Old 12-18-2016, 02:08 AM   #1
raptor90wm
Default Bump tag setup, what is charge max c
Like the title says, what should I put in for this as I not really sure?
A friend of mine told me on my 65c pack to put in 40c for this setting, as it's more the true c .
No idea if I should have done that, but I did
Citizen 584
Raptor E700, scorpion, helijive, BD 3sx. Trex 700N BD 3x, Trex 550 helijive BD 3x. Gaui X3, scorpion, hobbywing, BD 3x. Blade 300cfx BD 3x base
raptor90wm is offline        Reply With Quote
Old 12-18-2016, 08:16 AM   #2
aziz76
That is the upper limit for charging current. Typically not more that 5C for most packs. 40 is definitely way too high. You would never charge at 40C.
A\ziz - Citizen 672
Henseleit TDR, Minicopter Triabolo 700BE, Minicopter Diabolo 550, SAB Goblin 700 KSE, MSH Prtos Max2
JETI DC-24
aziz76 is online now        Reply With Quote
Old 12-18-2016, 08:20 AM   #3
jrman83
Your title says charge max C. This is the max charge rate you want to charge your batteries. Factory recommendations are 3-5 or so. I choose 2C.
The other C is the c-rating of your batteries output. Can't really say for sure, but don't think it really matters what you put in the bump tag info or charger. It is just a data point I believe, but I would put in what the label on the battery says.
-Ben
SAB Goblin 380/420/500S, Stretch m-Protos; Custom 360CFX; (2) Oxy 3+; (2) Blade 230s; DX9
jrman83 is offline        Reply With Quote
Old 12-18-2016, 09:46 AM   #4
KevinB
Put in what the label says as the max recommended charge rate. Ie: Pulse and GensAce are 5c max.
The setting just prevents you from exceeding the recommended max rate when setting up a charge. It doesn't mean you can't charge slower. My 'normal ' charge rate that I usually use is 2c. My max limit is 5c for most of my packs but I have never used that fast of a charge.
Also, this setting can't be changed once written to the BUMP tag. If you set this to 2c, the BUMP will prevent you from charging any faster.
KevinB
KevinB is offline        Reply With Quote
Old 12-18-2016, 09:46 AM   #5
RevoKelly
The max charge C is the max rate the manufacturer recommends charging the pack. Most packs say it on the back label. If u cant find it, use 1/10th the pack C rating (the max discharge rating). This is also the default value the Bump generates for you.
Note that this value sets the upper limit, so dont set it artificially low - your settings values adjust how u prefer to charge it.
RevoKelly is offline        Reply With Quote
Old 12-18-2016, 11:24 AM   #6
raptor90wm
Totally my fault but I worded this incorrect but I meant the pack max, like the pic shows.
My buddy says if a pack says 65c but not to put in that as the pack max, as that's not the true pack max C As these are always false
Citizen 584
Old 12-19-2016, 09:02 AM   #7
jrman83
I saw that it uses it as the default charge rate. I will never charge above 2C, regardless of what the pack is rated. Just would not have the need to charge that fast.
-Ben
Old 12-20-2016, 09:39 PM   #8
Ace Dude
I charge at 3C nearly all the time.
Ace Dude is offline        Reply With Quote
Old 12-21-2016, 09:53 AM   #9
Dansy
Same here I charge at 3c 100% of the time.....unless I have too many batteries to do at once and I'm restricted by my generator/PS output.
Daniel...many flying planks.....Goblin Urukay Red/White, Gaui R5
Goblin 380 KSE Yellow/Blue, Goblin 420 XNova
JETI DC-24, MKS Servos, Ikon2/Brain2, Axon, Kontronik, XNova
Revolectrix/MeanWell PS, DPL8, PL8, 2x XP10 and Bump Contr.
Dansy is offline        Reply With Quote
Old 12-21-2016, 10:05 AM   #10
Ace Dude
The only time I'm not charging at 3C is the first few break-in cycles, if they've been sitting unused for an extended period, or if they are cold (Winter flying).
Old 12-21-2016, 03:23 PM   #11
Dansy
During winter I charge in my heated garage before going flying.....I have a bench by a door....I can chuck them out if I see something wrong.
I do cycle them 3 time at 1c before using them.
