Old 01-31-2016, 10:18 PM   #1 (permalink)
Default Troubling to put the canopy on.
I have hard a time to put the canopy on. The bolts don't go through the holes of the grommets. I tried to force the canopy and it cracked a little. I tried to cut it and made it worst. Tips?
Mr._Torque is offline        Reply With Quote Quick reply to this message
Old 01-31-2016, 11:20 PM   #2 (permalink)
What heli?
Depending on what it is you can drill new holes farther back for the grommets. So that you don't have to jam the canopy on so far.
Or trim the bottom of the canopy in such a way that you are able to shove the canopy on further. If that is the problem.
Whatever way makes more sense for your situation.
Goblin 770 Comp, Raptor E700, T Rex 450-600-700 DFC, 600N, Blade NCPx-130-180. Citizen 778
HEXAHYDRATE is offline        Reply With Quote Quick reply to this message
Old 01-31-2016, 11:25 PM   #3 (permalink)
I have a T-Rex sport 450. I tried cut it with a knife or scissor, and it keeps cracking the canopy.
Old 02-01-2016, 02:29 AM   #4 (permalink)
Ya they are a tight fit and brittle. The best thing to do is relocate the holes for the grommets farther back on the canopy so you don't have to force it on so far. Put the canopy on the heli where you think is a good spot that you won't have to be forcing it and mark where you need to drill.
Old 02-01-2016, 02:39 AM   #5 (permalink)
And no you can not cut it with knives or scissors. You are best to grind using a dremmal tool. Or sanding would work too.
Old 02-01-2016, 05:02 AM   #6 (permalink)
Like Hexahydrate says, you can use a dremel with a stone or sanding attacment. This is what I do and it works great. I use the cone shaped stone attachment for making or enlarging the grommet holes.
Do the grommet holes line up with the posts? Sometimes, everything actually lines up, but the canopy holes are a little too small and constrict the opening in the grommet. Just throwing out something else to look at.
If it is an alignment issue and you can't get the canopy on all the way, then I would look for the item(s) that are obstructing it. Is the ESC in a bad spot? Is it the battery or battery wires? Maybe there is a different wire routing that will allow the canopy to fit without modification.
Oxy 2, Gaui X3 #1, Protos 380, Gaui X5, Synergy 766, Specter 700
Oxy 2/X3/Protos 380/X5/766/Specter 700 Consecutive Successful Flights (Current) = 32/16/12/145/7/50
Consecutive Successful Flights (Max) = 145
macdad is offline        Reply With Quote Quick reply to this message
Old 02-01-2016, 08:49 AM   #7 (permalink)
I had to make holes further back on my 450pro and sport. Makes it a heck of a lot easier for canopy install and removal.
A reamer is great for this. Some kits don't come with holes at all or you need to enlarge them so it's handy to have one.
http://www.amazon.com/Hobbypower-Exp...dy+hole+reamer
I don't have any pics handy of the 450's but I did the same with my 250 when I had it.
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is offline        Reply With Quote Quick reply to this message
Old 02-02-2016, 05:28 AM   #8 (permalink)
Off memory the manual was wrong for these - you need to put the underside of the canopy in the slot in the canopy holder - not right over it as the manual suggests.
EjectEjectEject is offline        Reply With Quote Quick reply to this message
