Old 07-02-2015, 09:42 PM   #1 (permalink)
Default Urgent help needed - main gear keeps stripping
My blade 450x main gear keeps stripping after I replace it. Every single time. Anyone know why? I've tried 4x same result everytime. Once got off the ground and it spun out of control main gear stripped after it got a foot off the ground.
Anyone?
benjiminstanley is offline        Reply With Quote Quick reply to this message
Old 07-02-2015, 09:51 PM   #2 (permalink)
How is your gear mesh? If it's really loose, or really tight it will strip your main gear.
*Spartan Vortex VX1e*
Old 07-02-2015, 10:10 PM   #3 (permalink)
It was loose once because I thought it was too tight the other time and this time around I couldn't see anything wrong with it but still stripped. I'm baffled
Old 07-02-2015, 11:02 PM   #4 (permalink)
No expert here but when setting the gear lash I would either adjust it to where a piece of thin paper could be fed through it, or I just set it "as if" that piece of paper would go through. Not binding too tightly, not out on the ends of the teeth, just enough so that I can have a tiny bit of play between the two.
How far out is yours set?
How far down is your motor gear set?
My motor gear's bottom surface sits about 1/16th inch lower than the main gear. Keeps that upper tapered part away.
Make every flight an adventure!!!
R/C Heli's: Blade 450, Blade MCX2, IR9098
1:1 Heli's Current: AW139, BH412, BH212
1:1 Heli's Past: SK76, UH60, BH206
Jeremy A is offline        Reply With Quote Quick reply to this message
Old 07-03-2015, 09:56 PM   #5 (permalink)
Also make sure that you are setting the proper lash at the tightest point of the gear. Good point about the pinion. If any part of the angled/tapered portion is contacting the main gear, it wil wear out quickly. How is your soft start?
