Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 02-25-2014, 07:58 PM   #41 (permalink)
FYI,
For the Diabolo S application you SHOULD NOT use the regular Pyro. They cannot stand the heat buildup due to the power delivery in the tight fuselage or canopy.
No problem for a motor like the HK4540 signature series which BTW runs very cool, or the outstanding black Comp Series Pyro.
Santiago
Team Minicopter www.PeakAircraft.com
Team Kontronik
Scorpion Power Systems - Bavarian Demon
plankdriver is offline        Reply With Quote Quick reply to this message
Old 02-26-2014, 09:10 AM   #42 (permalink)
CHC Benefactor
Default Pimp my Speed heli :)
Going with:
14s 4400 Revo 60C's and 14s 4800 Revo 70C - seeing if extra mah's help power
Kool Kosmik 200A BEC 8.0V - with fan?
Red Devil HC3-SX LE
Futaba R7003SB receiver
DH 711 blades (crossing fingers)
JLog 2.5
2s 325 TP 65C Buffer Pack
Now for the pimping:
Futaba BLS272SV .08 sec 12kg or BLS175SV .12 sec 21kg - 36.8mm selection if no room
Futaba BLS275SV .07 sec 15kg or BLS177SV .11 sec 37kg - 38.4mm selection if room
Futaba BLS276SV
Pyro 800 GMauro 500kv or 4540 PowerCroco 473kv - suggestions?
Raptorapture is online now        Reply With Quote Quick reply to this message
Old 02-26-2014, 11:30 AM   #43 (permalink)
Be aware Futaba R7003SB receiver is problematic.I lost one of my TDRs because of that receiver. I ordered DH 711 last night. What's wrong with them? please let me know if any of you guys had issues with them.
Link to R700SB .
https://www.helifreak.com/showthread.php?p=4905043
Thanks.
firemedic295 is offline        Reply With Quote Quick reply to this message
Old 02-26-2014, 12:16 PM   #44 (permalink)
CHC Benefactor
Link to R700SB .
Thanks.
Thanks. Aware of the receiver issue. From what I can surmise it is related to VBar going with reverse logic as to which direction to pull the line while no signal. Only seems to need attention if used with VBar. I've also got a 7008 but I've got four of these and need to put them somewhere... I could get a cheap scope like Mark and check it out myself...
No issue that I've heard of on DH 711's (edit: except Marcos had on his Banshee). Just crossing my fingers that Gerd shipped the S with them
Old 02-26-2014, 12:49 PM   #45 (permalink)
My S came with them.. The 711's.
craigdieselmac is offline        Reply With Quote Quick reply to this message
Old 02-27-2014, 09:29 AM   #46 (permalink)
CHC Benefactor
My Diabolo S arrived with DH711's as well
In addition I've received a 20T pinion which I've decided to pair with the 4540-473kv which Mr. Mel says will give around 2200 governed on Kosmik @80% and 2500 @90%. What should be the target headspeed for speed runs? I guess I'm looking for 2 values, one "safe " and one "going for it."
On the servos, I tried the MKS, they look to need an additional 1mm each with no grommets. Therefore going to attempt 38.4mm depth Futaba servos.
Cheers.
Old 02-27-2014, 09:54 AM   #47 (permalink)
I put Torq's on mine. I had to shim the elevator servo to fit, but so far, everything else is good. I slid the canopy over the servos and they don't rub, but i have not done a full installation of the canopy with the rear fuse on, I should get there this weekend or later on next week. My build thread is on RR if you would like to see pics.
Old 02-27-2014, 10:33 AM   #48 (permalink)
CHC Benefactor
I was probably referring to your post. I get confused sometimes which site a thread is on
No wonder Gerd hasn't answered yet re space available, I haven't logged in!
Old 03-04-2014, 04:14 AM   #49 (permalink)
Just to add to my torq disclaimer.. The cyclics do hit each other on the inside of the mechanics.. One could live with this or file down the cases on the corners that touch, which is what I'll do since i have mine installed with the entire fuselage on and everything fits
How much pitch is everyone going with? I set mine up with 16, but I'm new to speed, is this necessary... Do I need less.. More?
Old 03-04-2014, 04:18 AM   #50 (permalink)
15-16 sounds about right to me
Sent from my GT-I9305 using Tapatalk
Darcy Brown- ZenRC Field Rep
RED! Goblin 500, Quantum 4120-1200, BK Servos, from www.zenrc.com.au
ORANGE! Goblin Speed, Kosmik Kool 200HV, Pyro 850-50L, BK Servos, Brain
NevErSn0w is offline        Reply With Quote Quick reply to this message
Old 03-04-2014, 04:44 AM   #51 (permalink)
But it all depends on the swash and head of the Heli, some can handle 16 ( I know fpr a fact the goblin speed can) but some can only handle 14
Old 03-04-2014, 04:50 AM   #52 (permalink)
Default Diabolo S setups
Max 16 seems the rule
helicraze is offline        Reply With Quote Quick reply to this message
Old 03-04-2014, 05:07 AM   #53 (permalink)
Thants what I thought, because once you go over that you start become in efficient
Old 03-04-2014, 05:52 AM   #54 (permalink)
Ok.. I'll use 16 as my starting point and dial back as necessary.. Thanks!
Old 03-04-2014, 05:55 AM   #55 (permalink)
Default Re: Diabolo S setups
Sounds good!
Old 03-04-2014, 06:00 AM   #56 (permalink)
HF MR Support
Craig,
If this is the first time you are running speed, stay at 14 max on vbar for now. That's plenty especially on the Diabolo S. She will get away from you very fast. Once you are comfortable then go to -6/+16.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 03-04-2014, 06:46 AM   #57 (permalink)
That's a good idea.. I would imagine she is going to be a little faster than my Goblin.. And that thing is fast. It's running the world speed scorpion 4530-540.. She cooks across the field. We have a huge open sod farm.. It's hundreds of acres of golf course putting green grass.. Awesome place to fly and learn speed runs. I have been practicing with the Goblin and on the Sim.. Thanks again for the advice, I will tune it down.
Old 03-04-2014, 06:49 AM   #58 (permalink)
Originally Posted by TommyBear View Post
Craig,
+1
Old 03-04-2014, 07:24 AM   #59 (permalink)
I can't go back an edit my original post, but my motor has changed slightly. It will now be:
X-Nova XTS 4530-525 4+5YY
_____________________
JRAY is online now        Reply With Quote Quick reply to this message
Old 03-04-2014, 07:27 AM   #60 (permalink)
HF MR Support
Same here Jason.
SAB speed blades will not fit Diabolo S so don't waste your money.
Lynh
