Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 01-13-2016, 12:59 PM   #1 (permalink)
Default Balance problem
I am having a curious problem with a set of Align 325 carbon blades.
They are balanced using the Finless method of equalizing cg. then teetering them with an Align prop style balancer and adding tape to the high blade until they are level. The problem comes when I weigh them. One blade weighs 25.88g while the other is 25.73g.
My question is has anyone else seen this and are they ok to use.
Mini Protos 3x HS5065mg, AR7200BX, JR290
Trex 500ESP Robird, Oxy 2, OXY 3, Oxy 4 All on Dx8G2
AMA 732104
MiataJohn is offline        Reply With Quote Quick reply to this message
Old 01-14-2016, 11:18 AM   #2 (permalink)
Add tape to the lighter blade directly over the balance point till they are equally balanced. Should not take too much tape.
Gabriel Sandoval "NitroGabe"
soXos USA Flight Team, Team JR PROPO
Team Scorpion, Team YS engines USA
Bavarian Demon Flight Team #HIGHONHELIS
DUCDOC is offline        Reply With Quote Quick reply to this message
Old 01-14-2016, 12:45 PM   #3 (permalink)
Thanks DUCDOC
But they are currently "in balance" on the balancer (perfectly level). Adding weight over the cg of the blade to make them weigh the same will cause that blade to drop.
Am I missing something really obvious in my old age? I have never seen two objects with unequal weights be in balance on a balancer.
AMA 732104
Old 01-14-2016, 09:18 PM   #4 (permalink)
OC Helifreak
the balancer is correct , go fly it then decide besides .15G ? not much
Edge540V3 DA120
Urukay HPS3
KSE700 HPS3
Mamba DA70
Airboss is offline        Reply With Quote Quick reply to this message
Old 01-16-2016, 10:51 AM   #5 (permalink)
+1 to the balancer is correct. The weight means nothing (to a point). For example you could have two blades the exact same weight but be extremely out of balance if one has more weight towards the root and one more weight towards the tip.
That's why using a balancer is a much better method than weighing. In general weighing works with smaller blades (like tail blades) but the longer blades will be better suited to using a balancer that will take in to effect where the weight is on the blade.
There are some exceptions to all of this, but in general this will get you where you need to be.
MCX2, 120SR, Blade 4503D w/Robird G31, Trex 500 w/RC Aerodyne A109 Scale Fuselage, 2X Trex 500's, Trex 550 w/ BD3SX, 2X Goblin 570's, 2X Goblin 700's w/BD3SX DX6i, DX9, Phoenix Sim, and a credit card. HF member #178,534, AMA
danfornow1 is offline        Reply With Quote Quick reply to this message
Old 01-17-2016, 09:27 AM   #6 (permalink)
Thanks for the help. I will fly them and if I crash of course it's your fault!
AMA 732104
