Old 12-17-2016, 07:33 PM   #1
lmcwilli
Default BUMP interface cable: proper polarity with a PL6
Establishing the proper polarity on the BUMP side of the interface cable is easy: black on the right (when viewed from the top front). And the BUMP displays a multi-color graphic on its start panel.
Proper polarity for the PL6 data port side of the interface cable is not so obvious.
Page 7 of the BUMP User Guide says:
"Proper polarity for each PowerLab data port side of the cable (listed as “TO PC”) is illustrated on every PowerLab top panel label and varies from model-to-model."
However, what's written on the top of my two PL6's is inconsistent: one says: G+S TO PC, the other says S+G TO PC. Same model, but different polarity information on the top.
From trial and error it became clear that G+S is the required polarity for both.
The documentation could use some clarification on this point.
ID:	684634   Click image for larger version
Blade 450X, Witespy Quad, Gaui X3, Gaui X5, Goblin 570, Goblin Black Thunder
lmcwilli is offline        Reply With Quote
Old 12-17-2016, 10:13 PM   #2
jrman83
You could have walked that info in. Aren't you like minutes away from the RevoUSA store?
-Ben
SAB Goblin 380/420/500S, Stretch m-Protos; Custom 360CFX; (2) Oxy 3+; (2) Blade 230s; DX9
jrman83 is offline        Reply With Quote
Old 12-18-2016, 02:16 AM   #3
lmcwilli
Yep. Ten minutes away at most.
Old 12-18-2016, 09:35 AM   #4
RevoKelly
Thanks. Ill add that to the todo list for manual updates.
RevoKelly is offline        Reply With Quote
