Old 05-09-2012, 10:38 PM   #1 (permalink)
Default Scorpion 4035-560 rewind
I have a old Scorpion 4035-560. I want to rewind for more power. Some idea for rewind. Is good the wind YY for this motor? What is the better KV for Trex 700E ?
LANDERW is offline        Reply With Quote Quick reply to this message
Old 05-10-2012, 10:45 AM   #2 (permalink)
I run a stock HKIII 4035-560 on my 700E with a 12T pinion and 112T main. This combo works pretty good with a Jive 120 (gives plenty of headroom).
stolla says rewinding this motor with 1.4mm wire in a YY configuration is the right thing to do.
NRPY is offline        Reply With Quote Quick reply to this message
Old 05-10-2012, 12:17 PM   #3 (permalink)
Thank NRPY, How many turns I need for 560 KV with 1.4mm in YY. Do you know is the power increses with YY in this motor and how many watts
Old 05-10-2012, 02:29 PM   #4 (permalink)
I'd say 5+5 in YY comes close to your target.
It depends a bit on which ESC you are using. YGE and Castle produce a little bit higher Kv than Jive.
Best is always to do a test wind with thin wire and only 6 teeth (one of the 2 motors) and then let it run with a known voltage and measure the speed,
Kind Regards ZT - TDR,
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote Quick reply to this message
Old 05-10-2012, 05:29 PM   #5 (permalink)
He said 5+5 for 560kV and 5+6 for 510kV. 8000W+ easy.
Old 05-10-2012, 10:07 PM   #6 (permalink)
schematic 5 + 6 YY @ 1.4 mm 510 KV ABCABC II ABCABC 565656 II 565656
i'm correct maybe someone with more experience can chime in and confirm
Old 05-11-2012, 10:10 AM   #7 (permalink)
ABC is a Delta terminated winding.
I thought you would like to go with a YY?
This would be the proper YY winding scheme:
AabBCc/aABbcC
There are other possibilities by winding all groups in the same way and just terminating differently.
Just have a look at powerditto.de
Old 07-14-2012, 01:21 PM   #8 (permalink)
so where do you buy wire?
550E, X3 | BeastX, YGE, DX8
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 02:32 PM   #9 (permalink)
Brocott in the UK for wire
http://www.brocott.co.uk/enamelled-m...ire?fullSite=1
Winding scheme here http://www.powerditto.de/schemamodus12Naussen.html
VControl
Old hand at Planks
Peter
Old 07-14-2012, 02:36 PM   #10 (permalink)
wow! thanks m8! perfect. Will try to do a 5+5 x 1,4YY on mine. Anything else you need except for wire, insulation tubes, protective paper?
Old 07-14-2012, 02:41 PM   #11 (permalink)
it would be about 12x5x40x2+6x40+6x100=5640 mm, say roughly 6 meter wire, should be correct I hope?
/edit: don't bother. They sell by weight...
l = 12x5x40x2+6x40+6x100 = 5640 = 6000 mm
A = pi*r^2 = 1,54 mm^2
V = A*l = 1,54*6000 = 9240 mm^3 = 9,24 cm^3
d = 8,96 g/cm^3
m = V*d = 9,24 * 8,96 = 83 g
So I guess this following 1,4 mm 250 g reel would be suitable?
http://www.brocott.co.uk/enamelled-m...ww140-250.html
