Old 12-21-2016, 06:29 PM   #121
RevoKelly
Originally Posted by krauley View Post
hey on my charge setup the voltage is reading 3 places using the bump. on the pc software with just the pl6 i could set it up for either 2 or 3 decimal places but not with the bump. does this effect charge time? as in when charging to 4.20 i am actually charging to 4.205, is it taking my charger longer to get it accurate down to .205 versus .20?
Display only - no impact on cycle time.
RevoKelly is online now        Reply With Quote
Old 12-22-2016, 08:25 AM   #122
krauley
k cause i spent too much time trying to set it back to 2 places
UH-60 EXI 500 DFC/3GX v5.0 ICE 75 Bec Pro w/4 blade main & tail rotors
Align trex 500DFC Pro w/AR7210bx Align trex 150X
Oxy 3 Tareq Edition AR7210bx Edge lite 50 Kst 215's
PL6 w/Bump Controller-24v PS DX8 gen2
krauley is offline        Reply With Quote
Old 12-22-2016, 09:40 AM   #123
cyclenut
Default Migrating Battery History to a new Tablet
RevoKelly, how do I take the battery History and move it to a new tablet? Hunting around with ES Explorer, I can see all the .hst files sitting in the downloads folder on the internal storage of my old tablet, copying them to the downloads folder on the new tablet didn't work.
--citizen 19-- ama#986265, W8RMB, T-Rex 700n 700e, 600n, 550e, 500 efl pro, 450 pro.. and a couple of planks...I am not a rep for anyone
cyclenut is offline        Reply With Quote
Old 12-22-2016, 10:16 AM   #124
Gus
I think it would be nice if the files were placed in their own folder instead of the "downloads" folder.
Gus (KI7LPX)
Synergy E5s, Goblin 380KSE, Gaui X3, Beam E4, T-Rex 250 Pro, MX-155, CF-226, CF-258, F1-5, F1-6, Chameleon, AcroWhoop V2 (2), Convergence VTOL, SK SlowHawk 2, SK ParkHawk 4, Bionic Bird, CF Wing, ThunderBird EDF Jet.
Gus is online now        Reply With Quote
Old 12-22-2016, 06:27 PM   #125
krauley
revokelley comfirmed that there will be a way to do that in a later to final version of the software in this thread. http://www.helifreak.com/showthread.php?t=716194 look for post #656
i basically asked the same question.
Old 12-22-2016, 09:35 PM   #126
RevoKelly
The files you see in Downloads is just for debugging purposes - the actual history files are in a hidden directory. Downloads will only be used for import/export of .zip backup or .csv files.
Old 12-22-2016, 11:07 PM   #127
cyclenut
Yes, I saw that thread.. but I am faced with the issue of having to now hold on to my old tablet or abandon the history which is not a very satisfying conundrum.
Old 12-23-2016, 07:55 AM   #128
krauley
yeah i understand, i had a few charges and then deleted the app to try to get the bluetooth to connect better and lost them. at least the app/bump have still kept track of the cycles for which im more interested in keeping. i still have history back up for when and if i am able to reuse it.
Old 12-23-2016, 09:11 AM   #129
RevoKelly
Definitely do history Backups occasionally - youll be able to use them soon to restore ... Jan/Feb timeframe.
Old 12-30-2016, 02:30 PM   #130
krauley
Looks like they snuck in an app and bump update. I'll let kelly give the details but for those that want to do it now. It's out there.
Old 01-11-2017, 11:03 AM   #131
potrzebie
Default Multiple packs setup mode?
Is the CCS app going to be able to deal with the Multiple packs
parallel/separate choice soon? Once the bump is configured the CCS has all the other required functionality to take over the bump GUI.
Without going to separate tags for each battery this alone is keeping me
from putting the bump out of sight in my new charger case build.
potrzebie is offline        Reply With Quote
Old 01-11-2017, 06:10 PM   #132
RevoKelly
Honestly, its not very high on our priority list so likely to be several months. Im not sure i would recommend completely burying the Bump - not to say it shouldnt work, but we are not really prioritizing/optimizing for that use case so if issues popup, it could take longer for features/fixes. Would also make troubleshooting difficult if u run into any issues with Bump/app interaction.
Old 02-07-2017, 08:06 PM   #133
gtrsteele
Can anyone tell me what the balance bypass % represents?
gtrsteele is online now        Reply With Quote
Old 02-07-2017, 08:48 PM   #134
RevoKelly
Its how.much the balancer is currently bypassing that cell - which means some charge current is getting bypassed around the cell so less current is flowing into that cell. This is the core of how balancing works - it allows the other cells (with lower voltage) to "catchup" to the higher voltage cells (which are being bypassed to some degree).
Old 02-08-2017, 06:27 AM   #135
gtrsteele
Makes sense. I notice the status bars next to each cell voltage readout are highest level when the bypass is highest. Are the two related because I would have thought the higher the bar readout the more current is being put into that cell?
Old 02-08-2017, 07:24 AM   #136
RevoKelly
Inversely related - higher balance bypass % means less going into cell. It would be possible to show it the other way, but it gets a little more complicated since the balancer is limited to 1A - the current flowing into the cell = charge amps - (bypass% x 1A). Showing actual amps per cell, as well as capacity per cell, is something we can derive from bypass% - its on our wish list.
Old 02-24-2017, 03:15 PM   #137
RevoKelly
Just an update on the Apple iOS version of the CCS app ...
We have submitted the request for public posting of the app, so once we fix whatever Apple doesn't like, it will be ready for download.
Once it's available on iTunes, I'll post here again.
Old 02-25-2017, 01:10 AM   #138
aziz76
My iPad Mini is ready
A\ziz - Citizen 672
Henseleit TDR, Minicopter Triabolo 700BE, Minicopter Diabolo 550, SAB Goblin 700 KSE, MSH Prtos Max2, MSH Prtos 380
JETI DC-24
aziz76 is online now        Reply With Quote
Old 02-25-2017, 09:51 AM   #139
cudaboy_71
perfect timing. just finished my charger case in time for the flying season. just need to get the iOS app to be complete.
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı
cudaboy_71 is online now        Reply With Quote
Old 02-25-2017, 07:11 PM   #140
larryfl
I was charging today using my dpl8/bump
Meanwell power supply and generator
I had trouble getting the unit to ramp up the current as I received his message
Low volt restore chg
What does that mean? Amperage went down greatly and power supply and generator still had plenty of capacity
Thoughts?
larryfl is online now        Reply With Quote
