450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
12-20-2012, 02:49 PM | #1 (permalink) |
450 Sport V2 to DFC issue
Hi,
I have another issue with this conversion, because of the new main shaft which is shorter the swashplate linkage rods are too long, anybody had same issue or I am doing something wrong? should I just cut them down to shorten them or buy new ones?
Trex 450 Sport V2 TT FBL SK 540 DX6i |
12-20-2012, 03:14 PM | #2 (permalink) |
They need to be 10.5mm long- measured from the metal bar length position.
I would get new ones from the PRO DFC so they are factory built with tight, new heads. |
12-20-2012, 03:18 PM | #3 (permalink) |
The sport v2 and the pro v2 has different servo setup. For the sport v2 I have three different rod length.
12-20-2012, 03:23 PM | #4 (permalink) |
Oop.. My bad..
They are 15mm 21mm and 9mm. Didnt your upgraded head come with the instructions? |
12-20-2012, 03:29 PM | #5 (permalink) |
I tried to attach the instructions..
12-20-2012, 03:30 PM | #6 (permalink) |
It did, but the rods are way too big, that is why I asked if I should cut them with dremel.
12-20-2012, 03:35 PM | #7 (permalink) |
I see... You could buy the replacement links for the PLUS DFC... It has the same servo arrangement and same length drive shaft.
12-20-2012, 03:44 PM | #8 (permalink) |
Regardless of the DFC shaft length, your servo to swash link should not change unless you have it set up too high before DFC conversion. DFC shaft is shorter since there is no room needed for swash follower.
Have you tightened the linkage all the way and they are still longer than the instruction length? |
12-20-2012, 03:46 PM | #9 (permalink) |
Got it, Sometimes you just have to read...
Thanks guys!!
