Go Back   HeliFreak > R/C Helicopters > Contest Flying
Contest Flying Contest Flying F3C/AMA
Old 07-10-2011, 01:07 AM   #1 (permalink)
Default Blitz-Avro 90- on the way!
I decided to jump in. I bought a Blitz-Avro 90 kit and have started to put together components. All my practice has been with my T-Rex 700N and anxious to try a dedicated F3C machine. I'l be using Futaba S9452 for cyclic and throttle with a Futaba GY520 gyro and a Futaba BLS 251 on the tail.
I've had good results with the OS 91HZ-R w/ hatori pipe with my Trex700 so I believe I'll stick with OS
I initially wanted a Sylphide but I found excellent support for Blitz parts and tech info in California. Helos Aviation Technologies. Its going to be an interesting journey.
T-Rex 700 Nitro ,BLITZ AVRO 90, M.A. Fury 55FBL, SAB Goblin 700, T-Rex 500, T-Rex 250,T-Rex 600E DFC, Outrage Velocity 50V2
Arclight338 is offline        Reply With Quote Quick reply to this message
Old 07-10-2011, 01:03 PM   #2 (permalink)
Nice!
Some build pictures would be appreciated. I´ve always been curious about this heli but never had the guts to try one since botique helis somehow seems to disappear of the chart after a period of time.
Love the design of the avro for sure!
tomra is offline        Reply With Quote Quick reply to this message
Old 07-16-2011, 05:33 PM   #3 (permalink)
Got the Blitz build finished. Roughly 20 hours or so. OS 91HZ-R 3C w/hatori pipe. Ready to maiden this week. The header tank is only for additional fuel capacity. For what its worth the factory idle mixture setting was @ 12 oclock and WAY TOO RICH. Once adjusted the motor ran very sweet. Added the additional .2mm shim. Running 30% Nitro.
Last edited by Arclight338; 07-22-2011 at 12:56 AM.. Reason: Additional build photos
Old 07-18-2011, 12:41 AM   #4 (permalink)
Very beautiful!
So nice to see an avro. Any hickups during the build? Machining quality?
Old 07-18-2011, 03:36 PM   #5 (permalink)
Originally Posted by tomra View Post
Very beautiful!
Absolutely flawless.( My one and only complaint is the canopy is fiberglass but NOT gel-coated and quite fussy to prepare for paint,which is a work in progress) The component quality is exceptional.
Not only do you receive an assembly manual, bound and very well written- you also get a setup manual to guide you through various ways to setup the head linkages for stable, sport/3D and extreme 3D.
Old 07-31-2011, 06:46 AM   #6 (permalink)
Maiden flight was flawless. I love this machine!!
Old 08-18-2011, 06:44 AM   #7 (permalink)
Blitz Avro 90 update. I've put about 5 hours of flight time on this machine. The OS 91 HZ-R "Speed" 3C has become VERY problematic. Exceedingly rich at all times. Rechecked the complete fuel system on the heli-no issues. Changed plugs. OS #8 to Enya #3-no change. Fuel consumption is unreal.
Finally, I pulled the motor out. All issues were resolved with a very simple change. A NEW YS 91 SRS3D and Hatori SB19. Breakin was flawless, on CP 30% this engine runs like a dream. Tuning was simple. The power increase is amazing, and of course not running puking rich its quiet,controllable and I don't need to practice my auto's-unless I WANT TO.
I called OS- this motor is NOT under warranty. This of course was of no concern to me since I've had good luck with my other OS engines. Tech support was of no tech help. They said "send it in-we'll check it out for you".
....For $20 initial exam fee and then $40/hr and parts,plus shipping back. Uh, yeah.
I stripped the motor, the piston, ring and liner were ok. The wrist pin was rusted so bad there was little lateral movement-in fact it was hard to remove the rod from the crank until I soaked the pin with penetrating oil. This was probably a result of being flooded with so much fuel as well as flying in very humid wweather-maybe.The carb was free of debris and "appeared " to have been machined correctly.
, when I took the regulator apart, I found the diaphragm was installed upside down! In fact, I was so surprised, I took another of my HZ-R's apart to confirm this. Is this why the engine ran poorly? I have no idea. I reassembled the engine and put it back into the box, sooner or later I'll give it another try. Although NOT in my most valuable heli. OS lost a customer. The YS is my first and not last.
