Go Back   HeliFreak > R/C Electronics Support > Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion
Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion
Old 02-13-2012, 01:34 AM   #901 (permalink)
Originally Posted by FlyingFiz View Post
I agree with Rikybob,
Just move the ball to the other side of the servo arm, then the linkage rod should be straight down. Anyway that's how it appears from the photo, possibly need a side on view to be sure.
Phil
+1
Balls to the inside of the servo arm.
SAB Goblin 700 750MX BeastX - Compass Warp 360 Scorpion HK2520-1360KV V-Bar?
T-Rex 700N LogicTech 6100 - T-Rex 600N FBL OS55 -T-Rex 550FLB Spartan VorTex
T-Rex 450L-6S V-Bar? ----- Blade 130x ---- McpX BL--- DJI Phantom FPV
TBS Discovery FPV
dna001 is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 02:14 AM   #902 (permalink)
Guys, he's mentioned that the ball use to be on the inside, but at the 14mm requested the balls hit the case..
Cheers Kallen
Stretched Trex 500 with ino-labs all round
kwesty2008 is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 05:23 AM   #903 (permalink)
Originally Posted by kwesty2008 View Post
Is there enough room to mount the servo's inside the frame? You need a gap between the servos of the frame thickness plus the case lug thickness, times 2
I'd have to shim the frames out about 5mm. That's how much clearance I'm missing. Then once one servo is in I would have a lot of trouble accessing the heads of the screws for the 2nd servo. I'll just get different servos if I have to.
Right, I think these servos just aren't going to work at 14-14.5mm. I have them setup at 16mm and have enough clearance when the ball is on the inside. These servos are just so boxy, the top isn't tapered at all like many other servos.
Mike A. is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 05:26 AM   #904 (permalink)
Phil
Originally Posted by dna001 View Post
+1
Don't have the clearance for the balls on the inside at 14mm...hence the reson for my initial post.
Old 02-13-2012, 08:04 AM   #905 (permalink)
Anyone heard anything about a firmware update for the Tarot units? I have another one of them coming for my 250 and was hoping they would update to get the tail bounce straightened out.
Align 450 Pro
Align 250 DFC
Blade 180CFX
learjet3 is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 12:13 PM   #906 (permalink)
Have you not got any shorter balls, the ones you have fitted are a bit long. That sounds rude don't it , :-/
Got Tobe cheaper that buying new servo`s
http://www.fast-lad.co.uk/store/h501...y-p-16796.html
OR shim/Pack the servo out a bit ?
TBS Discovery FPV
Old 02-13-2012, 01:26 PM   #907 (permalink)
I'm having the same problem with these servos and I'm using the shortest balls. I think it will be ok at somewhere around 15.5-16mm, but I wish I could get them working at a shorter length.
Trex 500 GF-- CX-3X1000
Blade MCPX V2
bretto is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 04:20 PM   #908 (permalink)
Default Using the ZYX gyro programmer at the field
Originally Posted by Busher View Post
You only need the multi functional programmer if you want to do on field adjustments without a pc, the usb cable is for pc use, but can also be used on the field if you have a lap top.
Got my 450TT Pro put back together with the all-silver Tarot 450FL flybarless head and ZYX 3-axis gyro last week. Boy is she lookin' sexy ;-)
Here's a pre-maiden checkout-flight, showing just how easy it is to use the Tarot ZYX programming card to make adjustments at the field. Tweaked pitch range, cyclic gain, and agility to get a much better feel and response.
It's a bit on the boring side, but hope you get a laugh out of the opening...
[ame]http://www.youtube.com/watch?v=ENnKLfgoZ74[/ame]
By the way, I suggest you do NOT try to mount the gyro on top of the receiver and squeeze them both inside the 450 Pro frame... not enough room and vibes will totally screw things up: tried to put her in a hover and she was pitching and yawing spitting angrely about 30 degrees at a time... very lucky I put her down in one piece! Anyway, mounted both gyro and rx outside the frame, and life is now good ;-)
ID:	289248   Click image for larger version
ID:	289251   Click image for larger version
ID:	289252   Click image for larger version
ID:	289260   Click image for larger version
HK-450TT Pro FBL, Blade 400 FBL, HK-250GT FBL
Exi 450CF v2 FB, HK-250GT FB
Blade 300X, 130X, mCPX
ZeroPitch is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 06:30 PM   #909 (permalink)
Very nice ZP. What caused the tipover?
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 07:43 PM   #910 (permalink)
Total. Inattention.
I was so busy talking up an intro to the video, I didn't notice it started tipping during spool-up.... it might have been the gusting wind, but I think I had rotated the sticks to preflight servo movement, so the gyro thought I wanted the heli to be turned sideways... and it was very happy to comply just as soon as it found enough lift from the now rotating main blades...
Old 02-13-2012, 09:17 PM   #911 (permalink)
Very nice video again! I used your first instructional video to setup my copter-x fbl, your efforts are appreciated.
I don't have the program box yet, but I'll be getting one soon.
Question though:
What are the default values for all of the various settings if you don't have the box?
In the one document I saw, it said various settings defaults are different from 'beginner to extreme' .
Current fleet is getting smaller.
Blackout Mini-H, WarpQuad 230, Blade 200qx, Nano QX, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX6 radio.
Previous fleet: mcpx, 300x, 350qx,450x, qav400, DX7s
InFocus is offline        Reply With Quote Quick reply to this message
Old 02-14-2012, 12:03 PM   #912 (permalink)
Now that Jack Frost has left us (2weeks over -10 deg C), I have tested my 450 again.
I started on the hardcore-settings.
Adjusted the swash-gains to 27 (analog servo's) and in the advanced menu the gyro deadband down from 60 to 20. collective to tail at 6, cyclic to tail on 3.
And I increased my headspeed. Didn't tached it, throotle on 85 - 90 %.
Then to the field.
Did some nice circuits, pitchpumps, piro's etc.
The heli flies oke. No more wags, and the tail was almost rocksolid. Needs a little bit of tweaking to be perfect.
The tarot can stay on my heli.
LOGO 500 : Spartan Vortex Nano; Scorpion 4020 1100kV
Quad 250 : Openpilot CC3D
chopstick is offline        Reply With Quote Quick reply to this message
Old 02-14-2012, 01:28 PM   #913 (permalink)
Hi
I use the unit at my trex 450PRO. My impressions are pretty good. The only problem appears in the tail when we move quickly forward in a straight line using the idle up. The tail moves quickly left and right like a spring. The unit is set to hard 3D mode and the tail servo is ds520. Could you advise on the parameters to be changed.thanks
NARXOSKON is offline        Reply With Quote Quick reply to this message
Old 02-14-2012, 01:36 PM   #914 (permalink)
Hi
Old 02-14-2012, 06:44 PM   #915 (permalink)
Originally Posted by NARXOSKON View Post
Hi
You have too much tail gain. There are multiple options: drop Yaw Total Gain on the gyro, or lower your Tx gain, or lower the I parameter in the advanced Tail Tuning menu.
Goblin Speed | iKon
Old 02-14-2012, 07:46 PM   #916 (permalink)
Turned my swash acceleration to 90 and my dead band values to 10... The heli was flying amazing! No wags, totally locked in... But... Stupid linkage to my blade grip failed...
Next--- blade boom strike... Death spiral---- and down.. All I broke was the one blade.. Will be bAck in air again soon. Loosing my confidence as haven't flown for so long, that in real life hands are freezing! Video coming soon... Crash didn't show... But rest is there... Soon..
Goblin Gasser TRM VX310TT Align MJ Design DTS 700N 91 HZ-R 3D Blackout Extreme Gasser #4 MCPX BL 2 iX12
Gaba
Rahulgaba is offline        Reply With Quote Quick reply to this message
Old 02-15-2012, 02:48 AM   #917 (permalink)
On Yaw I have
Rate L 40
Rate R 40
Gain 100
Advanced:
P 80
I 50
D 30
Acceleration 125; Deceleration 25
RCdeadband 20
Gyro deadband 4
Cyclic to tail 3
collective to tail 6
I still have enough to tune. But I do that step by step so I can see how a setting affects the heli.
Old 02-15-2012, 10:13 AM   #918 (permalink)
First day out with the zyx didn't go so well. I went through one battery getting it setup. I was trying to make adjustments using just the transmitter. I had it hovering semi decent. I put a new battery in and continued. I landed lowered my tail gain a few points and then started spooling up again. As soon as it got light on the skids it rolled really hard to the left...BAM! Trashed the blades, main gear, boom, mainshaft....it's back together. Not really sure what happened. The heli was pretty smooth, so I don't think it was a vibration issue. I took the opportunity to replace the main bearings, and swash too.
Old 02-15-2012, 10:19 AM   #919 (permalink)
Sorry to hear about your crash!
Can you do the following:
1) Post a few pics of your head from various angles
2) Post your complete set up on the tx.
My setup (aside from taking 11 hours, I did a complete R/R on the heli to include a new T/T tail) went without a hitch. I just had to add expo to the 3 axis as it was twitchy as hell!
b
"Trust, then verify"
Rikybo is offline        Reply With Quote Quick reply to this message
Old 02-15-2012, 10:42 AM   #920 (permalink)
@ Mike A:
Did you unplugged the battery after adjusting so the unit initializes with the new settings?
I almost had the same issue. Realized it just in time.
