Go Back   HeliFreak > R/C Helicopter Support > Multi Rotor Helicopters - Tandem
Multi Rotor Helicopters - Tandem Multi Rotor Helicopters - Tandem
Old 07-19-2013, 08:12 AM   #1
ttrip06
Default KK2 help
I have a kk2 board I purchased and I am getting no signal on all the channels from the receiver test menu. Futaba radio equipment and the unit is bound fine because I can power and run servos no problem. I can cal the gyro and set and adjust everything but the ESC and rec.
Any thoughts?
Tim Tripoli
Team Futaba, Rail Blades
Team crash
ProgressiveRC
ttrip06 is offline        Reply With Quote
Old 07-19-2013, 09:13 AM   #2
PTcaflyer
HF MR Support
Does the KK2 light up? Try scrolling to the end and debug.....
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote
Old 07-19-2013, 10:48 AM   #3
Subaru4WD
Try powering up the receiver for a second, then power the KK2 up.
Subaru4WD is offline        Reply With Quote
Old 07-19-2013, 11:07 AM   #4
PTcaflyer
HF MR Support
...frame rate for Futaba?
Have never seen a KK2 not link up....
Old 07-19-2013, 11:24 AM   #5
Subaru4WD
This was a common problem with older firmware.
I would make sure to update to the 1.6 firmware too.
Old 07-19-2013, 01:15 PM   #6
ttrip06
Firmware is 1.6
Yes the unit powers on fine and all menu are accessible. I will try powering the receiver first when I get home tonight.
Thanks for the suggestions so far.
Tim Tripoli
Team crash
ProgressiveRC
Old 07-19-2013, 01:29 PM   #7
Subaru4WD
Also be sure that CPPM is disabled in the KK2 menu.
Old 07-19-2013, 01:35 PM   #8
PTcaflyer
HF MR Support
...Agreed!
Old 07-19-2013, 04:47 PM   #9
petedee
Unless you are using a FlySky Rx then it makes the install very easy using a single cable and CPPM.
http://www.hobbyking.com/hobbyking/s...ompatible.html
similis vobis fugere eam furatus
"The beatings will continue until morale improves."
-- William Bligh
petedee is offline        Reply With Quote
Old 07-19-2013, 05:40 PM   #10
Subaru4WD
Well, yeah. CPPM is far cleaner and easier than using standard servo cables. But if he's not using CPPM, he will need to disable it in the menu or else he will get this error.
Old 07-20-2013, 07:15 AM   #11
ttrip06
Thanks guys already for my maiden today.
Tim Tripoli
Team crash
ProgressiveRC
Old 07-20-2013, 12:25 PM   #12
PTcaflyer
HF MR Support
...Video please!
Old 07-20-2013, 03:41 PM   #13
petedee
Yes what was the problem?
Pete
-- William Bligh
Old 07-20-2013, 05:16 PM   #14
Subaru4WD
Pete
Yes? How did you fix it?
