Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 03-02-2012, 04:23 PM   #1 (permalink)
Default Loose blades - what is the solution?
Hi there,
I have the radix blades on my heli, there is no way to tighten the bolts more then they are right now - and the blades are still not strong enough for an autorotation bailout - What is your guys's solution to that?
Elad.
Henseleit TDR!
Trex 800E F3C; Trex 550FB
I have no life anymore - only heli's in my head..
wonderd is offline        Reply With Quote Quick reply to this message
Old 03-02-2012, 04:52 PM   #2 (permalink)
Are you using the black blade spacers that came with the kit ?
I've had blades in the past that had their brass bushings not installed correctly (not flush with the rest of the blade). That does make them really sloppy even when tight really well but sounds like a wild shot if you're having this on both blades, wouldn't hurt to check though.
With great power comes great voltage times great current !
zmooth is offline        Reply With Quote Quick reply to this message
Old 03-02-2012, 05:36 PM   #3 (permalink)
Using the black spacers included in the kit and the brass inserts that came with the Radix blades seemed to snug up really well for me earlier today.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is online now        Reply With Quote Quick reply to this message
Old 03-02-2012, 09:48 PM   #4 (permalink)
I am using SpinBlades Matt Black with their bushing and white spacers and I have to tighten more than on other helis. I thought the TDR was like that since I have not tried any other blade other than these. I am able to get them medium tight as I always use all my blades and have made bailouts with no problems.
Marcos
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 03-03-2012, 04:23 AM   #5 (permalink)
In general, it is not blade related thing, i tried about 4-5 different blades and i always must tighten it hard, to avoid movement of the blades.
At beginning, i had one blade folded during spoolup, so i tighten them more then you would expect, 200g blade have some inertia...
- TDSF in a box...
- TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar
- TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14
jointer is offline        Reply With Quote Quick reply to this message
Old 03-03-2012, 07:29 AM   #6 (permalink)
+1 on the black spacers and you have to tighten them a bit more than other helis, but all my TDRs and those of my friend have good blade holding on all the blades we've tested i.e. Radix std, FBL, Jan's etc.
Heli G is offline        Reply With Quote Quick reply to this message
Old 03-04-2012, 12:11 AM   #7 (permalink)
Thanks, I forgot about the spacers, will put them on today!
Elad.
Henseleit TDR!
Old 03-04-2012, 04:50 AM   #8 (permalink)
If you tightend them so far that they would touch the blades without the spacers then you probably abussed yar blade grips. Beter check them for damage, you dont want these to come of in flight.
RJX 50 Extreme, Logo 600SE,
Ermax is offline        Reply With Quote Quick reply to this message
Old 03-04-2012, 10:43 AM   #9 (permalink)
I had the same thought in mind, but nobody would really dare to, right?!
shaman3 is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 05:20 AM   #10 (permalink)
It had been like that since I got the heli - 5 months ago, didn't have time yesterday to check if the spacers are there or not, will try to check tonight
Henseleit TDR!
Old 03-05-2012, 05:57 AM   #11 (permalink)
What a horrible thought, hope you didnt try and clamp down hard without spacers!
LOGO 500SE & 600SE & 600SX
Synergy E7 -
N7 - N5C
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzTDR + II
Alun
CyprusFlyer is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 12:26 PM   #12 (permalink)
Here people, calm down, there have always been spacers in place...
Name:	blade spacers.jpg
Henseleit TDR!
Old 03-05-2012, 01:33 PM   #13 (permalink)
Is that spacer in place? I looks as if it's added from the outside rather than centered with the bolt going through.
Marcos
Old 03-06-2012, 06:03 AM   #14 (permalink)
I took it out just to make sure I am not mistaking..
Henseleit TDR!
Old 03-06-2012, 07:21 AM   #15 (permalink)
Do you have the spacers on upper AND lower side?
You have the problem while Bailout? The restart-torque is to high? Another posibillity is to fix the blades with another screw (allen screw) in the second hole of the blade grips. But be patient not to damage the blades. This fix is done by pilots trying to do an bladestop.
MartinSausF is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 07:33 AM   #16 (permalink)
And there is one spacer above and one under the blade..?
I'm sorry for asking, but there was one guy here, some time ago, asking if he should use both spacers, or just one per blade, so you never know...
minicopter Diabolo, Henseleit TDR, X50e, X50n, Raptor 50
Futaba 2.4 GHz
DT75 is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 03:38 AM   #17 (permalink)
Yes, spacers are on both sides....
I did not try the bailout yet, Not going to until the matter is solved
Henseleit TDR!
