Go Back   HeliFreak > R/C Electronics Support > DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One)
DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) Factory Support Forum
Old 03-02-2013, 09:10 PM   #1
rcflyerheli
Default Wookong question
I am trying to set up a Wookong M with camera gimbals. I have the camera pitch figured out, but the roll function doesn't seem to be working. I am running the Savox 264MG servos with the pitch servo connected to F2 and the roll servo connected to F1.
I get proper pitch functions using the X3 channel to control the pitch servo and I can change the pitch of the camera mount with the rotary knob as per the manual. However, the roll servo doesn't appear to be getting any signal, as I get no roll stabilization and the servo output arm can be rotated with power applied.
Does anyone have any ideas how to get the roll function to operate?
Update:
Disregard, I got it to work.
Goblin 700, Trex 700 V2, Trex 700DFC, Gaui X7, Logo 600SX, Logo 690SX, Forza 700
Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Team
Rep
rcflyerheli is offline        Reply With Quote
Old 03-02-2013, 10:56 PM   #2
Thalios
Do you have anything assigned to x3? Check the gain controls, etc.
Thalios is offline        Reply With Quote
Old 03-02-2013, 10:56 PM   #3
Thalios
Also make sure you don't have switch activated RTH.
Old 03-02-2013, 11:23 PM   #4
rcflyerheli
Thanks for the reply. I had it set up correctly, as I was getting the pitch channel to work fine, I just couldn't get anything out of roll. I went back and looked at the servo connectors that plug into the MC, and the Savox plugs are (was on the roll) loose. I got them inserted good and put a dab of hot glue to hold them in, and everything works as normal.
I'm not positive how smooth the roll is going to be, and I might have to make some mechanical adjustments to the servo arm setup.
Amain Team
Rep
