Go Back   HeliFreak > R/C Electronics Support > DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One)
DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) Factory Support Forum
Old 02-15-2013, 03:47 PM   #1
DebianDog
Default Center stick changes in modes - Naza
Is this right? I have everything zeroed on the radio and it is perfectly centered in manual mode. I have tried recalibrating it in all modes = no change.
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 02-15-2013, 03:54 PM   #2
Alekoy
I would recomend pulling up the servo monitor on the transmitter and see if anything is happening on the respective channel there, might be a hover pitch or rpm setting or something if you are using a Heli-model on the transmitter..
Helibug Mercury 800, Henseleit TD-NT, Henseleit TDR, Tarot FY680, XuGong-10, TBS Disco PRO, Blackout Miniquad, Futaba 14SG, EZuhf.
Alekoy is offline        Reply With Quote
Old 02-15-2013, 04:05 PM   #3
DebianDog
Nope. Monitor is good. Only thing moving is pitch. Yes, I am using Idle Up 1 and 2 to switch modes on the pitch but I to not have anything mixed or linked. It is the only one changing.
Old 02-15-2013, 04:47 PM   #4
Alekoy
hmm..and this is only happening mid-stick on the throttle?
are you using PPM between receiver and NAZA?
I use Gyro gain linked to flight mode in the transmitter to change between flight modes on the NAZA,
This is on a futaba system, but I think your JR have similar possibilities...
You are after all changing the setting on the "Gyro" not the pitch
Old 02-15-2013, 07:44 PM   #5
02deuce
If I am understanding this correctly when you switch from manual mode to Atti mode you are getting movement on you elevator channel in the Naza software but its not showing any movement on your radio monitor screen?
Trex 700N, 700E, 600E, 500E all Vbar 5.2 Pro FBL
Dji F550 WKM Data Link 900MHZ
DJI F450 Naza/GPS FPV 5.8 vtx
TBS Disco w Core Naza GPS FPV 1.2 vtx MT Tiger motors
02deuce is offline        Reply With Quote
Old 02-16-2013, 07:21 AM   #6
DebianDog
Default Re: Center stick changes in modes - Naza
Deuce-Correct I have not changed anything from the way we set up earlier. I just noticed that aileron and elevator were changing slightly when I was flipping from GPS to atti to manual
Sent from Galaxy S3
Old 02-16-2013, 07:54 AM   #7
whiplashWho
When you calibrated the sticks, did you ensure everything was dead center when you confirmed? Are there any mixes programmed into your Tx?
Try posting in the RCTech subforum over at http://fpvlab.com.
whiplashWho is offline        Reply With Quote
Old 02-16-2013, 11:06 AM   #8
Alekoy
Might be caused by PPM timing changes if you use PPM....
Old 02-16-2013, 08:07 PM   #9
DebianDog
Deuce wins again. When I first reprogrammed the model I changed from Arco to heli and "thought" I had cleared or zeroed everything. Deuce PM'ed me and asked "are you SURE you cleared everything?"
Me: not 100%
So... I took pictures of all my screens, made a new model, and verbatim put everything back.
The problem went away! Thanks Bri!
Old 02-16-2013, 08:29 PM   #10
02deuce
Houston we have lift off!!!
