink)
Doing the windings with accuracy optimises the air flow which makes a noticeable difference. This doesn't mean that's only done by certain people, companies or on certain places in the world...
Just have a closer look at the Standard Pyro and compare it's windings with for example the Black Edition...
-Klaus
Old 04-17-2011, 11:21 PM   #10 (permalink)
Scorpion donated the full amount to Japanese Red Cross, i think there is about 10 units still left! Can't wait!
Old 05-03-2011, 01:06 PM   #11 (permalink)
i've ordered a 15 T pinion, do you guys think it will be overkill ?
I would like to push hard 3d move but don't want to strip the gears...
Radix 710
voltz 45c
jive 120 or yge 160 don't know yet
greetings,
jerome
Old 05-03-2011, 01:14 PM   #12 (permalink)
Might work fine for RPMs around 1900.
With configuration in my signature and 14T, i still easily touch 100% PWM in Jive in 3D at 1880RPM.
14T is optimal for everything, but 15T will be only for high RPM 3D.
With 15T, you might have a problem to get under 1400RPM with Jive.
Might be different with YGE.
BTW the motor will be more power hungry then my Pyro, which means the battery voltage will drop more, so 15T might really be optimal.
- TDSF in a box...
- TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar
- TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14
jointer is offline        Reply With Quote Quick reply to this message
Old 05-03-2011, 05:00 PM   #13 (permalink)
He is talking about the 4530 motor, the KV is 540 so with 15T and 85% around 2150RPM.
Not sure, should be ok with croco mount and proper gear mesh (gear expands a lot when pushing hard)
Old 05-03-2011, 05:14 PM   #14 (permalink)
I am well aware, HC.
That 20KV difference is not that much and my setup behaves as i wrote.
It depends if Jerome wants to do only hard 3D on high RPM or combination with low RPM.
I would not believe what i wrote before owning the JLog, the needed headroom for perfect governor work is quite large.
- TDSF in a box...
Old 05-03-2011, 06:00 PM   #15 (permalink)
Merci !
I guess i'll have to stick with the 14 T pinion if i want to slow things down from time to time...!
I also assume 15T will be greatly demanding on the packs.
By the way, today i broke 2 teeth of the main shaft gear. Maybe because of the heat, i hadn't check gear mesh since this winter...
Old 05-03-2011, 08:17 PM   #16 (permalink)
Originally Posted by neohp View Post
Merci !
Tzzeee, tzzeee, forgot the maintenance???
Btw. main shaft gear?? Do really mean the smaller Delrin gear on the man shaft?
Kind Regards ZT - TDR,
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote Quick reply to this message
Old 05-04-2011, 03:19 AM   #17 (permalink)
indeed mister !
Still wondering why....
Old 05-05-2011, 07:52 PM   #18 (permalink)
Radix 710
voltz 45c
greetings,
jerome
Big time over kill.
I think you will find the batteries will be the weak link when trying to sustain high headspeeds.
I would be surprised if you got much more than about 3 1/2 minutes out of it with a 15 tooth pinion on the motor.
Mick
aussiemick is offline        Reply With Quote Quick reply to this message
Old 05-07-2011, 03:08 PM   #19 (permalink)
you are right mick. i've changed with a 14t thanks to jan H. it will be more appropriate indeed !
Old 05-07-2011, 09:18 PM   #20 (permalink)
Decisions decisions, Hmmm make a hard core speed machine or just normal flier LOL.
Even with the pyro and flying hard (lots of powerloops and speed runs) i am down to 4.5 mins LOL 1850RPM
