Mikado V-BAR Mikado V-Stabi/V-BAR Flybarless System Software and Hardware Support |
12-07-2014, 03:07 AM | #1 (permalink) |
Mini Vbar cyclic throw
Hey guys I need some help with my mini Vbar setup on my atom 500 specifically when it comes to the cyclic throw. I have all my TX channels at 100 and at 0 when centered. swashplate is level and blade reads 0 degs when at "starting point", now for me to get 8 degs I need to move the slider all the way to 60. Is that ok? Even though Vbar says useful values are 110-80? If it not what do you guys usually do to fix it?
Also, I'm using a dx7, and I get about 18degs at full up and down( I changed the pitch curve end points to within recommend values. I get 12.6 degs when the slider is at 90 and 11.3 when it is at 80 degs. |
12-07-2014, 03:15 AM | #2 (permalink) |
You need to go in 2 holes on the servo horn, or use shorter ones if that's not possible.
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro |
12-07-2014, 03:18 AM | #3 (permalink) |
Thanks for the quick reply. What's the purpose of the cyclic throw?
12-07-2014, 03:42 AM | #4 (permalink) |
You MUST follow the software tabs, set TX with linear pitch curves, then go imto setup and follow the tabs making sure you have adjusted the TX subtrim and total throw to match the sliders in the setup tab. If you still get too much collective you have to change the mechanical setup, ie shorter servo arms etc, same if the swash plate is not centered etc etc.
Just follow the instructions on each tab and work from left to right, you will end up with a perfect setup that way.
Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks Peter |
12-07-2014, 08:58 AM | #5 (permalink) |
It tells the Vbar your head resolution.
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.) Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo JR XG14 PL8 v2 |
Tags |
cyclic, mini, setup, throw, vbar |
