Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4#3, 4#3a, 4#3b, 4#3Q
4#3, 4#3a, 4#3b, 4#3Q Walkera 4#3, 4#3a, 4#3b, 4#3Q Helicopter Support
Old 12-16-2008, 05:10 AM   #21 (permalink)
Hi guy's
Did the "swash gleued to the shaft" mod and the heli became dosile, thanks for the tips
Erwin
Anything that flies
Ber60 is offline        Reply With Quote Quick reply to this message
Old 12-16-2008, 12:15 PM   #22 (permalink)
Glad it worked for you, it's the first thing I do when I get a new 4#3 or fit a new shaft
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote Quick reply to this message
Old 12-16-2008, 06:48 PM   #23 (permalink)
Did some further modifications :
pic 1 : coppertape for cooling the motor
pic 2 : to remove horizontal slack of the flybar (I don't like slack/play )
ID:	72723   Click image for larger version
Anything that flies
Old 12-16-2008, 08:00 PM   #24 (permalink)
So i got mine today, this thing is too much fun. One thing is on the tail trim, i almost have it completely to the left because the tail wants to to move. Anyone elses like this?
XLPower Nimbus 550 (x2)
VControl
CagedVR6 is offline        Reply With Quote Quick reply to this message
Old 12-16-2008, 08:01 PM   #25 (permalink)
awesome mods Ber60! Can you explain a bit about the mod on pic 2... how does bending one of the holders remove the horizontal slack of the flybar?
Steve Joblin is online now        Reply With Quote Quick reply to this message
Old 12-17-2008, 02:08 AM   #26 (permalink)
I'll try: when you hold the head the flybar can move in the horizontal plane, the links from the Fbar to the SWplate pivot at the holders, bending one of the legs at the same side prevents that pivoting motion and removes the slack on the Fbar
Anything that flies
Old 12-17-2008, 02:14 AM   #27 (permalink)
I like the sound of that. Does the metal bend easily enough? How much difference does it make?
Many thanks
Dusty
Old 12-17-2008, 02:18 AM   #28 (permalink)
Tail motors, like main motors seem to vary in quality a bit. Some work better than others. I quite often find I need a different trim setting for the rudder for one tail motor, as I did for the last one, though I find usually that the trim needs adjusted towards the right.
I'd say so long as there is enough trim to hold the tail then don't bother about it, the tail motor won't last forever anyway, and the next one will probably be different
Old 12-17-2008, 02:48 AM   #29 (permalink)
Many thanks
Dusty
Did it with long nose pliers and it bends easely enough, in stead of 5mm play or + I've reduced it to 1mm
Anything that flies
Old 12-17-2008, 12:36 PM   #30 (permalink)
Changed an other modification : fastening those loose blades.
My dexterity isn't so good anymore (like my hearing ) so I've simplified the washer method, I heated my smallest screwdriver and made a "burr" at the root of the blade. Now a have a bit of friction on the blades just like a 3D heli
Anything that flies
Old 12-17-2008, 04:14 PM   #31 (permalink)
Just a test flight with the mods, a bit dark I know
Anything that flies
Old 12-17-2008, 07:46 PM   #32 (permalink)
Nice Pad Ber
perry59 is offline        Reply With Quote Quick reply to this message
Old 12-19-2008, 09:13 PM   #33 (permalink)
Got mine, prob around 20 flights and 50 crashes, only a few broken things, none big enough to make it not flyable while waiting for parts. I love this thing
VControl
Old 12-20-2008, 01:09 PM   #34 (permalink)
Where can you get a screw driver small enough for these?
VControl
Old 12-20-2008, 01:21 PM   #35 (permalink)
This works for everything on a 4#3.
http://www.grandrc.com/inc/sdetail/49604
Best screwdrivers I ever owned. The rotating tip is a must, because those tiny screws are gone the second you start to shift your grip.
T-Rex 600NP, T-Rex 500 ESP, HDX500 SE V2, HDX450 SE V3, T-Rex/Outrage SE V2, EXI450, T-Rex 250, CopterX/Guru-Z hybrid, HBFP separates, Lama V4, 2 x Walkera 4#3B
another_finn is offline        Reply With Quote Quick reply to this message
Old 12-20-2008, 01:25 PM   #36 (permalink)
+1 to another_finn... Wiha are awesome tools.
The "official" proper size is a #000, but you can use a #00 if that is all you have.
#00 sized phillips are common in most "micro screwdriver kits". Look in the "tools" section of any hobby website. Home Depot, Lowes, Sears Hardware, and ACE all sell them to. You can also do an ebay search for "micro screwdrivers".
I'm one of the guys that was raised with a "Craftsman" shop, so I am always a bit partial to Sears... http://www.sears.com/shc/s/p_10153_1...0070921x00003a for $3.00
i also like to support small businesses, so I will also throw a shout out to MIA MicroFlight who is selling a #000 screwdriver... scroll down a bit on this page http://www.micro-flight.com/Walkera%204-3.htm for $8.00
Old 12-20-2008, 02:31 PM   #37 (permalink)
Thanks.
Another Photo :]
Bent front linkage :[ haha
VControl
Old 12-21-2008, 03:21 AM   #38 (permalink)
And every local good electronics shop carries them
Thanks perry59
Anything that flies
Old 12-21-2008, 07:30 AM   #39 (permalink)
I've tried this elastic mod suggested by Bloodholds this is a mod that realy gives an instant difference in control.
The only downside is that to get the small elasic bands some of my wife's panties will drop to her knie's
Anything that flies
Old 12-21-2008, 10:15 AM   #40 (permalink)
Hey,
I have seen this a long time ago on some F3C machines, I think even the likes of Wayne Mann tried this many years ago.
But, knowing what your trying to achieve by doing this mod, eg. removing any slop, I dont think it works in this configuration to remove any in all honesty.
I can't see if there is a rubber band on the rear of the swashplate where there is no link supporting the swash, if there is one then great this is where this type of mod will help but not on the links unless yours are very loose?
Ian Contessa
Coolice Charge Cases & Power Supplies
Facebook Page
Coolice is offline        Reply With Quote Quick reply to this message
