Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Old 01-17-2016, 07:00 AM   #1 (permalink)
Default Atom 5.5: too fragile Main Gear?
Yesterday I had, for the second time, my 5.5's Main Gear sheared while trying to recover from a poor auto by engaging the Bail Out. Fortunately I managed to land the heli smoothly both times!
I can, of course, reduce the Bail Out speed, but this will make it almost as slow as the regular spool-up.
Maybe the 5.5, as floaty as it is, doesn't need Bail Out at all. But my impression is that in the 5.5 the Main Gear is working very close to its limits!
Does anyone else has such an impression?
Cheers!
Compass 7HV / Atom 6HVU / Atom 5.5 / Align Trex 500L / Spektrum DX8
Not flying anything - model or full - since 2017!
ARM_Coder is offline        Reply With Quote Quick reply to this message
Old 01-17-2016, 10:07 AM   #2 (permalink)
I chewed up 2 main gears recently. I called Tony and he said the yellowish gears are better than the snow white gears. It's been colder here in Ohio and maybe I've been getting better. But yes, I think we got a bad batch of gears. Hopefully compass will fix the next batch but I doubt it. Just stock up and keep flying!
This is gonna cost me.
aburkhardt is offline        Reply With Quote Quick reply to this message
Old 01-17-2016, 10:31 AM   #3 (permalink)
I am still using the original yellowish gear but I do think the Atom 5.5 is definitely harder on the gears than the regular Atom. When mine was new, I noticed white plastic residue accumulation in the CF around the pinion area every 5 or so flights. I did not notice this on the Atom 500 with the same gear. I fixed the issue by using White Lightning Wax based bicycle chain lube on the main gear. I am using the stock 9T pinion on my Atom 5.5.
XLP Specter NME | Oxy 5 550, 5 HF 560, 5 HF 610 | Compass Chronos, 7HVU, 550U, Atom | Gaui X3
cyclo is offline        Reply With Quote Quick reply to this message
Old 01-18-2016, 06:16 AM   #4 (permalink)
I rebuilt my 5.5 yesterday, but all 5 gears (now 4) I have in stock are the "Snow White Edition". So no abuse is allowed.
I don't think temperature plays a role here, because it's summertime here in Brazil. Although an untimely cold front arrived and cooled the weather a bit, it's still balmy here.
I'm using the 9T pinion and Rotortech 515 blades. The pinion may play a role here, since the 5.5 upgrade kit brings a 8T. Perhaps the guys at Compass realized that the stretch kit was too hard on the gear, and opted to alleviate this reducing the pinion. But the HS yielded with the 8T is too low for my taste, and I suppose that's true for most.
The 5.5 is a kit that definitely demands a black helical gear IMO. Just to compare, the Trex 500L has such a gear, in a diameter bigger than the Atom's, and a higher KV motor to make up for the larger diameter. In this sense, the Atom is really dated.
I'm sad that Compass could simply upgrade the Atom (helical gear, CF pushrod, better fixtures for the canopy, new tail case and rotor) instead of trying to release a brand-new 500 that's taking forever to show up and is not stretchable AFAIK.
Cheers!
EDIT: Hey Atom fans, we could start a petition to Compass: Please make the Atom 500 Ultimate, based on the current model, just with the so needed upgrades!
Old 01-19-2016, 08:42 AM   #5 (permalink)
I can't say I ever had a problem with the main gear and I was running the 4025 up to 3000 headspeed with 515mm blades at 14 pitch. I did crack the main frame from all the torque, but no stripped gears. Not sure if I had these white ones though.
Q700
RCHN #232
quinn is offline        Reply With Quote Quick reply to this message
Old 01-19-2016, 09:31 AM   #6 (permalink)
Cheers!
I do think a helical gear set would be a very good solution. More contact area between the pinion and main, and better meshing always helps in gear train stability.
SoXoS Strike 7.1 (x2) | Miniature Aircraft Whiplash Nitro NII | Miniature Aircraft Fury 57 | Blackout Mods : ??????
Teams: Aero Panda, Heli-Professional, SoXoS USA, 1ST RC, Xpert RC USA, Pulse Battery, iKon Flybarless, Blackout Mods USA
PowerDyne is offline        Reply With Quote Quick reply to this message
Old 01-20-2016, 07:20 AM   #7 (permalink)
let's hope they keep producing the straight cut gears, I for one don't fancy paying $75 for a pinion and main gear.....
AMA#1058309
Mon_t is offline        Reply With Quote Quick reply to this message
Old 01-27-2016, 09:41 AM   #8 (permalink)
Helical gears have not to be that expensive. Think about Align. The problem is that Compass uses Delrin instead of nylon, hence the high price tag.
Old 04-14-2016, 06:40 PM   #9 (permalink)
I keep breaking them. :/ This one appears to have bubbles in the plastic.
Old 04-14-2016, 08:57 PM   #10 (permalink)
What do you guys think about pinions?! I love the 10T but I'm wondering if I should drop to the 9T. Tony ran this with 473mm blades at 3000+ rpm. I'm running cyclone 505mm closer to 2600 rpm.
Old 04-14-2016, 09:22 PM   #11 (permalink)
I am running the stock 9T with 515mm blades on my Atom 5.5 with the stock 1100kv motor... I am running at 100% throttle ungoverned. With this setup it is fast and responsive enough (though not as fast as my 550U at 2400 rpm governed).
I never had a problem with the Atom main gear but I do lube it with White Lightning bicycle chain wax lube after I initially detected white plastic flakes in and around the pinion area.
Old 04-16-2016, 07:29 AM   #12 (permalink)
When I replaced it this time I did use a dry lube. Maybe it will last longer. Going to the field today, threw a 9t in my toolbox. Mesh seems good.
