Go Back   HeliFreak > R/C Electronics Support > DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One)
DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) Factory Support Forum
Old 12-28-2012, 04:39 PM   #1
Thalios
Default Very cold weather and Wookong-M are not playing well...
Had a crash happen yesterday.. Could not find the exact cause. The only reason I can figure is that the Wookong-M froze...
Let me recap:
It was roughly -15°C without windchill. Winds were calm.
I was flying around (for about 45 minutes or on my 3rd set of batteries if you prefer) and the wookong started feeling weird. When I banked in one direction, it wouldn't come back to full level. And same the other direction. So since the bird was far away (well, maybe 500') I started bringing it back. It came back fine, but started to bank right too much as it came back. I watched in horror as the H6 tilted all the way to the right to a point where the bird was upside down... I killed the motors as it hit the snow. Luckily it wasn't hard snow.. Broke all 6 props and one plate on my camera mount which I can probably redneck repair.
The motors were semi-hot after running 45 mins back to back so the snow melted on contact with it and got in the motors. The show then cooled the motor and it froze solid. The motors were stuck... I brought it straight home and blew compressed air all over everything to remove snow/water.
I still don't know exactly what happened, but my best guess is that the Wookong IMU froze....
Hint of advise: Don't fly below -10°C..........
Thalios is offline        Reply With Quote
Old 12-28-2012, 05:49 PM   #2
DesJardins
That happened to a buddy and his Naza when he left it sitting out on the pit-table for 30minutes around 35degrees before flying.
Sponge inside the Naza box was hard as a rock
Blade 450X & Blade mCPX BL
Spektrum AR7200BX
ProgressiveRC's "The Neutrino Ticket"
DesJardins is offline        Reply With Quote
Old 12-28-2012, 08:57 PM   #3
rmalt
Wow sorry to hear that! I wonder if that is why it has an operation temp of -5 deg C.
Pulse XT 60 Saito 100
~KBDD Team Pilot~
rmalt is offline        Reply With Quote
Old 12-29-2012, 08:25 AM   #4
benchmark
Could it also be due to lipo voltage suddenly drops dratically due to the cold?
benchmark is offline        Reply With Quote
Old 12-29-2012, 08:32 AM   #5
SAMUELPINONFLORES
May be you got some moisture inside you MC it probably made it to fail.
FUSION 50 /CGY750
PROTOS 500 /SKOOKUM SK540BELT CP V2,CYPHER 3D
BIG NAZA QUADCOPTER
FLIP FPV
SAMUELPINONFLORES is offline        Reply With Quote
Old 12-29-2012, 10:11 AM   #6
Thalios
Not lipo voltage as I have telemetry on it.
Really doubtful on moisture as I live in Quebec and it is fairly dry out here.
Old 12-31-2012, 01:15 PM   #7
oosnoopy
Interesting, I would have though the micro controller itself would have generated enough heat to keep itself from crossing that threshold.
How do you keep your hands warm in that? I get by in 0 C weather by using heated glove liners, and that's pushing it sometimes.
APM 2x / TBS Frame / Trex 700e
1.2 GHz video / 900 MHz packet telemetry
oosnoopy is offline        Reply With Quote
Old 12-31-2012, 01:49 PM   #8
Thalios
Using this mitt:
http://www.greathobbies.com/producti...rod_id=GHPMITT
Works great.
