Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > 2.4G Futaba Radios
2.4G Futaba Radios Futaba 2.4G Radio Help and support forum
Old 05-07-2011, 01:33 PM   #1
ebonicrobot
Default 7C and MultiGov Pro
Hello everyone I have a quick question regarding the Multigov Pro. Ive searched and searched and couldnt find anything, On Finless setup vids he used the 9303 and dx7 transmitters. I have a Futaba 7C and im trying to use the rpm selct feature. On the Align gov the rpm select uses one wire, I beleve its a yellow one. Can I do the same with the Multigov? My plan is to use one signal wire and plug it in with my battery wires in the channel 7 port since the battery only uses a black and wires leaving one port open. Im trying to configure everything with using the least amont of y connectors possible. Im already using one for my SwitchGlo for my gyro gain channel.
Avant Aurora FBL, YEP 120/700MX 510kv, Cyclic S9255 CGY750/9254
JR NEX E8, YGE 90/700MX,Cyclic DS610,BeastX/DS650
Trex 450 DFC 3S, YEP 45/450MX,Cyclic DS95i(clones), BeastX/8910a+,
Frenzy 90(UNDER CONSTRUCTION)
ebonicrobot is offline        Reply With Quote
Old 05-08-2011, 02:18 AM   #2
Jafa
Yes - that will work
Rave 450 | Lepton | Logo 400/500/600 | Aeolus | Sceadu | Freya | Avant FX | Raptor G4
Gryphon field rep
Jafa is offline        Reply With Quote
Old 05-21-2011, 08:05 AM   #3
AMIT MOHAN SHARMA
You can give power to any of the ports on MULTIGOV and it will power the RECIEVER as well...
AMIT MOHAN SHARMA is offline        Reply With Quote
