Old 07-21-2016, 10:10 PM   #21
jflowers84
Here is my charging case, It has 4x HP 1200FB installed setup in pairs to supply 24v to each powerlab. I have the bump charging system setup and the deck from bumpcharger.com.
Name:	charger deckless.jpg
ID:	662946   Click image for larger version
Name:	charger final.jpg
T-Rex 550 ikon, T-Rex 700E v2 brain2
Goblin 500 brain, goblin blk nitro braid2,Goblin 770 ikon
RCHN 761
jflowers84 is offline        Reply With Quote
Old 07-23-2016, 12:11 PM   #22
apper001
Serious mobile power!
apper001 is offline        Reply With Quote
Old 07-23-2016, 09:13 PM   #23
KevinB
I am really liking the charger setup I built last winter. It is powered by a Meanwell 48V 2000W power supply. It holds two DPL8 chargers and the BUMP to control the four channels.
It will charge four 5000mah 6s packs at 3C for a total draw of approx 1700W according to the BUMP. I don't normally charge at 3C, but when I need to, it will take 4 packs from Storage to full charge in 10-12 minutes.
The two small fans push filtered air into the case, and the big fan sucks the hot air out. There is also another small fan forcing air from the lower deck holding the power supply to the upper deck holding the chargers. At max output, the chargers and power supply only run 10-20C over ambient temperature with this configuration. The screen above the BUMP is the fan controller. It controls the four case fans as well as gives the temperature at the power supply exhaust, and an alarm if any of the fans fail.
The case is sealed when closed. The only holes I drilled were for the four flush hex head 1/4" bolts that fasten the top deck on and securely hold all the internal components in place. Removing the four bolts allows removal of the top deck and the two DPL8 chargers. Removing the four screws from the lower deck allows removal of that deck and the power supplies.
KevinB
KevinB is offline        Reply With Quote
Old 07-31-2016, 02:24 PM   #24
shadco
Mine kinda old school.
Diabolo 550 Vbar NEO : Diabolo 700 Vbar NEO: MSH Protos MAX V2 Vbar NEO : Logo 600SX V2 Vbar NEO : Compass 6HVU Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control ==> Jeti DS-14/BrainV2: Citizen 735
shadco is offline        Reply With Quote
Old 07-31-2016, 09:28 PM   #25
pctomlin
My Bump Case Build...........
The guts, two PL8s and a pair of DPS1200FBs in series to power everything.
Paul
Agile 5.5 - Quantum 4125-1100, Ice 100, Ikon FBL / Outrage 550 - HK4020-1390, Edge 120, iKon FBL
Rave Ballistic FSO - HKIII 4035-560, Ice2 HV160, iKon FBL / Protos Max V2 - MSH 4530-500, Edge HV160, Brain FBL
pctomlin is offline        Reply With Quote
Old 08-13-2016, 10:39 PM   #26
Heli_Jelly
Default Let's show your revolectrix charging station/case here
2 pl6s with an efuel power supply
Working great so far.
Heli_Jelly is offline        Reply With Quote
Old 08-14-2016, 05:37 PM   #27
mkovalcson
Picture from IRCHA, I was charging everything in sight.
4 separate chargers charging 4 different types of batteries.
At one point I had 2 x batteries charging at 20A on one of the dual PL8's leaving the other dual PL8 free to charge smaller stuff.
While I was there it charged EC3, EC5, 5.5mm bullets, RC ProPlus 6mm, Anderson Power Poles, XT150's, and Deans in 2S, 3S, 4S, 6S, 7S sizes.
I had 6S and 7S extension cables.
The bump controller worked great. All my batteries and all the batteries of my friend sharing the canopy had RFID tags. The rest we charged in manual mode.
Mark
2011' Protos 500, 2014' Logo 550SX, 2012' TDR, 2015' Protos Max V2, 2016' TDR2
2013' Jeti DS-16
mkovalcson is offline        Reply With Quote
Old 10-03-2016, 07:50 AM   #28
jflowers84
Just finished a smaller case for the indoor flying season. It has a single PowerLab 8 under the deck. The deck and balance boards were provided by progressiverc. The red switch allows me to switch between the 24v internal voltage provided by dual hp 1200fb psu, and an external DC supply such as lead acid batteries.
I can attach jumper cables to connect it to my main power case where it will have access to a bump controller.
Sent from my SM-N920T using Tapatalk
RCHN 761
Old 10-04-2016, 05:39 PM   #29
Dansy
This has a DPL8 and bump controller with cheap android tablet, a meanwell 2000-48v Ps, a 48-24v converter, USB plugs and 4 small fans 2 per side....powering 2 FMA Parallel board.
ID:	674260   Click image for larger version
Daniel...many flying planks.....Goblin Urukay Red/White, Gaui R5
Goblin 380 KSE Yellow/Blue, Goblin 420 XNova
JETI DC-24, MKS Servos, Ikon2/Brain2, Axon, Kontronik, XNova
Revolectrix/MeanWell PS, DPL8, PL8, 2x XP10 and Bump Contr.
Dansy is offline        Reply With Quote
Old 10-08-2016, 02:24 PM   #30
Geena
Here is mine. I got the PL8x2, and other accessories from Progressive RC. The case came from walmart, and the deck is made from 1/4" birch plywood covered with self adhesive carbon fiber film wrap.
Name:	WP_20161008_001 (1024x574).jpg
Gaui USA/Empire Hobby, YS Engines,Team Heliproz..retired,
Zeal blades, Demonaero/Bavarian Demon, Citizen00082
Geena is offline        Reply With Quote
Old 10-08-2016, 05:22 PM   #31
Glenflyer
Some nice setups I need to build 1 soon
Glenflyer is offline        Reply With Quote
Old 10-22-2016, 11:45 AM   #32
mkovalcson
It took the two chargers and PS out of my tall charging towers that was on wheels since it was too heavy and I never took it out to the field.
Instead I created this very light and small footprint charging brick.
It's 15"x6.5"x 8" tall and may have half a pound of weight past the weight of the electronics.
Mark
2013' Jeti DS-16
Old 10-22-2016, 11:45 PM   #33
Kaolith
Love this case! I'd love to see how it looks under the lid! Its a similar setup to mine but yours looks much better overall.
Kaolith is offline        Reply With Quote
Old 11-01-2016, 08:56 PM   #34
krauley
Heli Jelly where did you get the frame around your bump controller? and can you post a pic of the underneath of your deck of how its mounted?
nice case setup btw
UH-60 EXI 500 DFC/3GX v5.0 ICE 75 Bec Pro w/4 blade main & tail rotors
Align trex 500DFC Pro w/AR7210bx Align trex 150X
Oxy 3 Tareq Edition AR7210bx Edge lite 50 Kst 215's
PL6 w/Bump Controller-24v PS DX8 gen2
krauley is offline        Reply With Quote
Old 11-02-2016, 07:03 AM   #35
jflowers84
Thanks, once I put it back together I will post some pics of what it looks like below the lid.
RCHN 761
Old 11-02-2016, 10:19 AM   #36
Heli_Jelly
nice case setup btw
Thanks Krauley I'm very happy with it.
I made the bump frame, charge board circular frames and the fan guards.
I posted the STL file on thingiverse if you have access to a 3D printer.
http://www.thingiverse.com/thing:1434728
I'll post the inside of the box this up coming weekend.
Old 11-02-2016, 08:10 PM   #37
krauley
pm sent
Old 11-07-2016, 09:03 PM   #38
krauley
powerlab 6 with bump controller case. when i first read about the bump controller i thought it was a gimmick but after watching some how to and seeing the newest firmware in action i changed my mine. the manual charge and how the user interface interacts with the powerlab making easier to setup a charge was worth the cost alone. i havent even setup a bump tag yet wow im i happy with my newest setup.
https://goo.gl/photos/gwybj2DAwRDfGNy17
gotta say thanks to Heli_Jelly for letting me use his plans for the bump case
Name:	pl6 case pic 2.jpg
Old 11-09-2016, 10:07 PM   #39
krauley
final touches
Name:	pl6 case with cable straps.jpg
Old 11-20-2016, 12:50 PM   #40
mkovalcson
This is the smallest and lightest charging case I've made yet. It's 16 lbs 4 oz, 6 3/8" deep x 15" wide.
Mark
2013' Jeti DS-16
