Old 06-02-2015, 05:49 AM   #21
Lee2782
Originally Posted by Gregor99 View Post
It was fixed in firmware version 3.31.
***VERSION 3.31 2-24-12*** Fixed MPA internal resistance reading.
If you are still having issues, its typically one of the following:
1) Incorrect wiring type for the balance connector being used.
2) Damaged, worn, corroded, or generally dirty contacts on the balance connector or the main leads.
3) An imbalance of resistance on either the main leads, or the balance connector. A lot of 3rd party boards and cables may have a fuse or LED on either the positive or negative leads, but not both. This causes issues with the IR readings.
EDIT: Example of PL8 showing the correct IR. The user in that thread did found that it was a due to a BuddyRc parallel board. http://www.rcgroups.com/forums/showp...0&postcount=17
Just went over my charger setup and well well well I found I was still in FMA wiring (i'm using Revo SPA charging board)
changed it to XH/EH wiring and all is good now all my cells (on this particular lipo) are around 1.7
feel pretty stupid now
BTW I'm using 3.32
Revolectrix Ambassador
Revolectrix.com 10% Discount All Products Code
LEESS17
Lee2782 is offline        Reply With Quote
Old 06-02-2015, 06:26 AM   #22
Ace Dude
Glad to hear you were able to resolve the issue.
Ace Dude is online now        Reply With Quote
Old 01-23-2017, 04:15 PM   #23
KC8CYF
Default Thread Update for those of us using the Revo MPA board
I thought I'd post this since I spent more than 5 minutes trying to find the answer...
MPA can be used with any Cellpro brand products capable of XH WIRING MODE
I was confused which mode to select today... I assumed FMA mode was meant for the Revolectrix MPA charging boards... I was getting high IR on my last cell regardless of the batteries. Came across this thread and was still confused or missed the answer... But, anyway, the answer is right on the Revolectrix website in the foot notes for the MPA board.
I'm no longer confused and getting correct IR's on all cells now.
I have the latest version 3.33 firmware installed.
MSH Prtos 500
Citizen 358
Outrage Fusion 50 FBL / HW100v3HV / Ikon
KC8CYF is online now        Reply With Quote
Old 01-23-2017, 04:21 PM   #24
lucidchaos
Well it is six months later but the thread was resurrected so ... what the heck.
My end result issue was traces burnt. I soldered wires where the traces went and now my board works like new. If you have to repair traces on this board, keep in mind they are both on the front and back.
dan ░▒▓█ x7 / x5 / 450 pro v2 / 300cfx / 230s night / 2*180cfx / 2*130x / nano cpx / nano qx & 3D / x9503 █▓▒░
lucidchaos is offline        Reply With Quote
Old 01-23-2017, 04:29 PM   #25
KC8CYF
Are you referring to the SPA board or the MPA?
MSH Prtos 500
Citizen 358
Old 01-23-2017, 05:23 PM   #26
lucidchaos
Just the 2s-6s SPA board, non-fused circa 2014.
Old 01-23-2017, 05:26 PM   #27
Ace Dude
The balance lead on the XH SPA board contains polyfuses and is good for 2-8s.
http://www.revolectrix.com/cellpro_adapters.htm
