SR Blade Helicopters (eFlite) SR |
09-02-2013, 03:11 AM | #521 (permalink) |
Thanks Ed, the times I wish it was at the bottom of a canal....
Ok I will try the gain. One handy tip I picked up yesterday was to adjust the tail manually and not have any trim set. That has made a big difference, but still needs fettling, so I will have a go at the gyro gain. It is on lowest setting, so will see if turning it up makes a difference. Not confident, but will give it a crack. Belt tension has been checked. Having read about how the bigger helis are more stable, I am thinking about going up in size. It never ends, does it? Last edited by VicSR; 09-05-2013 at 11:59 AM.. |
09-11-2013, 12:00 PM | #522 (permalink) |
Been thinking of doing this conversion as my SR's head is sloppier than a pig in mud and it has never really flown right. I'm confident I can build the kit and get it right, my question....could this be done with blade cp pro 2 guts? I've got a cpp2 that's complete just in pieces. The brushed motor should be up to the task I would think? I'd rather buy 2 of these kits and make the SR version a FBL bird than replace yet another main board in my 130x. Love that little heli but it's a picky little thing.
Also, anyone used a 300x canopy on this kit? Would it fit at all or even look decent? Ill be using the 1000mah 3s packs so I know the hk canopy won't fit (ugly anyhow) |
09-29-2013, 08:47 PM | #523 (permalink) |
Hey! I just built the kit and got everything working with the stock TX. Question though. Should I have the gyro set as DS tail Servo or normal?
10-01-2013, 11:01 AM | #524 (permalink) |
DS if you use digital tail servo.
08-25-2014, 09:35 PM | #525 (permalink) |
Servo question
I removed everything from my SR and hooked everything back up before installing into the HK 250. Esc works, motor works, gyro lights up. The only servo that will move is the one on the aileron. This servo moves for throttle, aileron, elevator & aux 1. Doesn't move for rudder. This surely isn't normal? Using the same radio settings.
Thanks |
