Old 10-26-2015, 11:05 PM   #61
hemp
BUMP Controller is now available for pre-order!
Limited quantities for early 2016 ETA.
hemp is offline        Reply With Quote
Old 10-27-2015, 12:42 AM   #62
aziz76
Ordered mine
A\ziz - Citizen 672
Henseleit TDR, Minicopter Triabolo 700BE, Minicopter Diabolo 550, SAB Goblin 700 KSE, MSH Prtos Max2
JETI DC-24
aziz76 is online now        Reply With Quote
Old 10-28-2015, 12:48 AM   #63
jetsurgeon
Ordered Mine.....
Jeff
jetsurgeon is offline        Reply With Quote
Old 10-31-2015, 09:59 AM   #64
mkovalcson
It's missing the left Charging platform and a top cover with handle, but it's a start. I'm going for light weight this time.
Mark
2011' Protos 500, 2014' Logo 550SX, 2012' TDR, 2015' Protos Max V2, 2016' TDR2
2013' Jeti DS-16
mkovalcson is online now        Reply With Quote
Old 10-31-2015, 12:47 PM   #65
RevoKelly
Very cool. Really like the idea of the MPA's in the lid and fold-out supports - very innovative design. When you going to start manufacturing those ?
RevoKelly is online now        Reply With Quote
Old 10-31-2015, 01:23 PM   #66
mkovalcson
My last "adventure" in making a charging tower led me down a path of complexity and very labor intensive construction. I really like my battery caddie, but the charging tower while feature rich is too heavy. I did feel like my back was a lot stronger after IRCHA this year
I'm going for light weight and simplicity this time around. I think this one will be an easy one to provide plans for and let people build themselves. After I'm happy with the first one, I expect to at least build a second unit based on plans. That I'll make available.
I've got a enough RCProPlus connectors coming to switch all my batteries and charging cables over.
Mark
2013' Jeti DS-16
Old 10-31-2015, 01:45 PM   #67
pctomlin
Like that you switched to corrugated cardboard, much easier to work with just don't get it wet
Paul
Agile 5.5 - Quantum 4125-1100, Ice 100, Ikon FBL / Outrage 550 - HK4020-1390, Edge 120, iKon FBL
Rave Ballistic FSO - HKIII 4035-560, Ice2 HV160, iKon FBL / Protos Max V2 - MSH 4530-500, Edge HV160, Brain FBL
pctomlin is offline        Reply With Quote
Old 10-31-2015, 02:04 PM   #68
mkovalcson
It works as well as the cardboard Bump controller, PS, Dual PL8's and MPA boards.
I just need some cardboard helis and I'll be all set!
Mark
2013' Jeti DS-16
Old 10-31-2015, 03:07 PM   #69
Gregor99
And so it begins...... again.
Glad to some someone else prototyping with cardboard
Gregor99 is offline        Reply With Quote
Old 10-31-2015, 03:29 PM   #70
mkovalcson
This will be a much quicker affair. I learned a lot last year.
I'm keeping my existing Charging Tower and not cannibalizing anything from it., so this means all new equipment. The bottom line is that I don't get to go to the field as often as I like and the only real pain point for me is charging time and making the charging tower light enough that I take it to the airfield with me.
I fully expect to have all 6 Chargers in action some mornings. I'll just pull my existing charger into another room on a different circuit so I don't overload my breakers
Mark
2013' Jeti DS-16
Old 10-31-2015, 04:24 PM   #71
pctomlin
Looking forward to the next iteration of your charging station, should be another interesting build.
Paul
Old 10-31-2015, 06:32 PM   #72
mkovalcson
Does the Bump have a feature that shows you the total wattage being consumed by all the connected PL8's ??
It would be a great feature to be able to set a max limit based on whether you are running off a generator or at home.
Since this product will encourage people to run many PL8's blowing breakers or melting wires could become more of an issue.
Mark
2013' Jeti DS-16
Old 10-31-2015, 07:59 PM   #73
RevoKelly
Yes, you can always see the total input amps and watts for all chargers on the BC, along with the volts/amps/watts of the currently selected charger.
Being able to set limits for all chargers combined will come in a followup software release - likes like around spring 2016. The plan is to also be able to support multiple power supplies too - so you could specify that chargers 1 & 2 are on a separate supply from 3 & 4, with each supply having different power capabilities, and the BC would control the chargers to stay within the corresponding power limits.
Being able to define multiple profiles (like "home" and "generator" above) would make sense too, although not exactly sure what the other variables might be in play ... for example, would there be a third "battery" profile, and these profiles would also control PL settings like regen discharge enable, limits, etc. ... seems useful to me, but would need to think through the details. I'll add it to our feature backlog.
Old 10-31-2015, 09:09 PM   #74
pctomlin
The Bump Controller is starting to sound like a Swiss Army knife, looking forward to the release.
Paul
Old 10-31-2015, 10:18 PM   #75
mkovalcson
Perfect. I'm pretty comfortable that knowing the watts for all chargers and dividing by the PS efficiency I should be able to keep things safe.
Mark
2013' Jeti DS-16
Old 11-01-2015, 12:24 PM   #76
3Dmuse
I apologize for this off topic question, but what are those red connectors? Have they worked well for you in a 700 class heli? Are they big enough for 8 AWG wires? Thanks.
3Dmuse is offline        Reply With Quote
Old 11-01-2015, 01:41 PM   #77
mkovalcson
Those are PRC6 6mm connectors. 8awg will fit, but not with any room.
They solder easier the EC5's and have worked well in my TDR and the Banshee I used to own.
There is nothing wrong with the PRC6's, but there is no means of inspecting the solder joint.
I'm converting to 6mm RCProPlus connectors for everything except my upcoming TDR-2 where I'm using 7mm RCProPlus, just to be a bit safer with the high current loads I'll be experiencing with speed flying. If I were a smooth flier experienced in speed flying it wouldn't even be a concern for me.
The RCProPlus connectors allow me to easily open the connector and inspect the solder joints at any time, they have a positive lock and they can be reused so while they are pricey they don't need to be tossed when your batteries give up.
Mark
2013' Jeti DS-16
Old 11-02-2015, 11:56 PM   #78
eddiscus
+1 on the RCProPlus connectors.
Switched 2 years ago and have not looked at another connector since.
__________________________________________________
Citizen 142
MA Whiplash 90E, SAB Goblin 700, Logo Xxtreme 800 and Banshee #25.
REVOLECTRIX Ambassador (save 10% on LiPos anytime at revolectrix.com w/ code EDJOHN16)
eddiscus is offline        Reply With Quote
Old 11-03-2015, 04:58 AM   #79
mkovalcson
I've got some work ahead of me...
Mark
2013' Jeti DS-16
Old 11-03-2015, 06:29 AM   #80
eddiscus
Now I know why Amain hobbies has low stock levels.
Citizen 142
