Old 12-17-2016, 09:12 PM   #1
lmcwilli
Default How to BUMP a 4.27V Revolectrix pack?
I have three Revolectrix Silver Label 70C HV5500 6S packs. The recommended charge voltage is 4.27V/cell.
The BUMP only allows setting up to 4.25V as the max volts/cell. Can I achieve a 4.27V setting using the BUMP?
Blade 450X, Witespy Quad, Gaui X3, Gaui X5, Goblin 570, Goblin Black Thunder
lmcwilli is offline        Reply With Quote
Old 12-17-2016, 10:53 PM   #2
RevoKelly
The BUMP only allows setting up to 4.25V as the max volts/cell. I know it's not much of a difference but you would think the BUMP would accommodate the configuration of its own brand packs.
Anything above 4.20 is considered a high voltage lipo - if u use the LiHV chemistry instead of LiPo, it will let u go up to 4.35.
RevoKelly is online now        Reply With Quote
Old 12-18-2016, 12:43 AM   #3
lmcwilli
Great. Simple. Thanks. Sounds like I'll need to replace those bump tags.
Old 12-18-2016, 08:38 AM   #4
RevoKelly
Unfortunately, yes if u want to charge above 4.25. We use a different chemistry type to distinguish regular vs HV lipos to avoid accidentally mixing them, especially when parallel charging.
Old 12-19-2016, 07:33 AM   #5
lmcwilli
NP
