Go Back   HeliFreak > R/C Helicopter Support > Multi Rotor Helicopters - Tandem
Multi Rotor Helicopters - Tandem Multi Rotor Helicopters - Tandem
Old 07-25-2013, 08:28 AM   #1
CaptHal8HS
Default Motor/ESC Recommendations
Hello;
I am contemplating buying a Sky-Hero Spyder. It can be configured as a 8 motor machine in a quad arm configuration. It is a 700mm machine. It can accommodate 28mm to 36mm motor sizes. My plan is to sell my DJI 550 but keep the electronics and transfer them to this machine.
Can someone recommend a descent motor and esc configuration for this machine? Looking for props as well.
Thanks!
/Hal
____________________________________________
Goblin 700C - VBar Neo | Goblin 420 - VBar Neo | Blade 180CFX
MIKADO VControl | SPEKTRUM DX9 | iCharger 406 Duo | Meanwell RSP-1500W-24V
CaptHal8HS is offline        Reply With Quote
Old 07-25-2013, 01:41 PM   #2
petedee
I am running some NTM 2630 800kv motors on my DJI550 frame with 10x4.7 props, very nice motor and under $20 with prop adapter, they would be nice on a bigger frame with bigger props as they are rated at 300 watts.
similis vobis fugere eam furatus
"The beatings will continue until morale improves."
-- William Bligh
petedee is offline        Reply With Quote
Old 07-29-2013, 10:09 AM   #3
lowflyer101
quad 8, which FC will support this config, my knoedge Apm support this, will Naza support quad8?
lowflyer101 is offline        Reply With Quote
Old 07-29-2013, 10:27 AM   #4
CaptHal8HS
Naza and Wookong-M supports a X8 and Y6 configurations.
/Hal
